20#ifndef FeaturesAPI_BooleanFuse_H_
21#define FeaturesAPI_BooleanFuse_H_
23#include "FeaturesAPI.h"
25#include <FeaturesPlugin_BooleanFuse.h>
29#include <ModelHighAPI_Double.h>
47 const std::list<ModelHighAPI_Selection>& theMainObjects,
48 const bool theRemoveEdges =
false,
54 const std::list<ModelHighAPI_Selection>& theMainObjects,
55 const std::list<ModelHighAPI_Selection>& theToolObjects,
56 const bool theRemoveEdges =
false,
109#define DUMMY_TOOLS std::pair<std::list<ModelHighAPI_Selection>, bool>\
110 (std::list<ModelHighAPI_Selection>(), false)
114FEATURESAPI_EXPORT BooleanFusePtr
addFuse(
115 const std::shared_ptr<ModelAPI_Document>& part,
116 const std::list<ModelHighAPI_Selection>& objects,
117 const std::pair<std::list<ModelHighAPI_Selection>,
bool>& tools = DUMMY_TOOLS,
120 const bool keepSubResults =
false);
Interface for Boolean Fuse feature.
Definition: FeaturesAPI_BooleanFuse.h:38
virtual ~FeaturesAPI_BooleanFuse()
Definition: FeaturesAPI_BooleanFuse.cpp:93
virtual std::shared_ptr< ModelAPI_AttributeDouble > fuzzyParam() const
Fuzzy parameter.
Definition: FeaturesAPI_BooleanFuse.h:75
void setAdvancedMode(const bool theMode)
Set mode.
Definition: FeaturesAPI_BooleanFuse.cpp:142
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > toolObjects() const
Tool objects.
FeaturesAPI_BooleanFuse(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_BooleanFuse.cpp:31
void setMainObjects(const std::list< ModelHighAPI_Selection > &theMainObjects)
Set main objects.
Definition: FeaturesAPI_BooleanFuse.cpp:99
void setToolObjects(const std::list< ModelHighAPI_Selection > &theToolObjects)
Set tool objects.
Definition: FeaturesAPI_BooleanFuse.cpp:108
void setUseFuzzy(bool theUseFuzzy)
Set use fuzzy parameter.
Definition: FeaturesAPI_BooleanFuse.cpp:126
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects() const
Main objects.
virtual std::shared_ptr< ModelAPI_AttributeBoolean > removeEdges() const
Remove edges.
virtual std::shared_ptr< ModelAPI_AttributeBoolean > useFuzzy() const
Use Fuzzy parameter.
void setFuzzyValue(const ModelHighAPI_Double &theFuzzy)
Set fuzzy parameter.
Definition: FeaturesAPI_BooleanFuse.cpp:134
void setRemoveEdges(const bool theRemoveEdges)
Set remove edges.
Definition: FeaturesAPI_BooleanFuse.cpp:118
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
Dump wrapped feature.
Definition: FeaturesAPI_BooleanFuse.cpp:154
Feature kind.
Definition: FeaturesPlugin_BooleanFuse.h:33
Definition: FeaturesPlugin_BooleanFuse.h:47
static const std::string & REMOVE_INTERSECTION_EDGES_ID()
Attribute name of remove edges option.
Definition: FeaturesPlugin_BooleanFuse.h:82
static const std::string & OBJECT_LIST_ID()
Attribute name of main objects.
Definition: FeaturesPlugin_BooleanFuse.h:68
static const std::string & TOOL_LIST_ID()
Attribute name of tool objects.
Definition: FeaturesPlugin_BooleanFuse.h:75
static const std::string & USE_FUZZY_ID()
Attribute name of use fuzzy parameter.
Definition: FeaturesPlugin_Boolean.h:55
static const std::string & FUZZY_PARAM_ID()
Attribute name of fuzzy parameter.
Definition: FeaturesPlugin_Boolean.h:62
Dump engine for the model.
Class for filling ModelAPI_AttributeInteger.
Definition: ModelHighAPI_Integer.h:36
BooleanFusePtr addFuse(const std::shared_ptr< ModelAPI_Document > &part, const std::list< ModelHighAPI_Selection > &objects, const std::pair< std::list< ModelHighAPI_Selection >, bool > &tools=std::pair< std::list< ModelHighAPI_Selection >, bool >(std::list< ModelHighAPI_Selection >(), false), const bool removeEdges=false, const ModelHighAPI_Double &fuzzyParam=ModelHighAPI_Double(-1), const bool keepSubResults=false)
Create Boolean Fuse feature.
Definition: FeaturesAPI_BooleanFuse.cpp:191
