Interface for AIS_InteractiveObject. More...
#include <GeomAPI_AISObject.h>
| GEOMAPI_EXPORT | GeomAPI_AISObject () |
| Creation of empty AIS object. More... | |
| GEOMAPI_EXPORT void | createShape (std::shared_ptr< GeomAPI_Shape > theShape) |
| Creates AIS_Shape object using specified shape. More... | |
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shape > | getShape () const |
| Returns shape used for the presentation creation (can be NULL) More... | |
| GEOMAPI_EXPORT void | createDistance (std::shared_ptr< GeomAPI_Pnt > theStartPoint, std::shared_ptr< GeomAPI_Pnt > theEndPoint, std::shared_ptr< GeomAPI_Pnt > theFlyoutPoint, std::shared_ptr< GeomAPI_Pln > thePlane, double theDistance) |
| Creates PrsDim_LengthDimension object. More... | |
| GEOMAPI_EXPORT bool | isEmptyDistanceGeometry () |
| Returns validity of the AIS distance. More... | |
| GEOMAPI_EXPORT void | createRadius (std::shared_ptr< GeomAPI_Circ > theCircle, std::shared_ptr< GeomAPI_Pnt > theFlyoutPoint, double theRadius) |
| Creates PrsDim_RadiusDimension object. More... | |
| GEOMAPI_EXPORT void | createParallel (std::shared_ptr< GeomAPI_Shape > theLine1, std::shared_ptr< GeomAPI_Shape > theLine2, std::shared_ptr< GeomAPI_Pnt > theFlyoutPoint, std::shared_ptr< GeomAPI_Pln > thePlane) |
| Creates PrsDim_ParallelRelation object for two lines. More... | |
| GEOMAPI_EXPORT void | createPerpendicular (std::shared_ptr< GeomAPI_Shape > theLine1, std::shared_ptr< GeomAPI_Shape > theLine2, std::shared_ptr< GeomAPI_Pln > thePlane) |
| Creates PrsDim_PerpendicularRelation object for two lines. More... | |
| GEOMAPI_EXPORT void | createFixed (std::shared_ptr< GeomAPI_Shape > theShape, std::shared_ptr< GeomAPI_Pln > thePlane) |
| Creates PrsDim_FixedRelation object for an object. More... | |
| GEOMAPI_EXPORT void | setColor (const int &theColor) |
| Assigns the color for the shape. More... | |
| GEOMAPI_EXPORT bool | setColor (int theR, int theG, int theB) |
| GEOMAPI_EXPORT bool | setColor (const std::shared_ptr< GeomAPI_Shape > &theSubShape, int theR, int theG, int theB) |
| Assigns the color for the subshape. More... | |
| GEOMAPI_EXPORT void | getColor (int &theR, int &theG, int &theB) |
| Returns the color for the shape. More... | |
| GEOMAPI_EXPORT bool | setDeflection (const double theDeflection) |
| Assigns the deflection to the shape. More... | |
| GEOMAPI_EXPORT double | getDeflection () const |
| Returns deflection for the shape. More... | |
| GEOMAPI_EXPORT bool | setTransparency (const double theTransparency) |
| Assigns the transparency to the shape. More... | |
| GEOMAPI_EXPORT double | getTransparency () const |
| GEOMAPI_EXPORT double | width () |
| GEOMAPI_EXPORT bool | setWidth (const double &theWidth) |
| Assigns the width of the lines of shape. More... | |
| Checks if the object is empty. More... | |
| GEOMAPI_EXPORT int | getShapeType () const |
| Return shape type according to TopAbs_ShapeEnum if the AIS is AIS_Shape Otherwise returns -1. More... | |
| GEOMAPI_EXPORT void | setPointMarker (int theType, double theScale) |
| Sets marker type for vertex. More... | |
| GEOMAPI_EXPORT bool | setLineStyle (int theStyle) |
| Set line type of edges Has to be defined according to Aspect_TypeOfLine. More... | |
| GEOMAPI_EXPORT bool | setTransparensy (double theVal) |
| Set transparency of the presentation (theVal = 0 ... 1) More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
| GeomAPI_AISObject::GeomAPI_AISObject | ( | ) |
the text selection tolerance
| void GeomAPI_AISObject::createShape | ( | std::shared_ptr< GeomAPI_Shape > | theShape | ) |
| std::shared_ptr< GeomAPI_Shape > GeomAPI_AISObject::getShape | ( | ) | const |
| void GeomAPI_AISObject::createDistance | ( | std::shared_ptr< GeomAPI_Pnt > | theStartPoint, |
| std::shared_ptr< GeomAPI_Pnt > | theEndPoint, | ||
| std::shared_ptr< GeomAPI_Pnt > | theFlyoutPoint, | ||
| std::shared_ptr< GeomAPI_Pln > | thePlane, | ||
| double | theDistance | ||
| [in] | theStartPoint | first point for dimension |
| [in] | theEndPoint | second point for dimension |
| [in] | theFlyoutPoint | the flyout of dimension relative to the measured line |
| [in] | thePlane | the plane which contains all points above |
| [in] | theDistance | value of the distance to be shown |
| bool GeomAPI_AISObject::isEmptyDistanceGeometry | ( | ) |
It is invalid if set measured geometry is not valid, e.g. the distance points are equal.
| void GeomAPI_AISObject::createRadius | ( | std::shared_ptr< GeomAPI_Circ > | theCircle, |
| double | theRadius | ||
| [in] | theCircle | the radius is created for this circle |
| [in] | theFlyoutPoint | the flyout of dimension |
| [in] | theRadius | value of the radius to be shown |
| void GeomAPI_AISObject::createParallel | ( | std::shared_ptr< GeomAPI_Shape > | theLine1, |
| std::shared_ptr< GeomAPI_Shape > | theLine2, | ||
| std::shared_ptr< GeomAPI_Pln > | thePlane | ||
| [in] | theLine1 | first parallel line |
| [in] | theLine2 | second parallel line |
| [in] | theFlyoutPoint | the flyout point for relation |
| [in] | thePlane | the plane which contains the lines |
| void GeomAPI_AISObject::createPerpendicular | ( | std::shared_ptr< GeomAPI_Shape > | theLine1, |
| void GeomAPI_AISObject::createFixed | ( | std::shared_ptr< GeomAPI_Shape > | theShape, |
| [in] | theShape | the object |
| void GeomAPI_AISObject::setColor | ( | const int & | theColor | ) |
| [in] | theColor | index of the color |
| bool GeomAPI_AISObject::setColor | ( | int | theR, |
| int | theG, | ||
| int | theB | ||
| [in] | theR | value of the red component |
| [in] | theG | value of the green component |
| [in] | theB | value of the blue component |
| bool GeomAPI_AISObject::setColor | ( | const std::shared_ptr< GeomAPI_Shape > & | theSubShape, |
| int | theR, | ||
| int | theG, | ||
| int | theB | ||
| [in] | theSubShape | subshape that belongs to shape |
| void GeomAPI_AISObject::getColor | ( | int & | theR, |
| int & | theG, | ||
| int & | theB | ||
| bool GeomAPI_AISObject::setDeflection | ( | const double | theDeflection | ) |
| [in] | theDeflection | value of deflection |
| double GeomAPI_AISObject::getDeflection | ( | ) | const |
| bool GeomAPI_AISObject::setTransparency | ( | const double | theTransparency | ) |
| [in] | theTransparency | value of transparency |
| double GeomAPI_AISObject::getTransparency | ( | ) | const |
| double GeomAPI_AISObject::width | ( | ) |
| bool GeomAPI_AISObject::setWidth | ( | const double & | theWidth | ) |
| bool GeomAPI_AISObject::empty | ( | ) | const |
| int GeomAPI_AISObject::getShapeType | ( | ) | const |
| void GeomAPI_AISObject::setPointMarker | ( | int | theType, |
| double | theScale | ||
The type has to be defined according to Acpect_TypeOfMarker
| bool GeomAPI_AISObject::setLineStyle | ( | int | theStyle | ) |
| bool GeomAPI_AISObject::setTransparensy | ( | double | theVal | ) |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
