PlaneGCSSolver_Storage Class Reference
Contains all necessary data in PlaneGCS format to solve a single group of constraints. More...
#include <PlaneGCSSolver_Storage.h>
Inheritance diagram for PlaneGCSSolver_Storage:
 PlaneGCSSolver_Storage (const SolverPtr &theSolver)
virtual void addConstraint (ConstraintPtr theConstraint, ConstraintWrapperPtr theSolverConstraint)
 Change mapping between constraint from SketchPlugin and a constraint applicable for corresponding solver. More...
virtual void addMovementConstraint (const ConstraintWrapperPtr &theSolverConstraint)
 Add a movement constraint which will be destroyed after the next solving of the set of constraints. More...
virtual bool update (FeaturePtr theFeature, bool theForce=false)
 Convert feature to the form applicable for specific solver and map it. More...
virtual bool update (AttributePtr theAttribute, bool theForce=false)
 Convert attribute to the form applicable for specific solver and map it. More...
virtual void makeExternal (const EntityWrapperPtr &theEntity)
 Make entity external. More...
virtual void makeNonExternal (const EntityWrapperPtr &theEntity)
 Make entity non-external. More...
virtual bool removeConstraint (ConstraintPtr theConstraint)
 Removes constraint from the storage. More...
virtual bool changeActiveStatus (ConstraintPtr theConstraint, bool theNewState)
virtual bool UpdateDeactivateList ()
virtual PlaneGCSSolver_Solver::SolveStatus checkDegeneratedGeometry () const
 Verify, the sketch contains degenerated geometry after resolving the set of constraints. More...
virtual void refresh () const
 Update SketchPlugin features after resolving constraints. More...
double * createParameter ()
 Initialize memory for new solver's parameter. More...
void removeParameters (const GCS::SET_pD &theParams)
 Release memory occupied by parameters. More...
virtual void removeInvalidEntities ()
 Remove all features became invalid. More...
virtual bool isEmpty () const
 Check the storage has constraints. More...
virtual void adjustParametrizationOfArcs ()
 Make parametrization of arcs consistent. More...
virtual void getUnderconstrainedGeometry (std::set< ObjectPtr > &theFeatures) const
 Return list of features which are not fully constrained. More...
void addEntity (FeaturePtr theFeature, EntityWrapperPtr theSolverEntity)
 Change mapping feature from SketchPlugin and the entity applicable for corresponding solver. More...
void addEntity (AttributePtr theAttribute, EntityWrapperPtr theSolverEntity)
 Change mapping attribute of a feature and the entity applicable for corresponding solver. More...
const ConstraintWrapperPtr & constraint (const ConstraintPtr &theConstraint) const
 Returns constraint related to corresponding constraint. More...
const EntityWrapperPtr & entity (const FeaturePtr &theFeature) const
 Returns entity related to corresponding feature. More...
const EntityWrapperPtr & entity (const AttributePtr &theAttribute) const
 Returns entity related to corresponding attribute. More...
void removeFeature (FeaturePtr theFeature)
 Removes feature from the storage. More...
void removeAttribute (AttributePtr theAttribute)
 Removes attribute from the storage. More...
bool areFeaturesValid () const
 Check the features have not been removed. More...
virtual bool isNeedToResolve ()
 Shows the sketch should be resolved. More...
void setNeedToResolve (bool theFlag)
 Changes the flag of group to be resolved. More...
std::set< ObjectPtr > getConflictingConstraints (SolverPtr theSolver) const
 Return list of conflicting constraints. More...
void blockEvents (bool isBlocked)
 Block or unblock events when refreshing features. More...
void subscribeUpdates (SketchSolver_Constraint *theSubscriber, const std::string &theGroup) const
 Subscribe for updates of features. More...
void unsubscribeUpdates (SketchSolver_Constraint *theSubscriber) const
 Unsubscribe for updates of features. More...
void notify (const FeaturePtr &theFeature) const
 Notify all subscribers about update of the feature. More...
static void resultToFeatureOrAttribute (const ObjectPtr &theResult, FeaturePtr &theFeature, AttributePtr &theAttribute)
 Convert result to feature or attribute if theResult is linked to center of circle/arc. More...
SolverPtr mySketchSolver
 Sketch solver, prepared in corresponding group. More...
bool myNeedToResolve
 parameters are changed and group needs to be resolved More...
bool myEventsBlocked
 indicates that features do not send events More...
std::map< ConstraintPtr, ConstraintWrapperPtr > myConstraintMap
 map SketchPlugin constraint to a list of solver's constraints More...
std::map< FeaturePtr, EntityWrapperPtr > myFeatureMap
 map SketchPlugin feature to solver's entity More...
std::map< AttributePtr, EntityWrapperPtr > myAttributeMap
 map attribute to solver's entity More...
UpdaterPtr myUpdaters
std::map< ConstraintPtr, ConstraintWrapperPtr > myDeactivatedConstraintMap
◆ addConstraint()
void PlaneGCSSolver_Storage::addConstraint ( ConstraintPtr  theConstraint,
theConstraint[in] original SketchPlugin constraint
theSolverConstraint[in] solver's constraint
Reimplemented from SketchSolver_Storage.
◆ addMovementConstraint()
void PlaneGCSSolver_Storage::addMovementConstraint ( const ConstraintWrapperPtr &  theSolverConstraint)
Implements SketchSolver_Storage.
◆ update() [1/2]
bool PlaneGCSSolver_Storage::update ( FeaturePtr  theFeature,
bool  theForce = false
theFeature[in] feature to convert
theForce[in] forced feature creation
true if the feature has been created or updated
◆ update() [2/2]
bool PlaneGCSSolver_Storage::update ( AttributePtr  theAttribute,
theAttribute[in] attribute to convert
true if the attribute has been created or updated
TODO: Check resultToFeatureOrAttribute() precisely.
◆ makeExternal()
void PlaneGCSSolver_Storage::makeExternal ( const EntityWrapperPtr &  theEntity)
◆ makeNonExternal()
void PlaneGCSSolver_Storage::makeNonExternal ( const EntityWrapperPtr &  theEntity)
◆ removeConstraint()
bool PlaneGCSSolver_Storage::removeConstraint ( ConstraintPtr  theConstraint)
true if the constraint and all its parameters are removed successfully
◆ changeActiveStatus()
bool PlaneGCSSolver_Storage::changeActiveStatus ( ConstraintPtr  theConstraint,
bool  theNewState
◆ UpdateDeactivateList()
bool PlaneGCSSolver_Storage::UpdateDeactivateList ( )
◆ checkDegeneratedGeometry()
PlaneGCSSolver_Solver::SolveStatus PlaneGCSSolver_Storage::checkDegeneratedGeometry ( ) const
STATUS_OK if the geometry is valid, STATUS_DEGENERATED otherwise.
◆ refresh()
void PlaneGCSSolver_Storage::refresh ( ) const
◆ createParameter()
double * PlaneGCSSolver_Storage::createParameter ( )
◆ removeParameters()
void PlaneGCSSolver_Storage::removeParameters ( const GCS::SET_pD &  theParams)
◆ removeInvalidEntities()
void PlaneGCSSolver_Storage::removeInvalidEntities ( )
TODO: Think on optimization of checking invalid features and attributes
◆ isEmpty()
virtual bool PlaneGCSSolver_Storage::isEmpty ( ) const
◆ adjustParametrizationOfArcs()
void PlaneGCSSolver_Storage::adjustParametrizationOfArcs ( )
Forward arcs should have the last parameter greater than the first parameter. Reversed arcs should have the last parameter lesser than the first parameter.
◆ getUnderconstrainedGeometry()
void PlaneGCSSolver_Storage::getUnderconstrainedGeometry ( std::set< ObjectPtr > &  theFeatures) const
◆ addEntity() [1/2]
void SketchSolver_Storage::addEntity ( FeaturePtr  theFeature,
theFeature[in] original SketchPlugin feature
theSolverEntity[in] solver's entity, created outside
◆ addEntity() [2/2]
void SketchSolver_Storage::addEntity ( AttributePtr  theAttribute,
theAttribute[in] original attribute
◆ constraint()
const ConstraintWrapperPtr & SketchSolver_Storage::constraint ( const ConstraintPtr &  theConstraint) const
◆ entity() [1/2]
const EntityWrapperPtr & SketchSolver_Storage::entity ( const FeaturePtr &  theFeature) const
◆ entity() [2/2]
const EntityWrapperPtr & SketchSolver_Storage::entity ( const AttributePtr &  theAttribute) const
TODO: Check resultToFeatureOrAttribute() precisely. Create additional unit-test
◆ removeFeature()
void SketchSolver_Storage::removeFeature ( FeaturePtr  theFeature)
◆ removeAttribute()
void SketchSolver_Storage::removeAttribute ( AttributePtr  theAttribute)
◆ areFeaturesValid()
bool SketchSolver_Storage::areFeaturesValid ( ) const
◆ isNeedToResolve()
virtual bool SketchSolver_Storage::isNeedToResolve ( )
inlinevirtualinherited
◆ setNeedToResolve()
void SketchSolver_Storage::setNeedToResolve ( bool  theFlag)
◆ getConflictingConstraints()
std::set< ObjectPtr > SketchSolver_Storage::getConflictingConstraints ( SolverPtr  theSolver) const
◆ blockEvents()
void SketchSolver_Storage::blockEvents ( bool  isBlocked)
◆ subscribeUpdates()
void SketchSolver_Storage::subscribeUpdates ( SketchSolver_Constraint *  theSubscriber,
const std::string &  theGroup
theSubscriber[in] object which wants to revceive notifications
theGroup[in] group of updates features to be send
◆ unsubscribeUpdates()
void SketchSolver_Storage::unsubscribeUpdates ( SketchSolver_Constraint *  theSubscriber) const
theSubscriber[in] object which does not want to revceive notifications anymore
◆ notify()
void SketchSolver_Storage::notify ( const FeaturePtr &  theFeature) const
◆ resultToFeatureOrAttribute()
void SketchSolver_Storage::resultToFeatureOrAttribute ( const ObjectPtr &  theResult,
FeaturePtr &  theFeature,
staticprotectedinherited
◆ mySketchSolver
SolverPtr SketchSolver_Storage::mySketchSolver
◆ myNeedToResolve
bool SketchSolver_Storage::myNeedToResolve
◆ myEventsBlocked
bool SketchSolver_Storage::myEventsBlocked
◆ myConstraintMap
std::map<ConstraintPtr, ConstraintWrapperPtr> SketchSolver_Storage::myConstraintMap
◆ myFeatureMap
std::map<FeaturePtr, EntityWrapperPtr> SketchSolver_Storage::myFeatureMap
◆ myAttributeMap
std::map<AttributePtr, EntityWrapperPtr> SketchSolver_Storage::myAttributeMap
