Interface for Boolean Smash feature. More...
#include <FeaturesAPI_BooleanSmash.h>
| FeaturesAPI_BooleanSmash (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_BooleanSmash (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const std::list< ModelHighAPI_Selection > &theToolObjects, const ModelHighAPI_Double &theFuzzy=ModelHighAPI_Double(-1)) | |
| virtual | ~FeaturesAPI_BooleanSmash () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | mainObjects () const |
| Main objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | toolObjects () const |
| Tool objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | useFuzzy () const |
| Use Fuzzy parameter. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | fuzzyParam () const |
| void | setMainObjects (const std::list< ModelHighAPI_Selection > &theMainObjects) |
| Set main objects. More... | |
| void | setToolObjects (const std::list< ModelHighAPI_Selection > &theToolObjects) |
| Set tool objects. More... | |
| void | setUseFuzzy (bool theUseFuzzy) |
| Set use fuzzy parameter. More... | |
| void | setFuzzyValue (const ModelHighAPI_Double &theFuzzy) |
| Set fuzzy parameter. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mymainObjects |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mytoolObjects |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myuseFuzzy |
| std::shared_ptr< ModelAPI_AttributeDouble > | myfuzzyParam |
explicit |
| FeaturesAPI_BooleanSmash::FeaturesAPI_BooleanSmash | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| const std::list< ModelHighAPI_Selection > & | theMainObjects, | ||
| const std::list< ModelHighAPI_Selection > & | theToolObjects, | ||
| const ModelHighAPI_Double & | theFuzzy = ModelHighAPI_Double(-1) |
inlinevirtual |
Main objects.
inlinevirtual |
Tool objects.
inlinevirtual |
inlinevirtual |
Fuzzy parameter.
| void FeaturesAPI_BooleanSmash::setMainObjects | ( | const std::list< ModelHighAPI_Selection > & | theMainObjects | ) |
Set main objects.
| void FeaturesAPI_BooleanSmash::setToolObjects | ( | const std::list< ModelHighAPI_Selection > & | theToolObjects | ) |
Set tool objects.
| void FeaturesAPI_BooleanSmash::setUseFuzzy | ( | bool | theUseFuzzy | ) |
| void FeaturesAPI_BooleanSmash::setFuzzyValue | ( | const ModelHighAPI_Double & | theFuzzy | ) |
protectedinherited |
