YACS::ENGINE::dataParser Class Reference
#include <LoadState.hxx>
Inheritance diagram for YACS::ENGINE::dataParser:
Collaboration diagram for YACS::ENGINE::dataParser:
virtual void init (const xmlChar **p, xmlParserBase *father=0)
virtual void onStart (const XML_Char *elem, const xmlChar **p)
virtual void onEnd (const XML_Char *name)
virtual void addData (std::string value)
- Public Member Functions inherited from xmlParserBase
void setAttribute (std::string key, std::string value)
std::string getAttribute (std::string key)
Public Attributes
std::list< std::string > _dataList
- Public Attributes inherited from xmlParserBase
std::map< std::string, int > counts
- Static Public Member Functions inherited from YACS::ENGINE::stateParser
static void setProc (Proc *p)
static void setRuntime (Runtime *runtime)
- Static Public Member Functions inherited from xmlParserBase
static void XMLCALL start_document (void *userData)
static void XMLCALL end_document (void *userData)
static void XMLCALL start_element (void *userData, const xmlChar *name, const xmlChar **p)
static void XMLCALL end_element (void *userData, const xmlChar *name)
static void XMLCALL characters (void *userData, const xmlChar *ch, int len)
static void XMLCALL comment (void *userData, const xmlChar *value)
static void XMLCALL warning (void *userData, const char *fmt,...)
static void XMLCALL error (void *userData, const char *fmt,...)
static void XMLCALL fatal_error (void *userData, const char *fmt,...)
static void XMLCALL cdata_block (void *userData, const xmlChar *value, int len)
static void cleanGarbage ()
static int getGarbageSize ()
static void XML_SetUserData (_xmlParserCtxt *ctxt, xmlParserBase *parser)
- Static Public Attributes inherited from YACS::ENGINE::stateParser
static XMLReadState _state
static std::string _what
- Static Public Attributes inherited from xmlParserBase
static _xmlParserCtxt * _xmlParser
static std::stack< xmlParserBase * > _stackParser
- Protected Member Functions inherited from YACS::ENGINE::stateParser
virtual void charData (std::string data)
- Protected Member Functions inherited from xmlParserBase
void getAttributes (const xmlChar **p)
virtual void end ()
virtual void stopParse (std::string what)
- Protected Attributes inherited from xmlParserBase
std::map< std::string, std::string > _mapAttrib
std::string _data
xmlParserBase * _father
- Static Protected Attributes inherited from YACS::ENGINE::stateParser
static std::stack< XMLReadState > _stackState
static Proc * _p
static Runtime * _runtime
static std::map< std::string, YACS::StatesForNode > _nodeStateValue
static std::map< std::string, YACS::StatesForNode > _nodeStates
- Static Protected Attributes inherited from xmlParserBase
static std::list< xmlParserBase * > _garbage
Definition at line 167 of file LoadState.hxx.
◆ addData()
void dataParser::addData ( std::string  value)
Add data on the data attribute of the parser object dedicated to an xml tag
Reimplemented from xmlParserBase.
Definition at line 731 of file LoadState.cxx.
732{
733 _dataList.push_back(value);
734}
Definition: LoadState.hxx:174
References _dataList.
◆ init()
void dataParser::init ( const xmlChar **  p,
xmlParserBase *  father = 0
all parsers must know their father parser (father tag), in order to set values or attributes in father.
Reimplemented from YACS::ENGINE::stateParser.
Definition at line 701 of file LoadState.cxx.
702{
703 DEBTRACE("dataParser::init()");
705 _father = father;
706 _stackState.push(_state);
707 if (p) getAttributes(p);
708}
Definition: LoadState.hxx:98
Definition: LoadState.hxx:83
Proc * p
Definition: driver.cxx:216
References xmlParserBase::_father, YACS::ENGINE::stateParser::_stackState, YACS::ENGINE::stateParser::_state, DEBTRACE, xmlParserBase::getAttributes(), p, and YACS::ENGINE::XMLINVALUE.
◆ onEnd()
void dataParser::onEnd ( const XML_Char *  name)
Definition at line 736 of file LoadState.cxx.
737{
738 // cerr << "dataParser::onEnd " << name << endl;
739 string val = "<data>";
740 while (!_dataList.empty())
741 {
742 val += _dataList.front();
743 _dataList.pop_front();
744 }
745 val += "</data>";
746 // cerr << val << endl;
747 _father->addData(val);
748 stateParser::onEnd(name);
749}
Definition: LoadState.cxx:111
virtual void addData(std::string value)
References _dataList, xmlParserBase::_father, xmlParserBase::addData(), and YACS::ENGINE::stateParser::onEnd().
◆ onStart()
void dataParser::onStart ( const XML_Char *  elem,
const xmlChar **  p
Definition at line 711 of file LoadState.cxx.
712{
713 string element(elem);
714 DEBTRACE("data type " << element );
715 stateParser *parser = 0;
716 if (element == "value") parser = new valueParser();
717 else
718 {
719 _what = "expected value, got <" + element + ">";
722 }
723 if (parser)
724 {
725 _stackParser.push(parser);
727 parser->init(p, this);
728 }
729}
specialized parser to load SALOME execution saved states.
Definition: LoadState.hxx:81
virtual void init(const xmlChar **p, xmlParserBase *father=0)
Definition: LoadState.cxx:65
Definition: LoadState.hxx:84
static void XML_SetUserData(_xmlParserCtxt *ctxt, xmlParserBase *parser)
virtual void stopParse(std::string what)
References xmlParserBase::_stackParser, YACS::ENGINE::stateParser::_state, YACS::ENGINE::stateParser::_what, xmlParserBase::_xmlParser, DEBTRACE, YACS::parser::init(), p, xmlParserBase::stopParse(), xmlParserBase::XML_SetUserData(), and YACS::ENGINE::XMLFATALERROR.
◆ _dataList
std::list<std::string> YACS::ENGINE::dataParser::_dataList
Definition at line 174 of file LoadState.hxx.
Referenced by addData(), and onEnd().
