GDMLAPI_Ellipsoid.h
20#ifndef GDMLAPI_Ellipsoid_H_
21#define GDMLAPI_Ellipsoid_H_
23#include "GDMLAPI.h"
24
25#include <GDMLPlugin_Ellipsoid.h>
26
31
36{
37public:
39 GDMLAPI_EXPORT
40 explicit GDMLAPI_Ellipsoid(const std::shared_ptr<ModelAPI_Feature>& theFeature);
41
43 GDMLAPI_EXPORT
44 explicit GDMLAPI_Ellipsoid(const std::shared_ptr<ModelAPI_Feature>& theFeature,
45 const ModelHighAPI_Double& theAX,
46 const ModelHighAPI_Double& theBY,
47 const ModelHighAPI_Double& theCZ);
48
50 GDMLAPI_EXPORT
51 explicit GDMLAPI_Ellipsoid(const std::shared_ptr<ModelAPI_Feature>& theFeature,
52 const ModelHighAPI_Double& theAX,
53 const ModelHighAPI_Double& theBY,
54 const ModelHighAPI_Double& theCZ,
55 const ModelHighAPI_Double& theZCut1,
56 const ModelHighAPI_Double& theZCut2);
57
59 GDMLAPI_EXPORT
60 virtual ~GDMLAPI_Ellipsoid();
61
62 INTERFACE_7(GDMLPlugin_Ellipsoid::ID(),
84
85
86 GDMLAPI_EXPORT
87 void setSizes(const ModelHighAPI_Double& theAX,
88 const ModelHighAPI_Double& theBY,
89 const ModelHighAPI_Double& theCZ);
90
92 GDMLAPI_EXPORT
93 void setZCut1(const ModelHighAPI_Double& theZCut1);
94
96 GDMLAPI_EXPORT
97 void setZCut2(const ModelHighAPI_Double& theZCut2);
98
100 GDMLAPI_EXPORT
101 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
102};
103
105typedef std::shared_ptr<GDMLAPI_Ellipsoid> EllipsoidPtr;
106
109GDMLAPI_EXPORT
110EllipsoidPtr addEllipsoid(const std::shared_ptr<ModelAPI_Document>& thePart,
111 const ModelHighAPI_Double& theAX,
112 const ModelHighAPI_Double& theBY,
113 const ModelHighAPI_Double& theCZ);
114
117GDMLAPI_EXPORT
118EllipsoidPtr addEllipsoid(const std::shared_ptr<ModelAPI_Document>& thePart,
119 const ModelHighAPI_Double& theAX,
120 const ModelHighAPI_Double& theBY,
121 const ModelHighAPI_Double& theCZ,
122 const ModelHighAPI_Double& theZCut1,
123 const ModelHighAPI_Double& theZCut2);
124#endif // GDMLAPI_Ellipsoid_H_
Interface for primitive Ellipsoid feature.
Definition: GDMLAPI_Ellipsoid.h:36
GDMLAPI_Ellipsoid(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: GDMLAPI_Ellipsoid.cpp:25
virtual std::shared_ptr< ModelAPI_AttributeDouble > by() const
Ellipsoid size along Y axis.
Definition: GDMLAPI_Ellipsoid.h:83
virtual std::shared_ptr< ModelAPI_AttributeString > useZCut2() const
Second cut of the ellipsoid along Z axis.
void setZCut1(const ModelHighAPI_Double &theZCut1)
Set Z cut no.1.
Definition: GDMLAPI_Ellipsoid.cpp:74
Dump wrapped feature.
Definition: GDMLAPI_Ellipsoid.cpp:92
Definition: GDMLAPI_Ellipsoid.cpp:59
void setSizes(const ModelHighAPI_Double &theAX, const ModelHighAPI_Double &theBY, const ModelHighAPI_Double &theCZ)
Set dimensions.
Definition: GDMLAPI_Ellipsoid.cpp:63
virtual std::shared_ptr< ModelAPI_AttributeDouble > zCut1() const
Position of the first cut.
virtual std::shared_ptr< ModelAPI_AttributeDouble > ax() const
Ellipsoid size along X axis.
virtual std::shared_ptr< ModelAPI_AttributeDouble > zCut2() const
Position of the second cut.
virtual std::shared_ptr< ModelAPI_AttributeString > useZCut1() const
First cut of the ellipsoid along Z axis.
virtual std::shared_ptr< ModelAPI_AttributeDouble > cz() const
Ellipsoid size along Z axis.
void setZCut2(const ModelHighAPI_Double &theZCut2)
Set Z cut no.2.
Definition: GDMLAPI_Ellipsoid.cpp:82
static const std::string & ZCUT1_ID()
attribute name of the outer radius at top of cone
Definition: GDMLPlugin_Ellipsoid.h:62
static const std::string & AX_ID()
attribute name of the inner radius at base of cone
Definition: GDMLPlugin_Ellipsoid.h:44
static const std::string & ZCUT2_ID()
Definition: GDMLPlugin_Ellipsoid.h:80
static const std::string & CZ_ID()
attribute name of the inner radius at top of cone
Definition: GDMLPlugin_Ellipsoid.h:56
static const std::string & USE_ZCUT1_ID()
Definition: GDMLPlugin_Ellipsoid.h:68
static const std::string & USE_ZCUT2_ID()
Definition: GDMLPlugin_Ellipsoid.h:74
Cone segment kind.
Definition: GDMLPlugin_Ellipsoid.h:38
static const std::string & BY_ID()
attribute name of the outer radius at base of cone
Definition: GDMLPlugin_Ellipsoid.h:50
Dump engine for the model.
EllipsoidPtr addEllipsoid(const std::shared_ptr< ModelAPI_Document > &thePart, const ModelHighAPI_Double &theAX, const ModelHighAPI_Double &theBY, const ModelHighAPI_Double &theCZ)
Create GDML Ellipsoid feature.
Definition: GDMLAPI_Ellipsoid.cpp:125
