Scalar Bar properties
In this dialog you can specify the properties of the scalar bar
Scalar Range - in this menu you can specify Min value and Max value of the Scalar Bar, and turn on/off Logarithmic scaling of the scalar bar.
Logarithmic scale is not applicable in case of negative and zero values in the range. In such cases it is disabled.
Font - in this menu you can set type, face and color for the font of Title and Labels of the Scalar Bar
Colors & Labels - in this menu you can set the number of colors and the number of labels of the Scalar Bar
Orientation - allows choosing between vertical and horizontal orientation of the Scalar Bar.
- Origin & Size Vertical & Horizontal - allows defining the location (X and Y) and size (Width and Height) of Scalar Bar
X: abscissa of the origin (from the left side)
Y: ordinate of the origin (from the bottom)
- Distribution - in this menu you can Show/Hide distribution histogram of the values of the Scalar Bar and specify histogram properties
Multicolor the histogram is colored as Scalar Bar
Monocolor the histogram is colored as selected with Distribution color selector
