Interface for Intersection feature. More...
#include <FeaturesAPI_Intersection.h>
| FeaturesAPI_Intersection (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_Intersection (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theObjects, const ModelHighAPI_Double &aFuzzy=ModelHighAPI_Double(-1)) | |
| virtual | ~FeaturesAPI_Intersection () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | objects () const |
| Objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | useFuzzy () const |
| Use Fuzzy parameter. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | fuzzyParam () const |
| void | setObjects (const std::list< ModelHighAPI_Selection > &theObjects) |
| Modify objects attribute of the feature. More... | |
| void | setUseFuzzy (bool theUseFuzzy) |
| Set use fuzzy parameter. More... | |
| void | setFuzzyValue (const ModelHighAPI_Double &theFuzzy) |
| Set fuzzy parameter. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | myobjects |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myuseFuzzy |
| std::shared_ptr< ModelAPI_AttributeDouble > | myfuzzyParam |
explicit |
explicit |
inlinevirtual |
Objects.
inlinevirtual |
inlinevirtual |
Fuzzy parameter.
| void FeaturesAPI_Intersection::setObjects | ( | const std::list< ModelHighAPI_Selection > & | theObjects | ) |
| void FeaturesAPI_Intersection::setUseFuzzy | ( | bool | theUseFuzzy | ) |
| void FeaturesAPI_Intersection::setFuzzyValue | ( | const ModelHighAPI_Double & | theFuzzy | ) |
protectedinherited |
