PartSet_CustomPrs Class Reference
This is the module custom presentation, which manage an AIS presentation, that can be filled by a feature and visualized in the viewer additionally to usual workshop objects. More...
#include <PartSet_CustomPrs.h>
Inheritance diagram for PartSet_CustomPrs:
 PartSet_CustomPrs (ModuleBase_IWorkshop *theWorkshop)
bool isActive (const ModuleBase_IModule::ModuleBase_CustomizeFlag &theFlag)
 Returns true if the presentation is active. More...
bool activate (const FeaturePtr &theObject, const ModuleBase_IModule::ModuleBase_CustomizeFlag &theFlag, const bool theUpdateViewer)
 Initializes the operation presentation by the parameter object and display the presentation. More...
bool deactivate (const ModuleBase_IModule::ModuleBase_CustomizeFlag &theFlag, const bool theUpdateViewer)
 Initializes the operation presentation by empty object and erase the presentation. More...
bool redisplay (const ObjectPtr &theObject, const ModuleBase_IModule::ModuleBase_CustomizeFlag &theFlag, const bool theUpdateViewer)
 If the presentation is active[displayed], the shapes of the presentation is recomputed and the presentation is redisplayed. More...
void clearPrs ()
 Nullify all internal presentations. More...
void disableCustomMode (ModuleBase_IModule::ModuleBase_CustomizeFlag theMode)
 Disable displaying of custom mode. More...
void enableCustomModes ()
 Enables disabled custom mode. More...
virtual void processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Redefinition of Events_Listener method to listen a moment that the presentation becomes empty. More...
virtual EVENTS_EXPORT bool groupMessages ()
 Listener that needs mostly grouped messages received returns true in this method. More...
static const std::string OPERATION_PARAMETER_COLOR ()
 Returns yellow color. More...
static const std::string OPERATION_RESULT_COLOR ()
 Returns green color. More...
static const std::string OPERATION_HIGHLIGHT_COLOR ()
 Returns color between white and color of highlight. More...
static const std::string OPERATION_REMOVE_FEATURE_COLOR ()
 Returns color lighter than sketch feature entity : pink. More...
static const std::string OPERATION_SKETCH_PLANE ()
 Returns color equal to default color of construction plugin : green. More...
void groupWhileFlush (const std::shared_ptr< Events_Message > &theMessage)
 Allows to group messages while they are flushed (for flush for groupMessages=true listeners) More...
EVENTS_EXPORT void flushGrouped (const Events_ID &theID)
 Sends myGroups on flush finish. More...
◆ PartSet_CustomPrs()
PartSet_CustomPrs::PartSet_CustomPrs ( ModuleBase_IWorkshop *  theWorkshop)
theWorkshopa reference to workshop
◆ OPERATION_PARAMETER_COLOR()
static const std::string PartSet_CustomPrs::OPERATION_PARAMETER_COLOR ( )
inlinestatic
◆ OPERATION_RESULT_COLOR()
static const std::string PartSet_CustomPrs::OPERATION_RESULT_COLOR ( )
inlinestatic
◆ OPERATION_HIGHLIGHT_COLOR()
static const std::string PartSet_CustomPrs::OPERATION_HIGHLIGHT_COLOR ( )
inlinestatic
◆ OPERATION_REMOVE_FEATURE_COLOR()
static const std::string PartSet_CustomPrs::OPERATION_REMOVE_FEATURE_COLOR ( )
inlinestatic
◆ OPERATION_SKETCH_PLANE()
static const std::string PartSet_CustomPrs::OPERATION_SKETCH_PLANE ( )
inlinestatic
◆ isActive()
bool PartSet_CustomPrs::isActive ( const ModuleBase_IModule::ModuleBase_CustomizeFlag &  theFlag)
theFlagan object AIS presentation type
◆ activate()
bool PartSet_CustomPrs::activate ( const FeaturePtr &  theObject,
const ModuleBase_IModule::ModuleBase_CustomizeFlag &  theFlag,
theObjectan operation feature source to fill the presentation
theUpdateViewerthe parameter whether the viewer should be update immediately
true if the presentation is displayed
◆ deactivate()
bool PartSet_CustomPrs::deactivate ( const ModuleBase_IModule::ModuleBase_CustomizeFlag &  theFlag,
true if the presentation has been displayed and now it is erased
◆ redisplay()
bool PartSet_CustomPrs::redisplay ( const ObjectPtr &  theObject,
theObjectan object to redisplay
true if the presentation is redisplayed
◆ clearPrs()
void PartSet_CustomPrs::clearPrs ( )
For example, it can be useful when the viewer/context is closed. If this is not performed and the presentation is assigned in another context, it caused erroneous case because the presentation has linkage to the previous context.
◆ disableCustomMode()
void PartSet_CustomPrs::disableCustomMode ( ModuleBase_IModule::ModuleBase_CustomizeFlag  theMode)
theModea mode to disable
◆ enableCustomModes()
void PartSet_CustomPrs::enableCustomModes ( )
◆ processEvent()
void PartSet_CustomPrs::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
store state to analyze it after display/erase is finished
Implements Events_Listener.
◆ groupMessages()
virtual EVENTS_EXPORT bool Events_Listener::groupMessages ( )
inlinevirtualinherited
In this case during the message is flushed, all the new messages are grouped, not sended immideately and then sent in the end of flush.
Reimplemented in SketchPlugin_OverConstraintsResolver, and SketchSolver_Manager.
◆ groupWhileFlush()
void Events_Listener::groupWhileFlush ( const std::shared_ptr< Events_Message > &  theMessage)
◆ flushGrouped()
void Events_Listener::flushGrouped ( const Events_ID &  theID)
