Interface to map SketchPlugin features to the entities of corresponding solver. More...
#include <SketchSolver_Storage.h>
| SketchSolver_Storage (SolverPtr theSolver) | |
| virtual void | addConstraint (ConstraintPtr theConstraint, ConstraintWrapperPtr theSolverConstraint) |
| Change mapping between constraint from SketchPlugin and a constraint applicable for corresponding solver. More... | |
| virtual void | addMovementConstraint (const ConstraintWrapperPtr &theSolverConstraint)=0 |
| Add a movement constraint which will be destroyed after the next solving of the set of constraints. More... | |
| void | addEntity (FeaturePtr theFeature, EntityWrapperPtr theSolverEntity) |
| Change mapping feature from SketchPlugin and the entity applicable for corresponding solver. More... | |
| void | addEntity (AttributePtr theAttribute, EntityWrapperPtr theSolverEntity) |
| Change mapping attribute of a feature and the entity applicable for corresponding solver. More... | |
| virtual bool | update (FeaturePtr theFeature, bool theForce=false)=0 |
| Convert feature to the form applicable for specific solver and map it. More... | |
| virtual bool | update (AttributePtr theAttribute, bool theForce=false)=0 |
| Convert attribute to the form applicable for specific solver and map it. More... | |
| const ConstraintWrapperPtr & | constraint (const ConstraintPtr &theConstraint) const |
| Returns constraint related to corresponding constraint. More... | |
| const EntityWrapperPtr & | entity (const FeaturePtr &theFeature) const |
| Returns entity related to corresponding feature. More... | |
| const EntityWrapperPtr & | entity (const AttributePtr &theAttribute) const |
| Returns entity related to corresponding attribute. More... | |
| virtual void | makeExternal (const EntityWrapperPtr &theEntity)=0 |
| Make entity external. More... | |
| virtual void | makeNonExternal (const EntityWrapperPtr &theEntity)=0 |
| Make entity non-external. More... | |
| virtual bool | removeConstraint (ConstraintPtr theConstraint)=0 |
| Removes constraint from the storage. More... | |
| virtual bool | changeActiveStatus (ConstraintPtr theConstraint, bool theNewState)=0 |
| virtual bool | UpdateDeactivateList ()=0 |
| void | removeFeature (FeaturePtr theFeature) |
| Removes feature from the storage. More... | |
| void | removeAttribute (AttributePtr theAttribute) |
| Removes attribute from the storage. More... | |
| virtual void | removeInvalidEntities ()=0 |
| Remove all features became invalid. More... | |
| bool | areFeaturesValid () const |
| Check the features have not been removed. More... | |
| virtual bool | isEmpty () const |
| Check the storage has constraints. More... | |
| virtual bool | isNeedToResolve () |
| Shows the sketch should be resolved. More... | |
| void | setNeedToResolve (bool theFlag) |
| Changes the flag of group to be resolved. More... | |
| std::set< ObjectPtr > | getConflictingConstraints (SolverPtr theSolver) const |
| Return list of conflicting constraints. More... | |
| virtual void | getUnderconstrainedGeometry (std::set< ObjectPtr > &theFeatures) const =0 |
| Return list of features which are not fully constrained. More... | |
| virtual PlaneGCSSolver_Solver::SolveStatus | checkDegeneratedGeometry () const =0 |
| Verify, the sketch contains degenerated geometry after resolving the set of constraints. More... | |
| virtual void | refresh () const =0 |
| Update SketchPlugin features after resolving constraints. More... | |
| void | blockEvents (bool isBlocked) |
| Block or unblock events when refreshing features. More... | |
| void | subscribeUpdates (SketchSolver_Constraint *theSubscriber, const std::string &theGroup) const |
| Subscribe for updates of features. More... | |
| void | unsubscribeUpdates (SketchSolver_Constraint *theSubscriber) const |
| Unsubscribe for updates of features. More... | |
| void | notify (const FeaturePtr &theFeature) const |
| Notify all subscribers about update of the feature. More... | |
| virtual void | adjustParametrizationOfArcs ()=0 |
| Make parametrization of arcs consistent. More... | |
Static Protected Member Functions | |
| static void | resultToFeatureOrAttribute (const ObjectPtr &theResult, FeaturePtr &theFeature, AttributePtr &theAttribute) |
| Convert result to feature or attribute if theResult is linked to center of circle/arc. More... | |
Protected Attributes | |
| SolverPtr | mySketchSolver |
| Sketch solver, prepared in corresponding group. More... | |
| bool | myNeedToResolve |
| parameters are changed and group needs to be resolved More... | |
| bool | myEventsBlocked |
| indicates that features do not send events More... | |
| std::map< ConstraintPtr, ConstraintWrapperPtr > | myConstraintMap |
| map SketchPlugin constraint to a list of solver's constraints More... | |
| std::map< FeaturePtr, EntityWrapperPtr > | myFeatureMap |
| map SketchPlugin feature to solver's entity More... | |
| std::map< AttributePtr, EntityWrapperPtr > | myAttributeMap |
| map attribute to solver's entity More... | |
| UpdaterPtr | myUpdaters |
| std::map< ConstraintPtr, ConstraintWrapperPtr > | myDeactivatedConstraintMap |
| theConstraint | [in] original SketchPlugin constraint |
| theSolverConstraint | [in] solver's constraint |
Reimplemented in PlaneGCSSolver_Storage.
pure virtual |
Implemented in PlaneGCSSolver_Storage.
| void SketchSolver_Storage::addEntity | ( | FeaturePtr | theFeature, |
| EntityWrapperPtr | theSolverEntity | ||
| theFeature | [in] original SketchPlugin feature |
| theSolverEntity | [in] solver's entity, created outside |
| void SketchSolver_Storage::addEntity | ( | AttributePtr | theAttribute, |
| theAttribute | [in] original attribute |
pure virtual |
| theFeature | [in] feature to convert |
| theForce | [in] forced feature creation |
true if the feature has been created or updated Implemented in PlaneGCSSolver_Storage.
pure virtual |
| theAttribute | [in] attribute to convert |
true if the attribute has been created or updated Implemented in PlaneGCSSolver_Storage.
| const ConstraintWrapperPtr & SketchSolver_Storage::constraint | ( | const ConstraintPtr & | theConstraint | ) | const |
| const EntityWrapperPtr & SketchSolver_Storage::entity | ( | const FeaturePtr & | theFeature | ) | const |
| const EntityWrapperPtr & SketchSolver_Storage::entity | ( | const AttributePtr & | theAttribute | ) | const |
TODO: Check resultToFeatureOrAttribute() precisely. Create additional unit-test
pure virtual |
pure virtual |
pure virtual |
true if the constraint and all its parameters are removed successfully Implemented in PlaneGCSSolver_Storage.
| void SketchSolver_Storage::removeFeature | ( | FeaturePtr | theFeature | ) |
| void SketchSolver_Storage::removeAttribute | ( | AttributePtr | theAttribute | ) |
pure virtual |
| bool SketchSolver_Storage::areFeaturesValid | ( | ) | const |
inlinevirtual |
inlinevirtual |
inline |
| std::set< ObjectPtr > SketchSolver_Storage::getConflictingConstraints | ( | SolverPtr | theSolver | ) | const |
pure virtual |
pure virtual |
pure virtual |
| void SketchSolver_Storage::blockEvents | ( | bool | isBlocked | ) |
| void SketchSolver_Storage::subscribeUpdates | ( | SketchSolver_Constraint * | theSubscriber, |
| const std::string & | theGroup | ||
| ) | const |
| theSubscriber | [in] object which wants to revceive notifications |
| theGroup | [in] group of updates features to be send |
| void SketchSolver_Storage::unsubscribeUpdates | ( | SketchSolver_Constraint * | theSubscriber | ) | const |
| theSubscriber | [in] object which does not want to revceive notifications anymore |
| void SketchSolver_Storage::notify | ( | const FeaturePtr & | theFeature | ) | const |
pure virtual |
Forward arcs should have the last parameter greater than the first parameter. Reversed arcs should have the last parameter lesser than the first parameter.
staticprotected |
protected |
protected |
protected |
protected |
protected |
protected |
