Interface for primitive Cone feature. More...
#include <PrimitivesAPI_Cone.h>
| PrimitivesAPI_Cone (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| PrimitivesAPI_Cone (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBasePoint, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theBaseRadius, const ModelHighAPI_Double &theTopRadius, const ModelHighAPI_Double &theHeight) | |
| virtual | ~PrimitivesAPI_Cone () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | basePoint () const |
| Base point. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | axis () const |
| Axis. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | baseRadius () const |
| Base radius. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | topRadius () const |
| Top radius. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | height () const |
| Height. More... | |
| void | setRadius (const ModelHighAPI_Double &theBaseRadius, const ModelHighAPI_Double &theTopRadius) |
| Set radius. More... | |
| void | setHeight (const ModelHighAPI_Double &theHeight) |
| Set height. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelection > | mybasePoint |
| std::shared_ptr< ModelAPI_AttributeSelection > | myaxis |
| std::shared_ptr< ModelAPI_AttributeDouble > | mybaseRadius |
| std::shared_ptr< ModelAPI_AttributeDouble > | mytopRadius |
| std::shared_ptr< ModelAPI_AttributeDouble > | myheight |
explicit |
explicit |
inlinevirtual |
Base point.
inlinevirtual |
Axis.
inlinevirtual |
Base radius.
inlinevirtual |
Top radius.
inlinevirtual |
Height.
| void PrimitivesAPI_Cone::setRadius | ( | const ModelHighAPI_Double & | theBaseRadius, |
| const ModelHighAPI_Double & | theTopRadius | ||
Set radius.
| void PrimitivesAPI_Cone::setHeight | ( | const ModelHighAPI_Double & | theHeight | ) |
Set height.
protectedinherited |
