YACS::ENGINE::arrayParser Class Reference
#include <LoadState.hxx>
Inheritance diagram for YACS::ENGINE::arrayParser:
Collaboration diagram for YACS::ENGINE::arrayParser:
virtual void init (const xmlChar **p, xmlParserBase *father=0)
virtual void onStart (const XML_Char *elem, const xmlChar **p)
virtual void onEnd (const XML_Char *name)
virtual void addData (std::string value)
- Public Member Functions inherited from xmlParserBase
void setAttribute (std::string key, std::string value)
std::string getAttribute (std::string key)
- Static Public Member Functions inherited from YACS::ENGINE::stateParser
static void setProc (Proc *p)
static void setRuntime (Runtime *runtime)
- Static Public Member Functions inherited from xmlParserBase
static void XMLCALL start_document (void *userData)
static void XMLCALL end_document (void *userData)
static void XMLCALL start_element (void *userData, const xmlChar *name, const xmlChar **p)
static void XMLCALL end_element (void *userData, const xmlChar *name)
static void XMLCALL characters (void *userData, const xmlChar *ch, int len)
static void XMLCALL comment (void *userData, const xmlChar *value)
static void XMLCALL warning (void *userData, const char *fmt,...)
static void XMLCALL error (void *userData, const char *fmt,...)
static void XMLCALL fatal_error (void *userData, const char *fmt,...)
static void XMLCALL cdata_block (void *userData, const xmlChar *value, int len)
static void cleanGarbage ()
static int getGarbageSize ()
static void XML_SetUserData (_xmlParserCtxt *ctxt, xmlParserBase *parser)
- Public Attributes inherited from xmlParserBase
std::map< std::string, int > counts
- Static Public Attributes inherited from YACS::ENGINE::stateParser
static XMLReadState _state
static std::string _what
- Static Public Attributes inherited from xmlParserBase
static _xmlParserCtxt * _xmlParser
static std::stack< xmlParserBase * > _stackParser
- Protected Member Functions inherited from YACS::ENGINE::stateParser
virtual void charData (std::string data)
- Protected Member Functions inherited from xmlParserBase
void getAttributes (const xmlChar **p)
virtual void end ()
virtual void stopParse (std::string what)
- Protected Attributes inherited from xmlParserBase
std::map< std::string, std::string > _mapAttrib
std::string _data
xmlParserBase * _father
- Static Protected Attributes inherited from YACS::ENGINE::stateParser
static std::stack< XMLReadState > _stackState
static Proc * _p
static Runtime * _runtime
static std::map< std::string, YACS::StatesForNode > _nodeStateValue
static std::map< std::string, YACS::StatesForNode > _nodeStates
- Static Protected Attributes inherited from xmlParserBase
static std::list< xmlParserBase * > _garbage
Definition at line 158 of file LoadState.hxx.
◆ addData()
void arrayParser::addData ( std::string  value)
Add data on the data attribute of the parser object dedicated to an xml tag
Reimplemented from xmlParserBase.
Definition at line 684 of file LoadState.cxx.
685{
686 string val = "<array>" + value + "</array>";
687 _data = val;
688}
std::string _data
References xmlParserBase::_data.
◆ init()
void arrayParser::init ( const xmlChar **  p,
xmlParserBase *  father = 0
all parsers must know their father parser (father tag), in order to set values or attributes in father.
Reimplemented from YACS::ENGINE::stateParser.
Definition at line 654 of file LoadState.cxx.
655{
656 DEBTRACE("arrayParser::init()");
658 _father = father;
659 _stackState.push(_state);
660 if (p) getAttributes(p);
661}
Definition: LoadState.hxx:98
Definition: LoadState.hxx:83
Proc * p
Definition: driver.cxx:216
References xmlParserBase::_father, YACS::ENGINE::stateParser::_stackState, YACS::ENGINE::stateParser::_state, DEBTRACE, xmlParserBase::getAttributes(), p, and YACS::ENGINE::XMLINVALUE.
◆ onEnd()
void arrayParser::onEnd ( const XML_Char *  name)
Definition at line 691 of file LoadState.cxx.
692{
693 // cerr << "arrayParser::onEnd " << name << endl;
694 // cerr << _data << endl;
696 stateParser::onEnd(name);
697}
Definition: LoadState.cxx:111
virtual void addData(std::string value)
References xmlParserBase::_data, xmlParserBase::_father, xmlParserBase::addData(), and YACS::ENGINE::stateParser::onEnd().
◆ onStart()
void arrayParser::onStart ( const XML_Char *  elem,
const xmlChar **  p
Definition at line 664 of file LoadState.cxx.
665{
666 string element(elem);
667 DEBTRACE("array type " << element);
668 stateParser *parser = 0;
669 if (element == "data") parser = new dataParser();
670 else
671 {
672 _what = "expected data, got <" + element + ">";
675 }
676 if (parser)
677 {
678 _stackParser.push(parser);
680 parser->init(p, this);
681 }
682}
specialized parser to load SALOME execution saved states.
Definition: LoadState.hxx:81
virtual void init(const xmlChar **p, xmlParserBase *father=0)
Definition: LoadState.cxx:65
Definition: LoadState.hxx:84
static void XML_SetUserData(_xmlParserCtxt *ctxt, xmlParserBase *parser)
virtual void stopParse(std::string what)
References xmlParserBase::_stackParser, YACS::ENGINE::stateParser::_state, YACS::ENGINE::stateParser::_what, xmlParserBase::_xmlParser, DEBTRACE, YACS::parser::init(), p, xmlParserBase::stopParse(), xmlParserBase::XML_SetUserData(), and YACS::ENGINE::XMLFATALERROR.
