20#ifndef XGUI_ModuleConnector_H
21#define XGUI_ModuleConnector_H
24#include <ModuleBase_Definitions.h>
25#include <ModuleBase_IWorkshop.h>
98 virtual bool isVisible(
const ObjectPtr& theObject)
const;
105 virtual void setSelected(
const QList<std::shared_ptr<ModuleBase_ViewerPrs>>& theValues);
116 virtual std::shared_ptr<Config_FeatureMessage>
featureInfo(
const QString& theId)
const;
119 virtual QMainWindow*
desktop()
const;
125 virtual void deactivateCurrentSelector();
149 virtual void showHelpPage(
const QString& thePage)
const;
152 QObjectPtrList activeObjects(
const QObjectPtrList& theObjList)
const;
An interface to Errors manager object.
Definition: ModuleBase_IErrorMgr.h:38
Interface to a module.
Definition: ModuleBase_IModule.h:70
A class for Property panel object definition.
Definition: ModuleBase_IPropertyPanel.h:35
A class which provides interface of activation/deactivate selection modes and using selection filters...
Definition: ModuleBase_ISelectionActivate.h:36
A class which provides access to selection.
Definition: ModuleBase_ISelection.h:44
A Base object for definition of connector object to Salome Viewer.
Definition: ModuleBase_IViewer.h:47
Class which provides access to Workshop object services.
Definition: ModuleBase_IWorkshop.h:48
virtual void showHelpPage(const QString &thePage) const =0
Show help of a current operation.
virtual bool isCancelEnabled() const =0
Returns current state of cancel button.
virtual AISObjectPtr findPresentation(const ObjectPtr &theObject) const =0
Returns AIS object by data object.
virtual ModuleBase_IViewer * viewer() const =0
Returns current viewer.
virtual std::shared_ptr< Config_FeatureMessage > featureInfo(const QString &theId) const =0
Returns feature info according to given feature ID.
virtual void stopOperation(ModuleBase_Operation *theOperation, bool &isCommitted)=0
Commits if possible or aborts the given operation.
virtual void undo()=0
Undo last command.
virtual ModuleBase_ISelectionActivate * selectionActivate() const =0
A selection activate in 3D View handler.
virtual bool isVisible(const ObjectPtr &theObject) const =0
Returns true if the object is displayed.
virtual void applyCurrentSelectionModes(const AISObjectPtr &theAIS)=0
The methods applies current defined selection modes to given AIS presentation.
virtual ModuleBase_IPropertyPanel * propertyPanel() const =0
Returns property panel.
virtual ObjectPtr findPresentedObject(const AISObjectPtr &theAIS) const =0
Returns data object by AIS.
virtual ModuleBase_Operation * findStartedOperation(const QString &theId)=0
Returns started operation by the operation identifier.
virtual ModuleBase_IErrorMgr * errorMgr() const =0
Returns error manager.
virtual bool enableUpdateViewer(bool isEnabled)=0
Temporary enable or disable viewer update.
virtual void processLaunchOperation(ModuleBase_Operation *theOperation)=0
Performs the operation launch.
virtual ModuleBase_IModule * module() const =0
Returns instance of loaded module.
virtual bool hasSHIFTPressed() const =0
Returns true if SHIFT is pressed.
virtual void setStatusBarMessage(const QString &theMessage)=0
Shows the message in the status bar.
virtual ModuleBase_Operation * currentOperation() const =0
Returns currently active operation.
virtual QMainWindow * desktop() const =0
Returns main window of the application.
virtual void updateCommandStatus()=0
Update of commands status.
virtual ModuleBase_ISelection * selection() const =0
Return current selection instance.
virtual bool canStopOperation(ModuleBase_Operation *theOperation)=0
Returns true if the operation with id theId can be stopped.
virtual void setSelected(const QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues)=0
Select features clearing previous selection.
virtual bool canStartOperation(QString theId, bool &isCommitted)=0
Returns true if the operation with id theId can be started.
virtual void setCancelEnabled(bool toEnable)=0
Set enabled state of cancel button in property panel.
virtual QObjectPtrList displayedObjects() const =0
Returns list of currently displayed objects.
Base class for all operations.
Definition: ModuleBase_Operation.h:53
Displayer.
Definition: XGUI_Displayer.h:172
Implementation of IWorkshop interface which provides access to Workshop services at module level.
Definition: XGUI_ModuleConnector.h:35
XGUI_Workshop * workshop() const
Returns workshop.
Definition: XGUI_ModuleConnector.h:132
Class which defines a configuration of the application (Workshop) and launches it.
Definition: XGUI_Workshop.h:83
