FeaturesAPI_Intersection.h
20#ifndef FeaturesAPI_Intersection_H_
21#define FeaturesAPI_Intersection_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_Intersection.h>
26
29#include <ModelHighAPI_Double.h>
30
33
38{
39public:
41 FEATURESAPI_EXPORT
42 explicit FeaturesAPI_Intersection(const std::shared_ptr<ModelAPI_Feature>& theFeature);
43
45 FEATURESAPI_EXPORT
46 explicit FeaturesAPI_Intersection(const std::shared_ptr<ModelAPI_Feature>& theFeature,
47 const std::list<ModelHighAPI_Selection>& theObjects,
48 const ModelHighAPI_Double& aFuzzy = ModelHighAPI_Double(-1));
49
51 FEATURESAPI_EXPORT
53
61
62
63 FEATURESAPI_EXPORT
64 void setObjects(const std::list<ModelHighAPI_Selection>& theObjects);
65
67 FEATURESAPI_EXPORT
68 void setUseFuzzy(bool theUseFuzzy);
69
71 FEATURESAPI_EXPORT
72 void setFuzzyValue(const ModelHighAPI_Double& theFuzzy);
73
75 FEATURESAPI_EXPORT
76 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
77};
78
80typedef std::shared_ptr<FeaturesAPI_Intersection> IntersectionPtr;
81
84FEATURESAPI_EXPORT
85IntersectionPtr addIntersection(const std::shared_ptr<ModelAPI_Document>& part,
86 const std::list<ModelHighAPI_Selection>& objects,
88 const bool keepSubResults = false);
89
90#endif // FeaturesAPI_Intersection_H_
Interface for Intersection feature.
Definition: FeaturesAPI_Intersection.h:38
FeaturesAPI_Intersection(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_Intersection.cpp:30
virtual ~FeaturesAPI_Intersection()
Definition: FeaturesAPI_Intersection.cpp:61
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > objects() const
Objects.
Definition: FeaturesAPI_Intersection.h:60
virtual std::shared_ptr< ModelAPI_AttributeDouble > fuzzyParam() const
Fuzzy parameter.
Set use fuzzy parameter.
Definition: FeaturesAPI_Intersection.cpp:75
void setObjects(const std::list< ModelHighAPI_Selection > &theObjects)
Modify objects attribute of the feature.
Definition: FeaturesAPI_Intersection.cpp:67
void setFuzzyValue(const ModelHighAPI_Double &theFuzzy)
Set fuzzy parameter.
Definition: FeaturesAPI_Intersection.cpp:83
virtual std::shared_ptr< ModelAPI_AttributeBoolean > useFuzzy() const
Use Fuzzy parameter.
Dump wrapped feature.
Definition: FeaturesAPI_Intersection.cpp:91
static const std::string & FUZZY_PARAM_ID()
Attribute name of fuzzy parameter.
Definition: FeaturesPlugin_Intersection.h:59
static const std::string & USE_FUZZY_ID()
Attribute name of use fuzzy parameter.
Definition: FeaturesPlugin_Intersection.h:52
Feature kind.
Definition: FeaturesPlugin_Intersection.h:38
static const std::string & OBJECT_LIST_ID()
Attribute name of objects.
Definition: FeaturesPlugin_Intersection.h:45
Dump engine for the model.
IntersectionPtr addIntersection(const std::shared_ptr< ModelAPI_Document > &part, const std::list< ModelHighAPI_Selection > &objects, const ModelHighAPI_Double &fuzzyParam=ModelHighAPI_Double(-1), const bool keepSubResults=false)
Create Intersection feature.
Definition: FeaturesAPI_Intersection.cpp:113
