CollectionAPI_Field Class Reference
\inField CPPHighAPI More...
#include <CollectionAPI_Field.h>
Inheritance diagram for CollectionAPI_Field:
 CollectionAPI_Field (const std::shared_ptr< ModelAPI_Feature > &theFeature)
virtual ~CollectionAPI_Field ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > selection () const
 Field selection list. More...
virtual std::shared_ptr< ModelAPI_AttributeStringArray > componentsNames () const
 Names of components list of strings. More...
virtual std::shared_ptr< ModelAPI_AttributeIntArray > stamps () const
 Identifiers of stamps. More...
virtual std::shared_ptr< ModelAPI_AttributeTables > values () const
void setSelection (const std::list< ModelHighAPI_Selection > &theFieldList)
 Set selected objects. More...
void setComponentsNames (const std::list< std::string > &theNames)
 Set names of components. More...
void setValuesType (const std::string &theType)
 Set type of values. More...
void setStepsNum (const ModelHighAPI_Integer &theSteps)
 Set number of steps. More...
void setStamps (const std::list< ModelHighAPI_Integer > &theStamps)
 Set stamps identifiers. More...
void addStep (const ModelHighAPI_Integer &theStepNum, const ModelHighAPI_Integer &theStamp, const std::list< std::list< double > > &theComponents)
 Sets the double values of specific step. More...
void addStep (const ModelHighAPI_Integer &theStepNum, const ModelHighAPI_Integer &theStamp, const std::list< std::list< int > > &theComponents)
 Sets the integer values of specific step. More...
void addStep (const ModelHighAPI_Integer &theStepNum, const ModelHighAPI_Integer &theStamp, const std::list< std::list< std::string > > &theComponents)
 Sets the string values of specific step. More...
void addStep (const ModelHighAPI_Integer &theStepNum, const ModelHighAPI_Integer &theStamp, const std::list< std::list< bool > > &theComponents)
 Sets the boolean values of specific step. More...
 Dump wrapped feature. More...
std::shared_ptr< ModelAPI_AttributeTables > tableValues ()
 Returns the internal values tables. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > myselection
std::shared_ptr< ModelAPI_AttributeStringArray > mycomponentsNames
std::shared_ptr< ModelAPI_AttributeIntArray > mystamps
std::shared_ptr< ModelAPI_AttributeTables > myvalues
\inField CPPHighAPI
Interface for Field feature.
◆ CollectionAPI_Field()
CollectionAPI_Field::CollectionAPI_Field ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ ~CollectionAPI_Field()
CollectionAPI_Field::~CollectionAPI_Field ( )
◆ selection()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > CollectionAPI_Field::selection ( ) const
◆ componentsNames()
virtual std::shared_ptr< ModelAPI_AttributeStringArray > CollectionAPI_Field::componentsNames ( ) const
◆ stamps()
virtual std::shared_ptr< ModelAPI_AttributeIntArray > CollectionAPI_Field::stamps ( ) const
◆ initialize()
bool CollectionAPI_Field::initialize ( )
inlineprotected
Table of values
◆ setSelection()
void CollectionAPI_Field::setSelection ( const std::list< ModelHighAPI_Selection > &  theFieldList)
◆ setComponentsNames()
void CollectionAPI_Field::setComponentsNames ( const std::list< std::string > &  theNames)
◆ setValuesType()
void CollectionAPI_Field::setValuesType ( const std::string &  theType)
Set type of values.
◆ setStepsNum()
void CollectionAPI_Field::setStepsNum ( const ModelHighAPI_Integer &  theSteps)
◆ setStamps()
void CollectionAPI_Field::setStamps ( const std::list< ModelHighAPI_Integer > &  theStamps)
◆ addStep() [1/4]
void CollectionAPI_Field::addStep ( const ModelHighAPI_Integer &  theStepNum,
const ModelHighAPI_Integer &  theStamp,
const std::list< std::list< double > > &  theComponents
◆ addStep() [2/4]
const std::list< std::list< int > > &  theComponents
◆ addStep() [3/4]
const std::list< std::list< std::string > > &  theComponents
◆ addStep() [4/4]
const std::list< std::list< bool > > &  theComponents
◆ dump()
void CollectionAPI_Field::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ tableValues()
std::shared_ptr< ModelAPI_AttributeTables > CollectionAPI_Field::tableValues ( )
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
