Interface for Recover feature. More...
#include <FeaturesAPI_Recover.h>
| FeaturesAPI_Recover (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_Recover (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Reference &theBaseFeature, const std::list< ModelHighAPI_Selection > &theRecoveredList, const bool theRecoverCompound=false) | |
| virtual | ~FeaturesAPI_Recover () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeReference > | baseFeature () const |
| Concealed feature. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeRefList > | recoveredList () const |
| Recover list. More... | |
| void | setBaseFeature (const ModelHighAPI_Reference &theBaseFeature) |
| Set base feature. More... | |
| void | setRecoveredList (const std::list< ModelHighAPI_Selection > &theRecoverList) |
| Set recovered list of the base feature. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeReference > | mybaseFeature |
| std::shared_ptr< ModelAPI_AttributeRefList > | myrecoveredList |
explicit |
| FeaturesAPI_Recover::FeaturesAPI_Recover | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| const ModelHighAPI_Reference & | theBaseFeature, | ||
| const std::list< ModelHighAPI_Selection > & | theRecoveredList, | ||
| const bool | theRecoverCompound = false |
inlinevirtual |
Concealed feature.
inlinevirtual |
Recover list.
| void FeaturesAPI_Recover::setBaseFeature | ( | const ModelHighAPI_Reference & | theBaseFeature | ) |
Set base feature.
| void FeaturesAPI_Recover::setRecoveredList | ( | const std::list< ModelHighAPI_Selection > & | theRecoverList | ) |
protectedinherited |
