YACS::ENGINE::graphParser Class Reference
#include <LoadState.hxx>
Inheritance diagram for YACS::ENGINE::graphParser:
Collaboration diagram for YACS::ENGINE::graphParser:
virtual void init (const xmlChar **p, xmlParserBase *father=0)
virtual void onStart (const XML_Char *elem, const xmlChar **p)
virtual void onEnd (const XML_Char *name)
- Public Member Functions inherited from xmlParserBase
void setAttribute (std::string key, std::string value)
std::string getAttribute (std::string key)
virtual void addData (std::string value)
- Static Public Member Functions inherited from YACS::ENGINE::stateParser
static void setProc (Proc *p)
static void setRuntime (Runtime *runtime)
- Static Public Member Functions inherited from xmlParserBase
static void XMLCALL start_document (void *userData)
static void XMLCALL end_document (void *userData)
static void XMLCALL start_element (void *userData, const xmlChar *name, const xmlChar **p)
static void XMLCALL end_element (void *userData, const xmlChar *name)
static void XMLCALL characters (void *userData, const xmlChar *ch, int len)
static void XMLCALL comment (void *userData, const xmlChar *value)
static void XMLCALL warning (void *userData, const char *fmt,...)
static void XMLCALL error (void *userData, const char *fmt,...)
static void XMLCALL fatal_error (void *userData, const char *fmt,...)
static void XMLCALL cdata_block (void *userData, const xmlChar *value, int len)
static void cleanGarbage ()
static int getGarbageSize ()
static void XML_SetUserData (_xmlParserCtxt *ctxt, xmlParserBase *parser)
- Public Attributes inherited from xmlParserBase
std::map< std::string, int > counts
- Static Public Attributes inherited from YACS::ENGINE::stateParser
static XMLReadState _state
static std::string _what
- Static Public Attributes inherited from xmlParserBase
static _xmlParserCtxt * _xmlParser
static std::stack< xmlParserBase * > _stackParser
- Protected Member Functions inherited from YACS::ENGINE::stateParser
virtual void charData (std::string data)
- Protected Member Functions inherited from xmlParserBase
void getAttributes (const xmlChar **p)
virtual void end ()
virtual void stopParse (std::string what)
- Protected Attributes inherited from xmlParserBase
std::map< std::string, std::string > _mapAttrib
std::string _data
xmlParserBase * _father
- Static Protected Attributes inherited from YACS::ENGINE::stateParser
static std::stack< XMLReadState > _stackState
static Proc * _p
static Runtime * _runtime
static std::map< std::string, YACS::StatesForNode > _nodeStateValue
static std::map< std::string, YACS::StatesForNode > _nodeStates
- Static Protected Attributes inherited from xmlParserBase
static std::list< xmlParserBase * > _garbage
Definition at line 106 of file LoadState.hxx.
◆ init()
void graphParser::init ( const xmlChar **  p,
xmlParserBase *  father = 0
all parsers must know their father parser (father tag), in order to set values or attributes in father.
Reimplemented from YACS::ENGINE::stateParser.
Definition at line 126 of file LoadState.cxx.
127{
128 // DEBTRACE("graphParser::init()");
130 _father = father;
131 _stackState.push(_state);
132 if (p) getAttributes(p);
133}
Definition: LoadState.hxx:98
Definition: LoadState.hxx:83
Proc * p
Definition: driver.cxx:216
References xmlParserBase::_father, YACS::ENGINE::stateParser::_stackState, YACS::ENGINE::stateParser::_state, xmlParserBase::getAttributes(), p, and YACS::ENGINE::XMLINGRAPH.
◆ onEnd()
void graphParser::onEnd ( const XML_Char *  name)
Definition at line 155 of file LoadState.cxx.
156{
157 std::map<std::string, YACS::StatesForNode>::const_iterator it;
158 for (it = _nodeStates.begin(); it != _nodeStates.end(); it++)
159 {
160 Node *node =0;
161 string nodeName = it->first;
162 DEBTRACE("nodeName = " << nodeName);
163 if(_p->getName() == nodeName)
164 node = _p;
165 else
166 node = _p->getChildByName(nodeName);
167
168 InGate* inGate = node->getInGate();
169 list<OutGate*> backlinks = inGate->getBackLinks();
170 for (list<OutGate*>::iterator io = backlinks.begin(); io != backlinks.end(); io++)
171 {
172 Node* fromNode = (*io)->getNode();
173 string fromName;
174 if (fromNode == _p) fromName = fromNode->getName();
175 else fromName = _p->getChildName(fromNode);
176 if (_nodeStates[fromName] == YACS::DONE)
177 {
178 DEBTRACE(" fromNode = " << fromName);
179 inGate->setPrecursorDone(*io);
180 }
181 }
182 }
183 stateParser::onEnd(name);
184}
std::string getName() const
void setPrecursorDone(OutGate *fromgate)
Definition: InGate.cxx:142
std::list< OutGate * > getBackLinks()
Definition: InGate.cxx:134
Base class for all nodes.
Definition: Node.hxx:70
Definition: Node.hxx:125
InGate * getInGate()
Definition: Node.hxx:123
Definition: LoadState.cxx:111
Definition: LoadState.hxx:102
@ DONE
Definition: define.hxx:43
References YACS::ENGINE::stateParser::_nodeStates, YACS::ENGINE::stateParser::_p, DEBTRACE, YACS::DONE, YACS::ENGINE::InGate::getBackLinks(), YACS::ENGINE::ComposedNode::getChildByName(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Node::getInGate(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::stateParser::onEnd(), and YACS::ENGINE::InGate::setPrecursorDone().
◆ onStart()
void graphParser::onStart ( const XML_Char *  elem,
const xmlChar **  p
Definition at line 135 of file LoadState.cxx.
136{
137 string element(elem);
138 stateParser *parser = 0;
139 if (element == "node") parser = new nodeParser();
140 else
141 {
142 _what = "expected <node>, got <" + element + ">";
145 }
146 if (parser)
147 {
148 _stackParser.push(parser);
150 parser->init(p, this);
151 }
152}
specialized parser to load SALOME execution saved states.
Definition: LoadState.hxx:81
virtual void init(const xmlChar **p, xmlParserBase *father=0)
Definition: LoadState.cxx:65
Definition: LoadState.hxx:84
static void XML_SetUserData(_xmlParserCtxt *ctxt, xmlParserBase *parser)
virtual void stopParse(std::string what)
References xmlParserBase::_stackParser, YACS::ENGINE::stateParser::_state, YACS::ENGINE::stateParser::_what, xmlParserBase::_xmlParser, YACS::parser::init(), p, xmlParserBase::stopParse(), xmlParserBase::XML_SetUserData(), and YACS::ENGINE::XMLFATALERROR.
