FeaturesAPI_Placement.h
20#ifndef FeaturesAPI_Placement_H_
21#define FeaturesAPI_Placement_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_Placement.h>
26
32
37{
38public:
40 FEATURESAPI_EXPORT
41 explicit FeaturesAPI_Placement(const std::shared_ptr<ModelAPI_Feature>& theFeature);
42
44 FEATURESAPI_EXPORT
45 FeaturesAPI_Placement(const std::shared_ptr<ModelAPI_Feature>& theFeature,
46 const std::list<ModelHighAPI_Selection>& theObjects,
47 const ModelHighAPI_Selection& theStartShape,
48 const ModelHighAPI_Selection& theEndShape,
49 const bool theReverseDirection = false,
50 const bool theCentering = false);
51
53 FEATURESAPI_EXPORT
54 virtual ~FeaturesAPI_Placement();
55
56 INTERFACE_5(FeaturesPlugin_Placement::ID(),
67
68
69 FEATURESAPI_EXPORT
70 void setObjects(const std::list<ModelHighAPI_Selection>& theObjects);
71
73 FEATURESAPI_EXPORT
74 void setStartShape(const ModelHighAPI_Selection& theStartShape);
75
77 FEATURESAPI_EXPORT
78 void setEndShape(const ModelHighAPI_Selection& theEndShape);
79
81 FEATURESAPI_EXPORT
82 void setReverseDirection(const bool theReverseDirection);
83
85 FEATURESAPI_EXPORT
86 void setCentering(const bool theCentering);
87
89 FEATURESAPI_EXPORT
90 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
91};
92
94typedef std::shared_ptr<FeaturesAPI_Placement> PlacementPtr;
95
98FEATURESAPI_EXPORT
99PlacementPtr addPlacement(const std::shared_ptr<ModelAPI_Document>& thePart,
100 const std::list<ModelHighAPI_Selection>& theObjects,
101 const ModelHighAPI_Selection& theStartShape,
102 const ModelHighAPI_Selection& theEndShape,
103 const bool reverse = false,
104 const bool centering = false,
105 const bool keepSubResults = false);
106
107#endif // FeaturesAPI_Placement_H_
Interface for Placement feature.
Definition: FeaturesAPI_Placement.h:37
void setObjects(const std::list< ModelHighAPI_Selection > &theObjects)
Set objects.
Definition: FeaturesAPI_Placement.cpp:57
Definition: FeaturesAPI_Placement.cpp:51
virtual std::shared_ptr< ModelAPI_AttributeSelection > endShape() const
End shape.
Definition: FeaturesAPI_Placement.h:66
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reverseDirection() const
Reverse direction flag.
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > objects() const
Main objects.
virtual std::shared_ptr< ModelAPI_AttributeSelection > startShape() const
Start shape.
Set reverse direction flag.
Definition: FeaturesAPI_Placement.cpp:81
void setEndShape(const ModelHighAPI_Selection &theEndShape)
Set end shape.
Definition: FeaturesAPI_Placement.cpp:73
FeaturesAPI_Placement(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_Placement.cpp:26
virtual std::shared_ptr< ModelAPI_AttributeBoolean > centering() const
Centering flag.
Set centering flag.
Definition: FeaturesAPI_Placement.cpp:89
Dump wrapped feature.
Definition: FeaturesAPI_Placement.cpp:97
void setStartShape(const ModelHighAPI_Selection &theStartShape)
Set start shape.
Definition: FeaturesAPI_Placement.cpp:65
static const std::string & END_SHAPE_ID()
attribute name of attractable face
Definition: FeaturesPlugin_Placement.h:64
static const std::string & REVERSE_ID()
attribute name of flag of reverse direction
Definition: FeaturesPlugin_Placement.h:70
static const std::string & CENTERING_ID()
attribute name of flag of centering position
Definition: FeaturesPlugin_Placement.h:76
static const std::string & START_SHAPE_ID()
attribute name of referenced object
Definition: FeaturesPlugin_Placement.h:58
Placement kind.
Definition: FeaturesPlugin_Placement.h:43
attribute name of references sketch entities list, it should contain a sketch result or a pair a sket...
Definition: FeaturesPlugin_Placement.h:51
Dump engine for the model.
PlacementPtr addPlacement(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theObjects, const ModelHighAPI_Selection &theStartShape, const ModelHighAPI_Selection &theEndShape, const bool reverse=false, const bool centering=false, const bool keepSubResults=false)
Create Placement feature.
Definition: FeaturesAPI_Placement.cpp:124
