Interface for Symmetry feature. More...
#include <FeaturesAPI_Symmetry.h>
| FeaturesAPI_Symmetry (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_Symmetry (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theObject, bool theKeepOriginal=true) | |
| virtual | ~FeaturesAPI_Symmetry () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeString > | creationMethod () const |
| Creation method. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | mainObjects () const |
| Main objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | pointObject () const |
| Point object. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | axisObject () const |
| Axis object. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | planeObject () const |
| Plane object. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | keepOriginal () const |
| Keep original shape. More... | |
| void | setMainObjects (const std::list< ModelHighAPI_Selection > &theMainObjects) |
| Set main objects. More... | |
| void | setPoint (const ModelHighAPI_Selection &thePointObject) |
| Modify CreationMethod, point_object attribute of the feature. More... | |
| void | setAxis (const ModelHighAPI_Selection &theAxisObject) |
| Modify CreationMethod, axis_object attribute of the feature. More... | |
| void | setPlane (const ModelHighAPI_Selection &thePlaneObject) |
| Modify CreationMethod, plane_object attribute of the feature. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeString > | mycreationMethod |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mymainObjects |
| std::shared_ptr< ModelAPI_AttributeSelection > | mypointObject |
| std::shared_ptr< ModelAPI_AttributeSelection > | myaxisObject |
| std::shared_ptr< ModelAPI_AttributeSelection > | myplaneObject |
| std::shared_ptr< ModelAPI_AttributeBoolean > | mykeepOriginal |
explicit |
explicit |
inlinevirtual |
Creation method.
inlinevirtual |
Main objects.
inlinevirtual |
Point object.
inlinevirtual |
Axis object.
inlinevirtual |
Plane object.
inlinevirtual |
| void FeaturesAPI_Symmetry::setMainObjects | ( | const std::list< ModelHighAPI_Selection > & | theMainObjects | ) |
Set main objects.
| void FeaturesAPI_Symmetry::setPoint | ( | const ModelHighAPI_Selection & | thePointObject | ) |
| void FeaturesAPI_Symmetry::setAxis | ( | const ModelHighAPI_Selection & | theAxisObject | ) |
| void FeaturesAPI_Symmetry::setPlane | ( | const ModelHighAPI_Selection & | thePlaneObject | ) |
protectedinherited |
