FeaturesAPI_Symmetry.h
20#ifndef FEATURESAPI_SYMMETRY_H_
21#define FEATURESAPI_SYMMETRY_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_Symmetry.h>
26
33
38{
39public:
41 FEATURESAPI_EXPORT
42 explicit FeaturesAPI_Symmetry(const std::shared_ptr<ModelAPI_Feature>& theFeature);
43
45 FEATURESAPI_EXPORT
46 explicit FeaturesAPI_Symmetry(const std::shared_ptr<ModelAPI_Feature>& theFeature,
47 const std::list<ModelHighAPI_Selection>& theMainObjects,
48 const ModelHighAPI_Selection& theObject,
49 bool theKeepOriginal = true);
50
52 FEATURESAPI_EXPORT
53 virtual ~FeaturesAPI_Symmetry();
54
55 INTERFACE_6(FeaturesPlugin_Symmetry::ID(),
68
69
70 FEATURESAPI_EXPORT
71 void setMainObjects(const std::list<ModelHighAPI_Selection>& theMainObjects);
72
74 FEATURESAPI_EXPORT
75 void setPoint(const ModelHighAPI_Selection& thePointObject);
76
78 FEATURESAPI_EXPORT
79 void setAxis(const ModelHighAPI_Selection& theAxisObject);
80
82 FEATURESAPI_EXPORT
83 void setPlane(const ModelHighAPI_Selection& thePlaneObject);
84
86 FEATURESAPI_EXPORT
87 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
88};
89
91typedef std::shared_ptr<FeaturesAPI_Symmetry> SymmetryPtr;
92
95FEATURESAPI_EXPORT
96SymmetryPtr addSymmetry(const std::shared_ptr<ModelAPI_Document>& part,
97 const std::list<ModelHighAPI_Selection>& objects,
98 const ModelHighAPI_Selection& basis,
99 const bool keepOriginal = true,
100 const bool keepSubResults = false);
101
102#endif // FEATURESAPI_SYMMETRY_H_
Interface for Symmetry feature.
Definition: FeaturesAPI_Symmetry.h:38
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects() const
Main objects.
Definition: FeaturesAPI_Symmetry.h:67
void setPoint(const ModelHighAPI_Selection &thePointObject)
Modify CreationMethod, point_object attribute of the feature.
Definition: FeaturesAPI_Symmetry.cpp:68
virtual std::shared_ptr< ModelAPI_AttributeSelection > pointObject() const
Point object.
void setMainObjects(const std::list< ModelHighAPI_Selection > &theMainObjects)
Set main objects.
Definition: FeaturesAPI_Symmetry.cpp:59
virtual std::shared_ptr< ModelAPI_AttributeSelection > axisObject() const
Axis object.
void setPlane(const ModelHighAPI_Selection &thePlaneObject)
Modify CreationMethod, plane_object attribute of the feature.
Definition: FeaturesAPI_Symmetry.cpp:86
FeaturesAPI_Symmetry(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_Symmetry.cpp:26
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
Dump wrapped feature.
Definition: FeaturesAPI_Symmetry.cpp:95
virtual std::shared_ptr< ModelAPI_AttributeSelection > planeObject() const
Plane object.
virtual std::shared_ptr< ModelAPI_AttributeBoolean > keepOriginal() const
Keep original shape.
Definition: FeaturesAPI_Symmetry.cpp:54
void setAxis(const ModelHighAPI_Selection &theAxisObject)
Modify CreationMethod, axis_object attribute of the feature.
Definition: FeaturesAPI_Symmetry.cpp:77
static const std::string & PLANE_OBJECT_ID()
Attribute name of a plane.
Definition: FeaturesPlugin_Symmetry.h:95
Definition: FeaturesPlugin_Symmetry.h:46
static const std::string & AXIS_OBJECT_ID()
Attribute name of an axis.
Definition: FeaturesPlugin_Symmetry.h:88
static const std::string & KEEP_ORIGINAL_RESULT()
Attribute name of keeping original shape.
Definition: FeaturesPlugin_Symmetry.h:102
Symmetry kind.
Definition: FeaturesPlugin_Symmetry.h:39
static const std::string & POINT_OBJECT_ID()
Attribute name of a point.
Definition: FeaturesPlugin_Symmetry.h:81
Attribute name of referenced objects.
Definition: FeaturesPlugin_Symmetry.h:74
Dump engine for the model.
SymmetryPtr addSymmetry(const std::shared_ptr< ModelAPI_Document > &part, const std::list< ModelHighAPI_Selection > &objects, const ModelHighAPI_Selection &basis, const bool keepOriginal=true, const bool keepSubResults=false)
Create Symmetry feature.
Definition: FeaturesAPI_Symmetry.cpp:130
