YACS::ENGINE::simpleTypeParser Class Reference
#include <LoadState.hxx>
Inheritance diagram for YACS::ENGINE::simpleTypeParser:
Collaboration diagram for YACS::ENGINE::simpleTypeParser:
virtual void init (const xmlChar **p, xmlParserBase *father=0)
virtual void onStart (const XML_Char *elem, const xmlChar **p)
virtual void onEnd (const XML_Char *name)
virtual void charData (std::string data)
- Public Member Functions inherited from xmlParserBase
void setAttribute (std::string key, std::string value)
std::string getAttribute (std::string key)
virtual void addData (std::string value)
- Static Public Member Functions inherited from YACS::ENGINE::stateParser
static void setProc (Proc *p)
static void setRuntime (Runtime *runtime)
- Static Public Member Functions inherited from xmlParserBase
static void XMLCALL start_document (void *userData)
static void XMLCALL end_document (void *userData)
static void XMLCALL start_element (void *userData, const xmlChar *name, const xmlChar **p)
static void XMLCALL end_element (void *userData, const xmlChar *name)
static void XMLCALL characters (void *userData, const xmlChar *ch, int len)
static void XMLCALL comment (void *userData, const xmlChar *value)
static void XMLCALL warning (void *userData, const char *fmt,...)
static void XMLCALL error (void *userData, const char *fmt,...)
static void XMLCALL fatal_error (void *userData, const char *fmt,...)
static void XMLCALL cdata_block (void *userData, const xmlChar *value, int len)
static void cleanGarbage ()
static int getGarbageSize ()
static void XML_SetUserData (_xmlParserCtxt *ctxt, xmlParserBase *parser)
- Public Attributes inherited from xmlParserBase
std::map< std::string, int > counts
- Static Public Attributes inherited from YACS::ENGINE::stateParser
static XMLReadState _state
static std::string _what
- Static Public Attributes inherited from xmlParserBase
static _xmlParserCtxt * _xmlParser
static std::stack< xmlParserBase * > _stackParser
- Protected Member Functions inherited from xmlParserBase
void getAttributes (const xmlChar **p)
virtual void end ()
virtual void stopParse (std::string what)
- Protected Attributes inherited from xmlParserBase
std::map< std::string, std::string > _mapAttrib
std::string _data
xmlParserBase * _father
- Static Protected Attributes inherited from YACS::ENGINE::stateParser
static std::stack< XMLReadState > _stackState
static Proc * _p
static Runtime * _runtime
static std::map< std::string, YACS::StatesForNode > _nodeStateValue
static std::map< std::string, YACS::StatesForNode > _nodeStates
- Static Protected Attributes inherited from xmlParserBase
static std::list< xmlParserBase * > _garbage
Definition at line 177 of file LoadState.hxx.
◆ charData()
void simpleTypeParser::charData ( std::string  data)
to be specialized following the kind of xml tag
Reimplemented from YACS::ENGINE::stateParser.
Definition at line 778 of file LoadState.cxx.
779{
780 _data = _data + data;
781}
std::string _data
References xmlParserBase::_data.
◆ init()
void simpleTypeParser::init ( const xmlChar **  p,
xmlParserBase *  father = 0
all parsers must know their father parser (father tag), in order to set values or attributes in father.
Definition at line 753 of file LoadState.cxx.
754{
755 DEBTRACE("simpleTypeParser::init()");
757 _father = father;
758 _stackState.push(_state);
759 if (p) getAttributes(p);
760}
Definition: LoadState.hxx:98
Definition: LoadState.hxx:83
Proc * p
Definition: driver.cxx:216
References xmlParserBase::_father, YACS::ENGINE::stateParser::_stackState, YACS::ENGINE::stateParser::_state, DEBTRACE, xmlParserBase::getAttributes(), p, and YACS::ENGINE::XMLINVALUE.
◆ onEnd()
void simpleTypeParser::onEnd ( const XML_Char *  name)
Definition at line 770 of file LoadState.cxx.
771{
772 string val = string("<") + (char*) name + ">" + _data + "</" + (char*) name +">";
773 DEBTRACE( val );
774 _father->addData(val);
775 stateParser::onEnd(name);
776}
Definition: LoadState.cxx:111
virtual void addData(std::string value)
References xmlParserBase::_data, xmlParserBase::_father, xmlParserBase::addData(), DEBTRACE, and YACS::ENGINE::stateParser::onEnd().
◆ onStart()
void simpleTypeParser::onStart ( const XML_Char *  elem,
const xmlChar **  p
Definition at line 762 of file LoadState.cxx.
763{
764 string element(elem);
765 _what = "expected nothing, got <" + element + ">";
768}
Definition: LoadState.hxx:84
virtual void stopParse(std::string what)
References YACS::ENGINE::stateParser::_state, YACS::ENGINE::stateParser::_what, xmlParserBase::stopParse(), and YACS::ENGINE::XMLFATALERROR.
