YACS::ENGINE::attrParser Class Reference
#include <LoadState.hxx>
Inheritance diagram for YACS::ENGINE::attrParser:
Collaboration diagram for YACS::ENGINE::attrParser:
virtual void init (const xmlChar **p, xmlParserBase *father=0)
virtual void onStart (const XML_Char *elem, const xmlChar **p)
virtual void charData (std::string data)
virtual void onEnd (const XML_Char *name)
- Public Member Functions inherited from xmlParserBase
void setAttribute (std::string key, std::string value)
std::string getAttribute (std::string key)
virtual void addData (std::string value)
Public Attributes
std::string _attrValue
- Public Attributes inherited from xmlParserBase
std::map< std::string, int > counts
- Static Public Member Functions inherited from YACS::ENGINE::stateParser
static void setProc (Proc *p)
static void setRuntime (Runtime *runtime)
- Static Public Member Functions inherited from xmlParserBase
static void XMLCALL start_document (void *userData)
static void XMLCALL end_document (void *userData)
static void XMLCALL start_element (void *userData, const xmlChar *name, const xmlChar **p)
static void XMLCALL end_element (void *userData, const xmlChar *name)
static void XMLCALL characters (void *userData, const xmlChar *ch, int len)
static void XMLCALL comment (void *userData, const xmlChar *value)
static void XMLCALL warning (void *userData, const char *fmt,...)
static void XMLCALL error (void *userData, const char *fmt,...)
static void XMLCALL fatal_error (void *userData, const char *fmt,...)
static void XMLCALL cdata_block (void *userData, const xmlChar *value, int len)
static void cleanGarbage ()
static int getGarbageSize ()
static void XML_SetUserData (_xmlParserCtxt *ctxt, xmlParserBase *parser)
- Static Public Attributes inherited from YACS::ENGINE::stateParser
static XMLReadState _state
static std::string _what
- Static Public Attributes inherited from xmlParserBase
static _xmlParserCtxt * _xmlParser
static std::stack< xmlParserBase * > _stackParser
- Protected Member Functions inherited from xmlParserBase
void getAttributes (const xmlChar **p)
virtual void end ()
virtual void stopParse (std::string what)
- Protected Attributes inherited from xmlParserBase
std::map< std::string, std::string > _mapAttrib
std::string _data
xmlParserBase * _father
- Static Protected Attributes inherited from YACS::ENGINE::stateParser
static std::stack< XMLReadState > _stackState
static Proc * _p
static Runtime * _runtime
static std::map< std::string, YACS::StatesForNode > _nodeStateValue
static std::map< std::string, YACS::StatesForNode > _nodeStates
- Static Protected Attributes inherited from xmlParserBase
static std::list< xmlParserBase * > _garbage
Definition at line 129 of file LoadState.hxx.
◆ charData()
void attrParser::charData ( std::string  data)
to be specialized following the kind of xml tag
Reimplemented from YACS::ENGINE::stateParser.
Definition at line 507 of file LoadState.cxx.
508{
509 _attrValue = data;
510}
References _attrValue.
◆ init()
void attrParser::init ( const xmlChar **  p,
xmlParserBase *  father = 0
all parsers must know their father parser (father tag), in order to set values or attributes in father.
Definition at line 489 of file LoadState.cxx.
490{
491 DEBTRACE("attrParser::init()");
492 //_state = XMLINNODE;
493 _father = father;
494 _stackState.push(_state); // keep current state
495 if (p) getAttributes(p);
496}
Definition: LoadState.hxx:98
Definition: LoadState.hxx:83
Proc * p
Definition: driver.cxx:216
References xmlParserBase::_father, YACS::ENGINE::stateParser::_stackState, YACS::ENGINE::stateParser::_state, DEBTRACE, xmlParserBase::getAttributes(), and p.
◆ onEnd()
void attrParser::onEnd ( const XML_Char *  name)
Definition at line 512 of file LoadState.cxx.
513{
514 // cerr << "end attrParser " << name << " " << _stackParser.size() << endl;
516 _father->setAttribute((char*)name, _attrValue);
517 stateParser::onEnd(name);
518}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Definition: LoadState.cxx:111
void setAttribute(std::string key, std::string value)
References _attrValue, xmlParserBase::_father, YACS::ENGINE::stateParser::onEnd(), xmlParserBase::setAttribute(), and YASSERT.
◆ onStart()
void attrParser::onStart ( const XML_Char *  elem,
const xmlChar **  p
Definition at line 499 of file LoadState.cxx.
500{
501 string element(elem);
502 _what = "expected nothing, got <" + element + ">";
505}
Definition: LoadState.hxx:84
virtual void stopParse(std::string what)
References YACS::ENGINE::stateParser::_state, YACS::ENGINE::stateParser::_what, xmlParserBase::stopParse(), and YACS::ENGINE::XMLFATALERROR.
◆ _attrValue
std::string YACS::ENGINE::attrParser::_attrValue
Definition at line 136 of file LoadState.hxx.
Referenced by charData(), and onEnd().
