YACS::ENGINE::stateParser Class Reference
specialized parser to load SALOME execution saved states. More...
#include <LoadState.hxx>
Inheritance diagram for YACS::ENGINE::stateParser:
Collaboration diagram for YACS::ENGINE::stateParser:
virtual void init (const xmlChar **p, xmlParserBase *father=0)
- Public Member Functions inherited from xmlParserBase
void setAttribute (std::string key, std::string value)
std::string getAttribute (std::string key)
virtual void addData (std::string value)
static void setProc (Proc *p)
static void setRuntime (Runtime *runtime)
- Static Public Member Functions inherited from xmlParserBase
static void XMLCALL start_document (void *userData)
static void XMLCALL end_document (void *userData)
static void XMLCALL start_element (void *userData, const xmlChar *name, const xmlChar **p)
static void XMLCALL end_element (void *userData, const xmlChar *name)
static void XMLCALL characters (void *userData, const xmlChar *ch, int len)
static void XMLCALL comment (void *userData, const xmlChar *value)
static void XMLCALL warning (void *userData, const char *fmt,...)
static void XMLCALL error (void *userData, const char *fmt,...)
static void XMLCALL fatal_error (void *userData, const char *fmt,...)
static void XMLCALL cdata_block (void *userData, const xmlChar *value, int len)
static void cleanGarbage ()
static int getGarbageSize ()
static void XML_SetUserData (_xmlParserCtxt *ctxt, xmlParserBase *parser)
Static Public Attributes
static XMLReadState _state
static std::string _what
- Static Public Attributes inherited from xmlParserBase
static _xmlParserCtxt * _xmlParser
static std::stack< xmlParserBase * > _stackParser
virtual void onStart (const XML_Char *elem, const xmlChar **p)
virtual void onEnd (const XML_Char *name)
virtual void charData (std::string data)
- Protected Member Functions inherited from xmlParserBase
void getAttributes (const xmlChar **p)
virtual void end ()
virtual void stopParse (std::string what)
Static Protected Attributes
static std::stack< XMLReadState > _stackState
static Proc * _p
static Runtime * _runtime
static std::map< std::string, YACS::StatesForNode > _nodeStateValue
static std::map< std::string, YACS::StatesForNode > _nodeStates
- Static Protected Attributes inherited from xmlParserBase
static std::list< xmlParserBase * > _garbage
- Public Attributes inherited from xmlParserBase
std::map< std::string, int > counts
- Protected Attributes inherited from xmlParserBase
std::map< std::string, std::string > _mapAttrib
std::string _data
xmlParserBase * _father
this base class must be derived to build specific parsers for each tag defined in the xml file
Definition at line 80 of file LoadState.hxx.
◆ charData()
void stateParser::charData ( std::string  data)
to be specialized following the kind of xml tag
Reimplemented from xmlParserBase.
Reimplemented in YACS::ENGINE::attrParser, YACS::ENGINE::simpleTypeParser, YACS::ENGINE::loopPortParser, and YACS::ENGINE::sampleParser.
Definition at line 119 of file LoadState.cxx.
120{
121 //cerr << "data " << data << endl;
122}
◆ init()
void stateParser::init ( const xmlChar **  p,
xmlParserBase *  father = 0
all parsers must know their father parser (father tag), in order to set values or attributes in father.
Reimplemented in outputParser, YACS::ENGINE::graphParser, YACS::ENGINE::nodeParser, YACS::ENGINE::attrParser, YACS::ENGINE::portParser, YACS::ENGINE::valueParser, YACS::ENGINE::arrayParser, YACS::ENGINE::dataParser, YACS::ENGINE::simpleTypeParser, YACS::ENGINE::loopPortParser, and YACS::ENGINE::sampleParser.
Definition at line 65 of file LoadState.cxx.
66{
67 DEBTRACE("stateParser::init()");
69 _father = father;
70 _stackState.push(_state);
74 _nodeStateValue["TOACTIVATE"] =YACS::TOACTIVATE;
75 _nodeStateValue["ACTIVATED"] =YACS::ACTIVATED;
76 _nodeStateValue["DESACTIVATED"] =YACS::DESACTIVATED;
78 _nodeStateValue["SUSPENDED"] =YACS::SUSPENDED;
79 _nodeStateValue["LOADFAILED"] =YACS::LOADFAILED;
80 _nodeStateValue["EXECFAILED"] =YACS::EXECFAILED;
82 _nodeStateValue["INTERNALERR"] =YACS::INTERNALERR;
86 _nodeStates.clear();
87}
Definition: LoadState.hxx:98
Definition: LoadState.hxx:83
Definition: LoadState.hxx:102
Definition: LoadState.hxx:101
@ FAILED
Definition: define.hxx:51
@ DESACTIVATED
Definition: define.hxx:42
@ EXECFAILED
Definition: define.hxx:46
@ TOLOAD
Definition: define.hxx:38
@ LOADED
Definition: define.hxx:39
@ READY
Definition: define.hxx:37
@ ACTIVATED
Definition: define.hxx:41
@ INTERNALERR
Definition: define.hxx:49
@ DONE
Definition: define.hxx:43
@ TOACTIVATE
Definition: define.hxx:40
@ SUSPENDED
Definition: define.hxx:44
@ PAUSE
Definition: define.hxx:47
@ DISABLED
Definition: define.hxx:50
@ LOADFAILED
Definition: define.hxx:45
@ ERROR
Definition: define.hxx:52
References xmlParserBase::_father, _nodeStates, _nodeStateValue, _stackState, _state, YACS::ACTIVATED, DEBTRACE, YACS::DESACTIVATED, YACS::DISABLED, YACS::DONE, YACS::ERROR, YACS::EXECFAILED, YACS::FAILED, YACS::INTERNALERR, YACS::LOADED, YACS::LOADFAILED, YACS::PAUSE, YACS::READY, YACS::SUSPENDED, YACS::TOACTIVATE, YACS::TOLOAD, and YACS::ENGINE::XMLNOCONTEXT.
◆ onEnd()
◆ onStart()
void stateParser::onStart ( const XML_Char *  elem,
const xmlChar **  p
Reimplemented in YACS::ENGINE::graphParser, YACS::ENGINE::nodeParser, YACS::ENGINE::attrParser, YACS::ENGINE::portParser, YACS::ENGINE::valueParser, YACS::ENGINE::arrayParser, YACS::ENGINE::dataParser, YACS::ENGINE::simpleTypeParser, YACS::ENGINE::loopPortParser, and YACS::ENGINE::sampleParser.
Definition at line 90 of file LoadState.cxx.
91{
92 DEBTRACE("stateParser::onStart");
93 string element(elem);
94 stateParser *parser = 0;
95 if (element == "graphState") parser = new graphParser();
96 else
97 {
98 _what = "expected <graphState>, got <" + element + ">";
101 }
102 if (parser)
103 {
104 _stackParser.push(parser);
106 parser->init(p);
107 }
108}
Definition: LoadState.hxx:81
virtual void init(const xmlChar **p, xmlParserBase *father=0)
Definition: LoadState.cxx:65
Definition: LoadState.hxx:84
static void XML_SetUserData(_xmlParserCtxt *ctxt, xmlParserBase *parser)
virtual void stopParse(std::string what)
Proc * p
Definition: driver.cxx:216
References xmlParserBase::_stackParser, _state, _what, xmlParserBase::_xmlParser, DEBTRACE, YACS::parser::init(), p, xmlParserBase::stopParse(), xmlParserBase::XML_SetUserData(), and YACS::ENGINE::XMLFATALERROR.
◆ setProc()
void stateParser::setProc ( Proc *  p)
Definition at line 55 of file LoadState.cxx.
56{
57 _p= p;
58}
References _p, and p.
◆ setRuntime()
void stateParser::setRuntime ( Runtime *  runtime)
Definition at line 60 of file LoadState.cxx.
61{
62 _runtime = runtime;
63}
Definition: LoadState.hxx:100
References _runtime.
◆ _nodeStates
std::map< std::string, YACS::StatesForNode > stateParser::_nodeStates
staticprotected
◆ _nodeStateValue
std::map< std::string, YACS::StatesForNode > stateParser::_nodeStateValue
staticprotected
Definition at line 101 of file LoadState.hxx.
Referenced by init(), and YACS::ENGINE::nodeParser::onEnd().
◆ _p
Proc * stateParser::_p
staticprotected
◆ _runtime
Runtime * stateParser::_runtime
staticprotected
Definition at line 100 of file LoadState.hxx.
Referenced by setRuntime().
◆ _stackState
◆ _state
◆ _what
