BuildAPI_Filling Class Reference
Interface for Filling feature. More...
#include <BuildAPI_Filling.h>
Inheritance diagram for BuildAPI_Filling:
 BuildAPI_Filling (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 BuildAPI_Filling (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects)
 Constructor with base objects. More...
 BuildAPI_Filling (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const std::string &theOrientCorrection, const int theMinDegree, const int theMaxDegree, const int theNbIter, const double theTolerance2D, const double theTolerance3D, const bool theApproximate)
virtual ~BuildAPI_Filling ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects () const
 Base objects. More...
virtual std::shared_ptr< ModelAPI_AttributeString > orientationMethod () const
 Method to keep edge orientation. More...
virtual std::shared_ptr< ModelAPI_AttributeInteger > minDegree () const
 Minimal degree. More...
virtual std::shared_ptr< ModelAPI_AttributeInteger > maxDegree () const
 Maximal degree. More...
virtual std::shared_ptr< ModelAPI_AttributeInteger > nbIterations () const
 Number of iterations. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > tolerance2d () const
 2D tolerance More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > tolerance3d () const
 3D tolerance More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > approximate () const
 Approximate original edges. More...
void setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects)
 Modify base attribute of the feature. More...
void setOrientationMethod (const std::string &theMethod)
 Modify orientation method. More...
void setMinDegree (const int theMinDegree)
 Modify minimal degree of result B-spline. More...
void setMaxDegree (const int theMaxDegree)
 Modify maximal degree of result B-spline. More...
void setNbIterations (const int theNbIter)
 Modify number of iterations. More...
void setTolerance2d (const double theTol2d)
 Set 2D tolerance. More...
void setTolerance3d (const double theTol3d)
 Set 3D tolerance. More...
void setApproximation (const bool theApproximate)
 Set approximation flag. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mybaseObjects
std::shared_ptr< ModelAPI_AttributeString > myorientationMethod
std::shared_ptr< ModelAPI_AttributeInteger > myminDegree
std::shared_ptr< ModelAPI_AttributeInteger > mymaxDegree
std::shared_ptr< ModelAPI_AttributeInteger > mynbIterations
std::shared_ptr< ModelAPI_AttributeDouble > mytolerance2d
std::shared_ptr< ModelAPI_AttributeDouble > mytolerance3d
std::shared_ptr< ModelAPI_AttributeBoolean > myapproximate
◆ BuildAPI_Filling() [1/3]
BuildAPI_Filling::BuildAPI_Filling ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ BuildAPI_Filling() [2/3]
BuildAPI_Filling::BuildAPI_Filling ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theBaseObjects
explicit
◆ BuildAPI_Filling() [3/3]
const std::list< ModelHighAPI_Selection > &  theBaseObjects,
const std::string &  theOrientCorrection,
explicit
◆ ~BuildAPI_Filling()
BuildAPI_Filling::~BuildAPI_Filling ( )
◆ baseObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > BuildAPI_Filling::baseObjects ( ) const
Base objects.
◆ orientationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > BuildAPI_Filling::orientationMethod ( ) const
◆ minDegree()
virtual std::shared_ptr< ModelAPI_AttributeInteger > BuildAPI_Filling::minDegree ( ) const
Minimal degree.
◆ maxDegree()
virtual std::shared_ptr< ModelAPI_AttributeInteger > BuildAPI_Filling::maxDegree ( ) const
Maximal degree.
◆ nbIterations()
virtual std::shared_ptr< ModelAPI_AttributeInteger > BuildAPI_Filling::nbIterations ( ) const
◆ tolerance2d()
virtual std::shared_ptr< ModelAPI_AttributeDouble > BuildAPI_Filling::tolerance2d ( ) const
2D tolerance
◆ tolerance3d()
virtual std::shared_ptr< ModelAPI_AttributeDouble > BuildAPI_Filling::tolerance3d ( ) const
3D tolerance
◆ approximate()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > BuildAPI_Filling::approximate ( ) const
◆ setBase()
void BuildAPI_Filling::setBase ( const std::list< ModelHighAPI_Selection > &  theBaseObjects)
◆ setOrientationMethod()
void BuildAPI_Filling::setOrientationMethod ( const std::string &  theMethod)
◆ setMinDegree()
void BuildAPI_Filling::setMinDegree ( const int  theMinDegree)
◆ setMaxDegree()
void BuildAPI_Filling::setMaxDegree ( const int  theMaxDegree)
◆ setNbIterations()
void BuildAPI_Filling::setNbIterations ( const int  theNbIter)
◆ setTolerance2d()
void BuildAPI_Filling::setTolerance2d ( const double  theTol2d)
Set 2D tolerance.
◆ setTolerance3d()
void BuildAPI_Filling::setTolerance3d ( const double  theTol3d)
Set 3D tolerance.
◆ setApproximation()
void BuildAPI_Filling::setApproximation ( const bool  theApproximate)
◆ dump()
void BuildAPI_Filling::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
