Interface for Boolean Fuse feature. More...
#include <FeaturesAPI_BooleanFuse.h>
| FeaturesAPI_BooleanFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_BooleanFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const bool theRemoveEdges=false, const ModelHighAPI_Double &theFuzzy=ModelHighAPI_Double(-1)) | |
| FeaturesAPI_BooleanFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const std::list< ModelHighAPI_Selection > &theToolObjects, const bool theRemoveEdges=false, const ModelHighAPI_Double &theFuzzy=ModelHighAPI_Double(-1)) | |
| virtual | ~FeaturesAPI_BooleanFuse () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeString > | creationMethod () const |
| Creation method. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | mainObjects () const |
| Main objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | toolObjects () const |
| Tool objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | removeEdges () const |
| Remove edges. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | useFuzzy () const |
| Use Fuzzy parameter. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | fuzzyParam () const |
| void | setMainObjects (const std::list< ModelHighAPI_Selection > &theMainObjects) |
| Set main objects. More... | |
| void | setToolObjects (const std::list< ModelHighAPI_Selection > &theToolObjects) |
| Set tool objects. More... | |
| void | setRemoveEdges (const bool theRemoveEdges) |
| Set remove edges. More... | |
| void | setUseFuzzy (bool theUseFuzzy) |
| Set use fuzzy parameter. More... | |
| void | setFuzzyValue (const ModelHighAPI_Double &theFuzzy) |
| Set fuzzy parameter. More... | |
| void | setAdvancedMode (const bool theMode) |
| Set mode. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeString > | mycreationMethod |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mymainObjects |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mytoolObjects |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myremoveEdges |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myuseFuzzy |
| std::shared_ptr< ModelAPI_AttributeDouble > | myfuzzyParam |
explicit |
| FeaturesAPI_BooleanFuse::FeaturesAPI_BooleanFuse | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| const std::list< ModelHighAPI_Selection > & | theMainObjects, | ||
| const bool | theRemoveEdges = false, |
| const ModelHighAPI_Double & | theFuzzy = ModelHighAPI_Double(-1) |
| const std::list< ModelHighAPI_Selection > & | theToolObjects, | ||
inlinevirtual |
Creation method.
inlinevirtual |
Main objects.
inlinevirtual |
Tool objects.
inlinevirtual |
Remove edges.
inlinevirtual |
inlinevirtual |
Fuzzy parameter.
| void FeaturesAPI_BooleanFuse::setMainObjects | ( | const std::list< ModelHighAPI_Selection > & | theMainObjects | ) |
Set main objects.
| void FeaturesAPI_BooleanFuse::setToolObjects | ( | const std::list< ModelHighAPI_Selection > & | theToolObjects | ) |
Set tool objects.
| void FeaturesAPI_BooleanFuse::setRemoveEdges | ( | const bool | theRemoveEdges | ) |
Set remove edges.
| void FeaturesAPI_BooleanFuse::setUseFuzzy | ( | bool | theUseFuzzy | ) |
| void FeaturesAPI_BooleanFuse::setFuzzyValue | ( | const ModelHighAPI_Double & | theFuzzy | ) |
| void FeaturesAPI_BooleanFuse::setAdvancedMode | ( | const bool | theMode | ) |
Set mode.
protectedinherited |
