YACS::ENGINE::valueParser Class Reference
#include <LoadState.hxx>
Inheritance diagram for YACS::ENGINE::valueParser:
Collaboration diagram for YACS::ENGINE::valueParser:
virtual void init (const xmlChar **p, xmlParserBase *father=0)
virtual void onStart (const XML_Char *elem, const xmlChar **p)
virtual void onEnd (const XML_Char *name)
virtual void addData (std::string value)
- Public Member Functions inherited from xmlParserBase
void setAttribute (std::string key, std::string value)
std::string getAttribute (std::string key)
- Static Public Member Functions inherited from YACS::ENGINE::stateParser
static void setProc (Proc *p)
static void setRuntime (Runtime *runtime)
- Static Public Member Functions inherited from xmlParserBase
static void XMLCALL start_document (void *userData)
static void XMLCALL end_document (void *userData)
static void XMLCALL start_element (void *userData, const xmlChar *name, const xmlChar **p)
static void XMLCALL end_element (void *userData, const xmlChar *name)
static void XMLCALL characters (void *userData, const xmlChar *ch, int len)
static void XMLCALL comment (void *userData, const xmlChar *value)
static void XMLCALL warning (void *userData, const char *fmt,...)
static void XMLCALL error (void *userData, const char *fmt,...)
static void XMLCALL fatal_error (void *userData, const char *fmt,...)
static void XMLCALL cdata_block (void *userData, const xmlChar *value, int len)
static void cleanGarbage ()
static int getGarbageSize ()
static void XML_SetUserData (_xmlParserCtxt *ctxt, xmlParserBase *parser)
- Public Attributes inherited from xmlParserBase
std::map< std::string, int > counts
- Static Public Attributes inherited from YACS::ENGINE::stateParser
static XMLReadState _state
static std::string _what
- Static Public Attributes inherited from xmlParserBase
static _xmlParserCtxt * _xmlParser
static std::stack< xmlParserBase * > _stackParser
- Protected Member Functions inherited from YACS::ENGINE::stateParser
virtual void charData (std::string data)
- Protected Member Functions inherited from xmlParserBase
void getAttributes (const xmlChar **p)
virtual void end ()
virtual void stopParse (std::string what)
- Protected Attributes inherited from xmlParserBase
std::map< std::string, std::string > _mapAttrib
std::string _data
xmlParserBase * _father
- Static Protected Attributes inherited from YACS::ENGINE::stateParser
static std::stack< XMLReadState > _stackState
static Proc * _p
static Runtime * _runtime
static std::map< std::string, YACS::StatesForNode > _nodeStateValue
static std::map< std::string, YACS::StatesForNode > _nodeStates
- Static Protected Attributes inherited from xmlParserBase
static std::list< xmlParserBase * > _garbage
Definition at line 149 of file LoadState.hxx.
◆ addData()
void valueParser::addData ( std::string  value)
Add data on the data attribute of the parser object dedicated to an xml tag
Reimplemented from xmlParserBase.
Definition at line 637 of file LoadState.cxx.
638{
639 _data = "<value>" + value + "</value>";
640}
std::string _data
References xmlParserBase::_data.
◆ init()
void valueParser::init ( const xmlChar **  p,
xmlParserBase *  father = 0
all parsers must know their father parser (father tag), in order to set values or attributes in father.
Reimplemented from YACS::ENGINE::stateParser.
Definition at line 611 of file LoadState.cxx.
612{
613 DEBTRACE("valueParser::init()");
615 _father = father;
616 _stackState.push(_state);
617 if (p) getAttributes(p);
618}
Definition: LoadState.hxx:98
Definition: LoadState.hxx:83
Proc * p
Definition: driver.cxx:216
References xmlParserBase::_father, YACS::ENGINE::stateParser::_stackState, YACS::ENGINE::stateParser::_state, DEBTRACE, xmlParserBase::getAttributes(), p, and YACS::ENGINE::XMLINVALUE.
◆ onEnd()
void valueParser::onEnd ( const XML_Char *  name)
Definition at line 642 of file LoadState.cxx.
643{
644 DEBTRACE( _data );
646 string elem = (char *) name;
647 //if (elem == "value" || elem == "data" || elem == "array")
648 stateParser::onEnd(name);
649 //else YASSERT(0); //DEBTRACE("valueParser::onEnd " << elem);
650}
Definition: LoadState.cxx:111
virtual void addData(std::string value)
References xmlParserBase::_data, xmlParserBase::_father, xmlParserBase::addData(), DEBTRACE, and YACS::ENGINE::stateParser::onEnd().
◆ onStart()
void valueParser::onStart ( const XML_Char *  elem,
const xmlChar **  p
Definition at line 621 of file LoadState.cxx.
622{
623 string element(elem);
624 DEBTRACE("value type " << element );
625 stateParser *parser = 0;
626 if (element == "data") parser = new dataParser();
627 else if (element == "array") parser = new arrayParser();
628 else parser = new simpleTypeParser();
629 if (parser)
630 {
631 _stackParser.push(parser);
633 parser->init(p, this);
634 }
635}
specialized parser to load SALOME execution saved states.
Definition: LoadState.hxx:81
virtual void init(const xmlChar **p, xmlParserBase *father=0)
Definition: LoadState.cxx:65
static void XML_SetUserData(_xmlParserCtxt *ctxt, xmlParserBase *parser)
References xmlParserBase::_stackParser, xmlParserBase::_xmlParser, DEBTRACE, YACS::parser::init(), p, and xmlParserBase::XML_SetUserData().
