Interface for Placement feature. More...
#include <FeaturesAPI_Placement.h>
| FeaturesAPI_Placement (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_Placement (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theObjects, const ModelHighAPI_Selection &theStartShape, const ModelHighAPI_Selection &theEndShape, const bool theReverseDirection=false, const bool theCentering=false) | |
| virtual | ~FeaturesAPI_Placement () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | objects () const |
| Main objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | startShape () const |
| Start shape. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | endShape () const |
| End shape. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | reverseDirection () const |
| Reverse direction flag. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | centering () const |
| Centering flag. More... | |
| void | setObjects (const std::list< ModelHighAPI_Selection > &theObjects) |
| Set objects. More... | |
| void | setStartShape (const ModelHighAPI_Selection &theStartShape) |
| Set start shape. More... | |
| void | setEndShape (const ModelHighAPI_Selection &theEndShape) |
| Set end shape. More... | |
| void | setReverseDirection (const bool theReverseDirection) |
| Set reverse direction flag. More... | |
| void | setCentering (const bool theCentering) |
| Set centering flag. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | myobjects |
| std::shared_ptr< ModelAPI_AttributeSelection > | mystartShape |
| std::shared_ptr< ModelAPI_AttributeSelection > | myendShape |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myreverseDirection |
| std::shared_ptr< ModelAPI_AttributeBoolean > | mycentering |
explicit |
| FeaturesAPI_Placement::FeaturesAPI_Placement | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| const std::list< ModelHighAPI_Selection > & | theObjects, | ||
| const ModelHighAPI_Selection & | theStartShape, | ||
| const ModelHighAPI_Selection & | theEndShape, | ||
| const bool | theReverseDirection = false, |
| const bool | theCentering = false |
inlinevirtual |
Main objects.
inlinevirtual |
Start shape.
inlinevirtual |
End shape.
inlinevirtual |
inlinevirtual |
Centering flag.
| void FeaturesAPI_Placement::setObjects | ( | const std::list< ModelHighAPI_Selection > & | theObjects | ) |
Set objects.
| void FeaturesAPI_Placement::setStartShape | ( | const ModelHighAPI_Selection & | theStartShape | ) |
Set start shape.
| void FeaturesAPI_Placement::setEndShape | ( | const ModelHighAPI_Selection & | theEndShape | ) |
Set end shape.
| void FeaturesAPI_Placement::setReverseDirection | ( | const bool | theReverseDirection | ) |
| void FeaturesAPI_Placement::setCentering | ( | const bool | theCentering | ) |
Set centering flag.
protectedinherited |
