FeaturesAPI_SharedFaces Class Reference
Interface to find shared faces. More...
#include <FeaturesAPI_SharedFaces.h>
Inheritance diagram for FeaturesAPI_SharedFaces:
 FeaturesAPI_SharedFaces (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_SharedFaces (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theObject, const std::string &theNameGroup)
virtual ~FeaturesAPI_SharedFaces ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelection > objectselected () const
 object selected More...
virtual std::shared_ptr< ModelAPI_AttributeString > groupname () const
 group name More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelection > myobjectselected
std::shared_ptr< ModelAPI_AttributeString > mygroupname
◆ FeaturesAPI_SharedFaces()
FeaturesAPI_SharedFaces::FeaturesAPI_SharedFaces ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ ~FeaturesAPI_SharedFaces()
FeaturesAPI_SharedFaces::~FeaturesAPI_SharedFaces ( )
◆ objectselected()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_SharedFaces::objectselected ( ) const
object selected
◆ groupname()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_SharedFaces::groupname ( ) const
group name
◆ dump()
void FeaturesAPI_SharedFaces::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
