FeaturesAPI_BooleanSmash.h
20#ifndef FeaturesAPI_BooleanSmash_H_
21#define FeaturesAPI_BooleanSmash_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_BooleanSmash.h>
26
29#include <ModelHighAPI_Double.h>
30
33
38{
39public:
41 FEATURESAPI_EXPORT
42 explicit FeaturesAPI_BooleanSmash(const std::shared_ptr<ModelAPI_Feature>& theFeature);
43
45 FEATURESAPI_EXPORT
46 FeaturesAPI_BooleanSmash(const std::shared_ptr<ModelAPI_Feature>& theFeature,
47 const std::list<ModelHighAPI_Selection>& theMainObjects,
48 const std::list<ModelHighAPI_Selection>& theToolObjects,
49 const ModelHighAPI_Double& theFuzzy = ModelHighAPI_Double(-1));
50
52 FEATURESAPI_EXPORT
54
64
65
66 FEATURESAPI_EXPORT
67 void setMainObjects(const std::list<ModelHighAPI_Selection>& theMainObjects);
68
70 FEATURESAPI_EXPORT
71 void setToolObjects(const std::list<ModelHighAPI_Selection>& theToolObjects);
72
74 FEATURESAPI_EXPORT
75 void setUseFuzzy(bool theUseFuzzy);
76
78 FEATURESAPI_EXPORT
79 void setFuzzyValue(const ModelHighAPI_Double& theFuzzy);
80
82 FEATURESAPI_EXPORT
83 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
84};
85
87typedef std::shared_ptr<FeaturesAPI_BooleanSmash> BooleanSmashPtr;
88
91FEATURESAPI_EXPORT
92BooleanSmashPtr addSmash(const std::shared_ptr<ModelAPI_Document>& thePart,
93 const std::list<ModelHighAPI_Selection>& theMainObjects,
94 const std::list<ModelHighAPI_Selection>& theToolObjects,
96 const bool keepSubResults = false);
97
98#endif // FeaturesAPI_BooleanSmash_H_
Interface for Boolean Smash feature.
Definition: FeaturesAPI_BooleanSmash.h:38
Dump wrapped feature.
Definition: FeaturesAPI_BooleanSmash.cpp:104
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > toolObjects() const
Tool objects.
Definition: FeaturesAPI_BooleanSmash.h:63
virtual ~FeaturesAPI_BooleanSmash()
Definition: FeaturesAPI_BooleanSmash.cpp:64
virtual std::shared_ptr< ModelAPI_AttributeDouble > fuzzyParam() const
Fuzzy parameter.
void setToolObjects(const std::list< ModelHighAPI_Selection > &theToolObjects)
Set tool objects.
Definition: FeaturesAPI_BooleanSmash.cpp:79
virtual std::shared_ptr< ModelAPI_AttributeBoolean > useFuzzy() const
Use Fuzzy parameter.
void setFuzzyValue(const ModelHighAPI_Double &theFuzzy)
Set fuzzy parameter.
Definition: FeaturesAPI_BooleanSmash.cpp:96
void setMainObjects(const std::list< ModelHighAPI_Selection > &theMainObjects)
Set main objects.
Definition: FeaturesAPI_BooleanSmash.cpp:70
FeaturesAPI_BooleanSmash(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_BooleanSmash.cpp:31
Set use fuzzy parameter.
Definition: FeaturesAPI_BooleanSmash.cpp:88
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects() const
Main objects.
static const std::string & OBJECT_LIST_ID()
Attribute name of main objects.
Definition: FeaturesPlugin_BooleanSmash.h:49
static const std::string & TOOL_LIST_ID()
Attribute name of tool objects.
Definition: FeaturesPlugin_BooleanSmash.h:56
Feature kind.
Definition: FeaturesPlugin_BooleanSmash.h:35
static const std::string & USE_FUZZY_ID()
Attribute name of use fuzzy parameter.
Definition: FeaturesPlugin_Boolean.h:55
static const std::string & FUZZY_PARAM_ID()
Attribute name of fuzzy parameter.
Definition: FeaturesPlugin_Boolean.h:62
Dump engine for the model.
Class for filling ModelAPI_AttributeInteger.
Definition: ModelHighAPI_Integer.h:36
BooleanSmashPtr addSmash(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theMainObjects, const std::list< ModelHighAPI_Selection > &theToolObjects, const ModelHighAPI_Double &fuzzyParam=ModelHighAPI_Double(-1), const bool keepSubResults=false)
Create Boolean Smash feature.
Definition: FeaturesAPI_BooleanSmash.cpp:130
