GDMLAPI_Ellipsoid Class Reference
Interface for primitive Ellipsoid feature. More...
#include <GDMLAPI_Ellipsoid.h>
Inheritance diagram for GDMLAPI_Ellipsoid:
 GDMLAPI_Ellipsoid (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 GDMLAPI_Ellipsoid (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Double &theAX, const ModelHighAPI_Double &theBY, const ModelHighAPI_Double &theCZ)
 GDMLAPI_Ellipsoid (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Double &theAX, const ModelHighAPI_Double &theBY, const ModelHighAPI_Double &theCZ, const ModelHighAPI_Double &theZCut1, const ModelHighAPI_Double &theZCut2)
virtual ~GDMLAPI_Ellipsoid ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ax () const
 Ellipsoid size along X axis. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > by () const
 Ellipsoid size along Y axis. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > cz () const
 Ellipsoid size along Z axis. More...
virtual std::shared_ptr< ModelAPI_AttributeString > useZCut1 () const
 First cut of the ellipsoid along Z axis. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > zCut1 () const
 Position of the first cut. More...
virtual std::shared_ptr< ModelAPI_AttributeString > useZCut2 () const
 Second cut of the ellipsoid along Z axis. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > zCut2 () const
 Position of the second cut. More...
void setSizes (const ModelHighAPI_Double &theAX, const ModelHighAPI_Double &theBY, const ModelHighAPI_Double &theCZ)
 Set dimensions. More...
void setZCut1 (const ModelHighAPI_Double &theZCut1)
 Set Z cut no.1. More...
void setZCut2 (const ModelHighAPI_Double &theZCut2)
 Set Z cut no.2. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeDouble > myax
std::shared_ptr< ModelAPI_AttributeDouble > myby
std::shared_ptr< ModelAPI_AttributeDouble > mycz
std::shared_ptr< ModelAPI_AttributeString > myuseZCut1
std::shared_ptr< ModelAPI_AttributeDouble > myzCut1
std::shared_ptr< ModelAPI_AttributeString > myuseZCut2
std::shared_ptr< ModelAPI_AttributeDouble > myzCut2
◆ GDMLAPI_Ellipsoid() [1/3]
GDMLAPI_Ellipsoid::GDMLAPI_Ellipsoid ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ GDMLAPI_Ellipsoid() [2/3]
GDMLAPI_Ellipsoid::GDMLAPI_Ellipsoid ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Double &  theAX,
const ModelHighAPI_Double &  theBY,
const ModelHighAPI_Double &  theCZ
explicit
◆ GDMLAPI_Ellipsoid() [3/3]
const ModelHighAPI_Double &  theCZ,
const ModelHighAPI_Double &  theZCut1,
const ModelHighAPI_Double &  theZCut2
explicit
◆ ~GDMLAPI_Ellipsoid()
GDMLAPI_Ellipsoid::~GDMLAPI_Ellipsoid ( )
◆ ax()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_Ellipsoid::ax ( ) const
◆ by()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_Ellipsoid::by ( ) const
◆ cz()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_Ellipsoid::cz ( ) const
◆ useZCut1()
virtual std::shared_ptr< ModelAPI_AttributeString > GDMLAPI_Ellipsoid::useZCut1 ( ) const
◆ zCut1()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_Ellipsoid::zCut1 ( ) const
◆ useZCut2()
virtual std::shared_ptr< ModelAPI_AttributeString > GDMLAPI_Ellipsoid::useZCut2 ( ) const
◆ zCut2()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_Ellipsoid::zCut2 ( ) const
◆ setSizes()
void GDMLAPI_Ellipsoid::setSizes ( const ModelHighAPI_Double &  theAX,
Set dimensions.
◆ setZCut1()
void GDMLAPI_Ellipsoid::setZCut1 ( const ModelHighAPI_Double &  theZCut1)
Set Z cut no.1.
◆ setZCut2()
void GDMLAPI_Ellipsoid::setZCut2 ( const ModelHighAPI_Double &  theZCut2)
Set Z cut no.2.
◆ dump()
void GDMLAPI_Ellipsoid::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
