YACS::ENGINE::loopPortParser Class Reference
#include <LoadState.hxx>
Inheritance diagram for YACS::ENGINE::loopPortParser:
Collaboration diagram for YACS::ENGINE::loopPortParser:
virtual void init (const xmlChar **p, xmlParserBase *father=0)
virtual void onStart (const XML_Char *elem, const xmlChar **p)
virtual void onEnd (const XML_Char *name)
virtual void charData (std::string data)
void addSample (int index, const std::string data)
unsigned int getNbSamples () const
unsigned int getSampleId (unsigned int i) const
const std::string & getSampleData (unsigned int i) const
const std::string & getPortName () const
- Public Member Functions inherited from xmlParserBase
void setAttribute (std::string key, std::string value)
std::string getAttribute (std::string key)
virtual void addData (std::string value)
std::vector< unsigned int > _ids
std::vector< std::string > _sampleData
- Static Public Member Functions inherited from YACS::ENGINE::stateParser
static void setProc (Proc *p)
static void setRuntime (Runtime *runtime)
- Static Public Member Functions inherited from xmlParserBase
static void XMLCALL start_document (void *userData)
static void XMLCALL end_document (void *userData)
static void XMLCALL start_element (void *userData, const xmlChar *name, const xmlChar **p)
static void XMLCALL end_element (void *userData, const xmlChar *name)
static void XMLCALL characters (void *userData, const xmlChar *ch, int len)
static void XMLCALL comment (void *userData, const xmlChar *value)
static void XMLCALL warning (void *userData, const char *fmt,...)
static void XMLCALL error (void *userData, const char *fmt,...)
static void XMLCALL fatal_error (void *userData, const char *fmt,...)
static void XMLCALL cdata_block (void *userData, const xmlChar *value, int len)
static void cleanGarbage ()
static int getGarbageSize ()
static void XML_SetUserData (_xmlParserCtxt *ctxt, xmlParserBase *parser)
- Public Attributes inherited from xmlParserBase
std::map< std::string, int > counts
- Static Public Attributes inherited from YACS::ENGINE::stateParser
static XMLReadState _state
static std::string _what
- Static Public Attributes inherited from xmlParserBase
static _xmlParserCtxt * _xmlParser
static std::stack< xmlParserBase * > _stackParser
- Protected Member Functions inherited from xmlParserBase
void getAttributes (const xmlChar **p)
virtual void end ()
virtual void stopParse (std::string what)
- Protected Attributes inherited from xmlParserBase
std::map< std::string, std::string > _mapAttrib
std::string _data
xmlParserBase * _father
- Static Protected Attributes inherited from YACS::ENGINE::stateParser
static std::stack< XMLReadState > _stackState
static Proc * _p
static Runtime * _runtime
static std::map< std::string, YACS::StatesForNode > _nodeStateValue
static std::map< std::string, YACS::StatesForNode > _nodeStates
- Static Protected Attributes inherited from xmlParserBase
static std::list< xmlParserBase * > _garbage
Definition at line 186 of file LoadState.hxx.
◆ addSample()
void loopPortParser::addSample ( int  index,
Definition at line 826 of file LoadState.cxx.
827{
828 _ids.push_back(index);
829 _sampleData.push_back(data);
830}
Definition: LoadState.hxx:200
Definition: LoadState.hxx:199
References _ids, and _sampleData.
Referenced by YACS::ENGINE::sampleParser::onEnd().
◆ charData()
void loopPortParser::charData ( std::string  data)
to be specialized following the kind of xml tag
Reimplemented from YACS::ENGINE::stateParser.
Definition at line 822 of file LoadState.cxx.
823{
824}
◆ getNbSamples()
unsigned int loopPortParser::getNbSamples ( ) const
Definition at line 832 of file LoadState.cxx.
833{
834 return _ids.size();
835}
References _ids.
◆ getPortName()
const std::string & loopPortParser::getPortName ( ) const
Definition at line 847 of file LoadState.cxx.
848{
849 return _mapAttrib.at("name");
850}
References xmlParserBase::_mapAttrib.
◆ getSampleData()
const std::string & loopPortParser::getSampleData ( unsigned int  i) const
Definition at line 842 of file LoadState.cxx.
843{
844 return _sampleData[i];
845}
References _sampleData, and yacsorb.CORBAEngineTest::i.
◆ getSampleId()
unsigned int loopPortParser::getSampleId ( unsigned int  i) const
Definition at line 837 of file LoadState.cxx.
838{
839 return _ids[i];
840}
References _ids, and yacsorb.CORBAEngineTest::i.
◆ init()
void loopPortParser::init ( const xmlChar **  p,
xmlParserBase *  father = 0
all parsers must know their father parser (father tag), in order to set values or attributes in father.
Definition at line 785 of file LoadState.cxx.
786{
787 DEBTRACE("loopPortParser::init()");
788 //_state = XMLINPORT;
789 _father = father;
790 _stackState.push(_state);
791 _ids.clear();
792 _sampleData.clear();
793 if (p) getAttributes(p);
794}
Definition: LoadState.hxx:98
Definition: LoadState.hxx:83
Proc * p
Definition: driver.cxx:216
References xmlParserBase::_father, _ids, _sampleData, YACS::ENGINE::stateParser::_stackState, YACS::ENGINE::stateParser::_state, DEBTRACE, xmlParserBase::getAttributes(), and p.
◆ onEnd()
void loopPortParser::onEnd ( const XML_Char *  name)
Definition at line 817 of file LoadState.cxx.
818{
819 stateParser::onEnd(name);
820}
Definition: LoadState.cxx:111
References YACS::ENGINE::stateParser::onEnd().
◆ onStart()
void loopPortParser::onStart ( const XML_Char *  elem,
const xmlChar **  p
Definition at line 796 of file LoadState.cxx.
797{
798 DEBTRACE("loopPortParser::onStart" << elem);
799 string element(elem);
800 stateParser *parser = 0;
801 if (element == "name") parser = new attrParser();
802 else if (element == "sample") parser = new sampleParser(this);
803 else
804 {
805 _what = "expected name or sample, got <" + element + ">";
808 }
809 if (parser)
810 {
811 _stackParser.push(parser);
813 parser->init(p, this);
814 }
815}
specialized parser to load SALOME execution saved states.
Definition: LoadState.hxx:81
virtual void init(const xmlChar **p, xmlParserBase *father=0)
Definition: LoadState.cxx:65
Definition: LoadState.hxx:84
static void XML_SetUserData(_xmlParserCtxt *ctxt, xmlParserBase *parser)
virtual void stopParse(std::string what)
References xmlParserBase::_stackParser, YACS::ENGINE::stateParser::_state, YACS::ENGINE::stateParser::_what, xmlParserBase::_xmlParser, DEBTRACE, YACS::parser::init(), p, xmlParserBase::stopParse(), xmlParserBase::XML_SetUserData(), and YACS::ENGINE::XMLFATALERROR.
◆ _ids
std::vector<unsigned int> YACS::ENGINE::loopPortParser::_ids
Definition at line 199 of file LoadState.hxx.
Referenced by addSample(), getNbSamples(), getSampleId(), and init().
◆ _sampleData
std::vector<std::string> YACS::ENGINE::loopPortParser::_sampleData
Definition at line 200 of file LoadState.hxx.
Referenced by addSample(), getSampleData(), and init().
