CollectionAPI_Field.h
20#ifndef CollectionAPI_Field_H_
21#define CollectionAPI_Field_H_
23#include "CollectionAPI.h"
24
25#include <CollectionPlugin_Field.h>
26
33class ModelHighAPI_ComponentValue;
34
39{
40public:
42 COLLECTIONAPI_EXPORT
43 explicit CollectionAPI_Field(const std::shared_ptr<ModelAPI_Feature>& theFeature);
44
46 COLLECTIONAPI_EXPORT
47 virtual ~CollectionAPI_Field();
48
49 INTERFACE_4(CollectionPlugin_Field::ID(),
57 )
58
59
60 COLLECTIONAPI_EXPORT
61 void setSelection(const std::list<ModelHighAPI_Selection>& theFieldList);
63 COLLECTIONAPI_EXPORT
64 void setComponentsNames(const std::list<std::string>& theNames);
66 COLLECTIONAPI_EXPORT
67 void setValuesType(const std::string& theType);
69 COLLECTIONAPI_EXPORT
70 void setStepsNum(const ModelHighAPI_Integer& theSteps);
72 COLLECTIONAPI_EXPORT
73 void setStamps(const std::list<ModelHighAPI_Integer>& theStamps);
75 COLLECTIONAPI_EXPORT
76 void addStep(const ModelHighAPI_Integer& theStepNum, const ModelHighAPI_Integer& theStamp,
77 const std::list<std::list<double> >& theComponents);
79 COLLECTIONAPI_EXPORT
80 void addStep(const ModelHighAPI_Integer& theStepNum, const ModelHighAPI_Integer& theStamp,
81 const std::list<std::list<int> >& theComponents);
83 COLLECTIONAPI_EXPORT
84 void addStep(const ModelHighAPI_Integer& theStepNum, const ModelHighAPI_Integer& theStamp,
85 const std::list<std::list<std::string> >& theComponents);
87 COLLECTIONAPI_EXPORT
88 void addStep(const ModelHighAPI_Integer& theStepNum, const ModelHighAPI_Integer& theStamp,
89 const std::list<std::list<bool> >& theComponents);
90
92 COLLECTIONAPI_EXPORT
93 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
94
96 COLLECTIONAPI_EXPORT
97 std::shared_ptr<ModelAPI_AttributeTables> tableValues();
98
99};
100
102typedef std::shared_ptr<CollectionAPI_Field> FieldPtr;
103
106COLLECTIONAPI_EXPORT
107FieldPtr addField(const std::shared_ptr<ModelAPI_Document>& thePart,
108 const ModelHighAPI_Integer& theStepsNum,
109 const std::string& theComponentType,
110 const int theComponentsNum,
111 const std::list<std::string>& theComponentNames,
112 const std::list<ModelHighAPI_Selection>& theSelectionList);
113
114#endif // CollectionAPI_Field_H_
\inField CPPHighAPI
Definition: CollectionAPI_Field.h:39
CollectionAPI_Field(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: CollectionAPI_Field.cpp:32
std::shared_ptr< ModelAPI_AttributeTables > tableValues()
Returns the internal values tables.
Definition: CollectionAPI_Field.cpp:148
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > selection() const
Field selection list.
Definition: CollectionAPI_Field.h:57
void setValuesType(const std::string &theType)
Set type of values.
Definition: CollectionAPI_Field.cpp:58
virtual std::shared_ptr< ModelAPI_AttributeIntArray > stamps() const
Identifiers of stamps.
virtual std::shared_ptr< ModelAPI_AttributeStringArray > componentsNames() const
Names of components list of strings.
void addStep(const ModelHighAPI_Integer &theStepNum, const ModelHighAPI_Integer &theStamp, const std::list< std::list< double > > &theComponents)
Sets the double values of specific step.
Definition: CollectionAPI_Field.cpp:102
void setStamps(const std::list< ModelHighAPI_Integer > &theStamps)
Set stamps identifiers.
Definition: CollectionAPI_Field.cpp:72
Dump wrapped feature.
Definition: CollectionAPI_Field.cpp:108
void setComponentsNames(const std::list< std::string > &theNames)
Set names of components.
Definition: CollectionAPI_Field.cpp:51
void setSelection(const std::list< ModelHighAPI_Selection > &theFieldList)
Set selected objects.
Definition: CollectionAPI_Field.cpp:44
void setStepsNum(const ModelHighAPI_Integer &theSteps)
Set number of steps.
Definition: CollectionAPI_Field.cpp:65
Definition: CollectionAPI_Field.cpp:39
static const std::string & SELECTED_ID()
attribute name of selected entities list
Definition: CollectionPlugin_Field.h:52
static const std::string & COMPONENTS_NAMES_ID()
attribute name of components titles array
Definition: CollectionPlugin_Field.h:58
static const std::string & STAMPS_ID()
attribute name of stamps integer array
Definition: CollectionPlugin_Field.h:64
Feature kind.
Definition: CollectionPlugin_Field.h:46
static const std::string & VALUES_ID()
attribute name of list of tables that contain default values (row 0) and the custom values
Definition: CollectionPlugin_Field.h:70
API for the attribute that contains several integers in the array inside.
Definition: ModelAPI_AttributeIntArray.h:36
API for the attribute that contains several strings in the array inside.
Definition: ModelAPI_AttributeStringArray.h:32
API for the attribute that contains tables of some values type.
Definition: ModelAPI_AttributeTables.h:39
Dump engine for the model.
Class for filling ModelAPI_AttributeInteger.
Definition: ModelHighAPI_Integer.h:36
