SVTK_View Class Reference
This class is introduced just for compatibility with old code. More...
#include <SVTK_View.h>
Inheritance diagram for SVTK_View:
 SVTK_View (SVTK_ViewWindow *theMainWindow)
virtual ~SVTK_View ()
void highlight (const Handle(SALOME_InteractiveObject)&IObject, bool highlight, bool immediatly=true)
 To highlight a VTK presentation with the same SALOME_InteractiveObject. More...
void unHighlightAll ()
 To unhighlight all VTK presentations. More...
 Handle (SALOME_InteractiveObject) FindIObject(const char *Entry)
 Try to find a SALOME_InteractiveObject in the view that corresponds to the entry. More...
bool isInViewer (const Handle(SALOME_InteractiveObject)&IObject)
 Check, if the viewer contains a presentatin with defined SALOME_InteractiveObject. More...
bool isVisible (const Handle(SALOME_InteractiveObject)&IObject)
 Check, if a presentatin with defined SALOME_InteractiveObject is visible. More...
void rename (const Handle(SALOME_InteractiveObject)&IObject, const QString &newName)
int GetDisplayMode ()
 Get current display mode (obsolete) More...
void SetDisplayMode (int)
 Set current display mode. More...
void SetDisplayMode (const Handle(SALOME_InteractiveObject)&IObject, int theMode)
 Switch representation wireframe/shading. More...
void ChangeRepresentationToWireframe ()
 Change all actors to wireframe. More...
void ChangeRepresentationToSurface ()
 Change all actors to surface. More...
void ChangeRepresentationToSurfaceWithEdges ()
 Change all actors to surface with edges. More...
void ChangeRepresentationToWireframe (vtkActorCollection *theListofActors)
 Change to wireframe a list of vtkactor. More...
void ChangeRepresentationToSurface (vtkActorCollection *theListofActors)
 Change to surface a list of vtkactor. More...
void ChangeRepresentationToSurfaceWithEdges (vtkActorCollection *theListofActors)
 Change to surface with edges a list of vtkactor. More...
void SetTransparency (const Handle(SALOME_InteractiveObject)&theIObject, float trans)
 Change transparency. More...
float GetTransparency (const Handle(SALOME_InteractiveObject)&theIObject)
 Get current transparency. More...
void SetColor (const Handle(SALOME_InteractiveObject)&theIObject, const QColor &theColor)
 Change color. More...
QColor GetColor (const Handle(SALOME_InteractiveObject)&theIObject)
 Get current color. More...
void SetMaterial (const Handle(SALOME_InteractiveObject)&theIObject, vtkProperty *thePropF, vtkProperty *thePropB)
 Change material. More...
vtkProperty * GetFrontMaterial (const Handle(SALOME_InteractiveObject)&theIObject)
 Get current front material. More...
vtkProperty * GetBackMaterial (const Handle(SALOME_InteractiveObject)&theIObject)
 Get current back material. More...
void EraseAll ()
 To erase all existing VTK presentations. More...
void DisplayAll ()
 To display all existing VTK presentations. More...
void RemoveAll (const bool immediatly)
 To remove from the view all existing VTK presentations. More...
void Erase (const Handle(SALOME_InteractiveObject)&IObject, bool immediatly=true)
 To erase VTK presentation with defined SALOME_InteractiveObject. More...
void Remove (const Handle(SALOME_InteractiveObject)&IObject, bool immediatly=true)
void Display (const Handle(SALOME_InteractiveObject)&IObject, bool immediatly=true)
 To display VTK presentation with defined SALOME_InteractiveObject. More...
void DisplayOnly (const Handle(SALOME_InteractiveObject)&IObject)
 To display VTK presentation with defined SALOME_InteractiveObject and erase all anothers. More...
void Display (SALOME_Actor *SActor, bool immediatly=true)
 To display the VTK presentation. More...
void Erase (SALOME_Actor *SActor, bool immediatly=true)
 To erase the VTK presentation. More...
void Remove (SALOME_Actor *SActor, bool updateViewer=true)
 To remove the VTK presentation. More...
void GetVisible (SALOME_ListIO &theList)
 Collect objects visible in viewer. More...
void SetSelectionProp (const double &theRed=1, const double &theGreen=1, const double &theBlue=0, const int &theWidth=5)
 Redirect the request to SVTK_Renderer::SetPreselectionProp. More...
void SetPreselectionProp (const double &theRed=0, const double &theGreen=1, const double &theBlue=1, const int &theWidth=5)
void SetSelectionTolerance (const double &theTolNodes=0.025, const double &theTolCell=0.001, const double &theTolObjects=0.025)
- Public Member Functions inherited from SVTK_SignalHandler
 SVTK_SignalHandler (SVTK_ViewWindow *theMainWindow)
virtual ~SVTK_SignalHandler ()
SVTK_ViewWindow * GetMainWindow ()
 Get reference to its SVTK_ViewWindow. More...
void Repaint (bool theUpdateTrihedron=true)
 Redirect the request to SVTK_ViewWindow::Repaint (just for flexibility) More...
SVTK_Renderer * GetRenderer ()
 Redirect the request to SVTK_ViewWindow::GetRenderer (just for flexibility) More...
vtkRenderer * getRenderer ()
 Redirect the request to SVTK_ViewWindow::getRenderer (just for flexibility) More...
int myDisplayMode
- Protected Attributes inherited from SVTK_SignalHandler
SVTK_ViewWindow * myMainWindow
- Public Slots inherited from SVTK_SignalHandler
void onSelectionChanged ()
- Signals inherited from SVTK_SignalHandler
void MouseMove (QMouseEvent *)
void MouseButtonPressed (QMouseEvent *)
void MouseButtonReleased (QMouseEvent *)
void MouseDoubleClicked (QMouseEvent *)
void ButtonPressed (const QMouseEvent *event)
void ButtonReleased (const QMouseEvent *event)
void WheelMoved (QWheelEvent *)
void KeyPressed (QKeyEvent *)
void KeyReleased (QKeyEvent *)
void contextMenuRequested (QContextMenuEvent *e)
void selectionChanged ()
This class contains frequantly used functionality in old code. Now, you are supposed to extend existing functionality through writing corresponding functors (see SVTK_Functor.h for example).
◆ SVTK_View()
SVTK_View::SVTK_View ( SVTK_ViewWindow *  theMainWindow)
Constructor
◆ ~SVTK_View()
SVTK_View::~SVTK_View ( )
Destructor
◆ ChangeRepresentationToSurface() [1/2]
void SVTK_View::ChangeRepresentationToSurface ( )
Change all actors to shading
References ChangeRepresentationToSurface(), VTK::ActorCollectionCopy::GetActors(), and SVTK_SignalHandler::getRenderer().
◆ ChangeRepresentationToSurface() [2/2]
void SVTK_View::ChangeRepresentationToSurface ( vtkActorCollection *  theCollection)
Change to shading a list of vtkactor theCollection - list of vtkactor
References SVTK_SignalHandler::Repaint(), and VTKViewer_Actor::setDisplayMode().
◆ ChangeRepresentationToSurfaceWithEdges() [1/2]
void SVTK_View::ChangeRepresentationToSurfaceWithEdges ( )
Change all actors to shading with edges
References ChangeRepresentationToSurfaceWithEdges(), VTK::ActorCollectionCopy::GetActors(), and SVTK_SignalHandler::getRenderer().
◆ ChangeRepresentationToSurfaceWithEdges() [2/2]
void SVTK_View::ChangeRepresentationToSurfaceWithEdges ( vtkActorCollection *  theCollection)
Change to shading with edges a list of vtkactor theCollection - list of vtkactor
◆ ChangeRepresentationToWireframe() [1/2]
void SVTK_View::ChangeRepresentationToWireframe ( )
References ChangeRepresentationToWireframe(), VTK::ActorCollectionCopy::GetActors(), and SVTK_SignalHandler::getRenderer().
◆ ChangeRepresentationToWireframe() [2/2]
void SVTK_View::ChangeRepresentationToWireframe ( vtkActorCollection *  theCollection)
Change to wireframe a list of vtkactor theCollection - list of vtkactor
◆ Display() [1/2]
void SVTK_View::Display ( const Handle(SALOME_InteractiveObject)&  theIObject,
bool  theIsUpdate = true
References VTK::ActorCollectionCopy::GetActors(), SVTK_SignalHandler::getRenderer(), and SVTK_SignalHandler::Repaint().
◆ Display() [2/2]
void SVTK_View::Display ( SALOME_Actor *  theActor,
References SVTK_Renderer::AddActor(), SVTK_SignalHandler::GetRenderer(), SVTK_SignalHandler::Repaint(), and SALOME_Actor::SetVisibility().
◆ DisplayAll()
void SVTK_View::DisplayAll ( )
◆ DisplayOnly()
void SVTK_View::DisplayOnly ( const Handle(SALOME_InteractiveObject)&  theIObject)
To display VTK presentation with defined SALOME_InteractiveObject and erase all others
References Display(), and EraseAll().
◆ Erase() [1/2]
void SVTK_View::Erase ( const Handle(SALOME_InteractiveObject)&  theIObject,
theIObject- object
theIsUpdate- updates current viewer
◆ Erase() [2/2]
void SVTK_View::Erase ( SALOME_Actor *  theActor,
theActor- actor
References SVTK_SignalHandler::Repaint().
◆ EraseAll()
void SVTK_View::EraseAll ( )
◆ GetBackMaterial()
vtkProperty * SVTK_View::GetBackMaterial ( const Handle(SALOME_InteractiveObject)&  theIObject)
theIObject- object
property contained back material properties of the given object
References VTK::ActorCollectionCopy::GetActors(), VTKViewer_Actor::GetBackMaterial(), and SVTK_SignalHandler::getRenderer().
◆ GetColor()
QColor SVTK_View::GetColor ( const Handle(SALOME_InteractiveObject)&  theIObject)
Get current color.
object color
theIObject- object
References VTK::ActorCollectionCopy::GetActors(), VTKViewer_Actor::GetColor(), and SVTK_SignalHandler::getRenderer().
◆ GetDisplayMode()
int SVTK_View::GetDisplayMode ( )
References myDisplayMode.
◆ GetFrontMaterial()
vtkProperty * SVTK_View::GetFrontMaterial ( const Handle(SALOME_InteractiveObject)&  theIObject)
theIObject- object
property contained front material properties of the given object
References VTK::ActorCollectionCopy::GetActors(), VTKViewer_Actor::GetFrontMaterial(), and SVTK_SignalHandler::getRenderer().
◆ GetTransparency()
float SVTK_View::GetTransparency ( const Handle(SALOME_InteractiveObject)&  theIObject)
theIObject- object
References VTK::ActorCollectionCopy::GetActors(), VTKViewer_Actor::GetOpacity(), and SVTK_SignalHandler::getRenderer().
◆ GetVisible()
void SVTK_View::GetVisible ( SALOME_ListIO &  theList)
\Collect objects visible in viewer
theList- visible objects collection
References VTK::ActorCollectionCopy::GetActors(), and SVTK_SignalHandler::getRenderer().
◆ Handle()
SVTK_View::Handle ( SALOME_InteractiveObject  ) const
◆ highlight()
void SVTK_View::highlight ( const Handle(SALOME_InteractiveObject)&  theIO,
bool  theIsHighlight,
bool  immediatly = true
Hilights/unhilights object in viewer
theIO- object to be updated
theIsHighlight- if it is true, object will be hilighted, otherwise it will be unhilighted
theIsUpdate- update current viewer
◆ isInViewer()
bool SVTK_View::isInViewer ( const Handle(SALOME_InteractiveObject)&  theIObject)
true if object is in viewer or in collector
theIO- object to be checked
◆ isVisible()
bool SVTK_View::isVisible ( const Handle(SALOME_InteractiveObject)&  theIObject)
true if object is displayed in viewer
◆ Remove() [1/2]
void SVTK_View::Remove ( const Handle(SALOME_InteractiveObject)&  theIObject,
◆ Remove() [2/2]
void SVTK_View::Remove ( SALOME_Actor *  theActor,
References SVTK_SignalHandler::GetRenderer(), SVTK_Renderer::RemoveActor(), and SVTK_SignalHandler::Repaint().
◆ RemoveAll()
void SVTK_View::RemoveAll ( const bool  immediatly)
To remove all VTK presentations
◆ rename()
void SVTK_View::rename ( const Handle(SALOME_InteractiveObject)&  theIObject,
const QString &  theName
Changes name of object
theIObject- object to be renamed
theName- new name
References VTK::ActorCollectionCopy::GetActors(), SVTK_SignalHandler::getRenderer(), and SALOME_Actor::setName().
◆ SetColor()
void SVTK_View::SetColor ( const Handle(SALOME_InteractiveObject)&  theIObject,
const QColor &  theColor
Change color.
Change color
theIObject- object
theColor- new color
References VTK::ActorCollectionCopy::GetActors(), SVTK_SignalHandler::getRenderer(), and VTKViewer_Actor::SetColor().
◆ SetDisplayMode() [1/2]
void SVTK_View::SetDisplayMode ( const Handle(SALOME_InteractiveObject)&  theIObject,
int  theMode
theIObject- object
theMode- new display mode
References VTK::ActorCollectionCopy::GetActors(), SVTK_SignalHandler::getRenderer(), and VTKViewer_Actor::setDisplayMode().
◆ SetDisplayMode() [2/2]
void SVTK_View::SetDisplayMode ( int  theMode)
References ChangeRepresentationToSurface(), ChangeRepresentationToSurfaceWithEdges(), ChangeRepresentationToWireframe(), and myDisplayMode.
◆ SetMaterial()
void SVTK_View::SetMaterial ( const Handle(SALOME_InteractiveObject)&  theIObject,
vtkProperty *  thePropF,
vtkProperty *  thePropB
Change material.
Change material
theIObject- object
thePropF- property contained new properties of front material
thePropB- property contained new properties of back material
References VTK::ActorCollectionCopy::GetActors(), SVTK_SignalHandler::getRenderer(), and VTKViewer_Actor::SetMaterial().
◆ SetPreselectionProp()
void SVTK_View::SetPreselectionProp ( const double &  theRed = 0,
const double &  theGreen = 1,
const double &  theBlue = 1,
const int &  theWidth = 5
◆ SetSelectionProp()
void SVTK_View::SetSelectionProp ( const double &  theRed = 1,
const double &  theBlue = 0,
◆ SetSelectionTolerance()
void SVTK_View::SetSelectionTolerance ( const double &  theTolNodes = 0.025,
const double &  theTolCell = 0.001,
const double &  theTolObjects = 0.025
◆ SetTransparency()
void SVTK_View::SetTransparency ( const Handle(SALOME_InteractiveObject)&  theIObject,
float  theTrans
Sets current transparency
theIObject- object
theTrans- new transparency
References VTK::ActorCollectionCopy::GetActors(), SVTK_SignalHandler::getRenderer(), and VTKViewer_Actor::SetOpacity().
◆ unHighlightAll()
void SVTK_View::unHighlightAll ( )
Unhilights all objects in viewer
◆ myDisplayMode
int SVTK_View::myDisplayMode
