ConstructionAPI_Axis Class Reference
Interface for Axis feature. More...
#include <ConstructionAPI_Axis.h>
Inheritance diagram for ConstructionAPI_Axis:
 ConstructionAPI_Axis (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 ConstructionAPI_Axis (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theObject1, const ModelHighAPI_Selection &theObject2)
 ConstructionAPI_Axis (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theObject)
 ConstructionAPI_Axis (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &thePoint, const ModelHighAPI_Double &theX, const ModelHighAPI_Double &theY, const ModelHighAPI_Double &theZ)
 ConstructionAPI_Axis (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Double &theDX, const ModelHighAPI_Double &theDY, const ModelHighAPI_Double &theDZ)
 ConstructionAPI_Axis (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &thePlane1, const ModelHighAPI_Double &theOffset1, const bool theReverseOffset1, const ModelHighAPI_Selection &thePlane2, const ModelHighAPI_Double &theOffset2, const bool theReverseOffset2)
 ConstructionAPI_Axis (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &thePlane1, const ModelHighAPI_Selection &thePlane2, const ModelHighAPI_Double &theOffset2, const bool theReverseOffset2)
 ConstructionAPI_Axis (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &thePlane1, const ModelHighAPI_Double &theOffset1, const bool theReverseOffset1, const ModelHighAPI_Selection &thePlane2)
virtual ~ConstructionAPI_Axis ()
virtual std::string getID ()
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > firstPoint () const
 First point. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > secondPoint () const
 Second point. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > cylindricalFace () const
 Cylindrical face. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > xDirection () const
 X direction. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > yDirection () const
 Y direction. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > zDirection () const
 Z direction. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > xDimension () const
 X dimension. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > yDimension () const
 Y dimension. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > zDimension () const
 Z dimension. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > line () const
 Line. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > plane () const
 Plane. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > point () const
 Point. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > plane1 () const
 Plane 1. More...
virtual std::shared_ptr< ModelAPI_AttributeString > useOffset1 () const
 Use offset 1. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > offset1 () const
 Offset 1. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reverseOffset1 () const
 Reverse offset 1. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > plane2 () const
 Plane 2. More...
virtual std::shared_ptr< ModelAPI_AttributeString > useOffset2 () const
 Use offset 2. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > offset2 () const
 Offset 2. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reverseOffset2 () const
 Reverse offset 2. More...
void setByPoints (const ModelHighAPI_Selection &thePoint1, const ModelHighAPI_Selection &thePoint2)
 Set points. More...
void setByCylindricalFace (const ModelHighAPI_Selection &theCylindricalFace)
 Set cylindrical face. More...
void setByPointAndDirection (const ModelHighAPI_Selection &thePoint, const ModelHighAPI_Double &theX, const ModelHighAPI_Double &theY, const ModelHighAPI_Double &theZ)
 Set direction. More...
void setByDimensions (const ModelHighAPI_Double &theDX, const ModelHighAPI_Double &theDY, const ModelHighAPI_Double &theDZ)
 Set dimensions. More...
void setByLine (const ModelHighAPI_Selection &theCylindricalFace)
 Set by line. More...
void setByPlaneAndPoint (const ModelHighAPI_Selection &thePlane, const ModelHighAPI_Selection &thePoint)
 Set by plane and point. More...
void setByTwoPlanes (const ModelHighAPI_Selection &thePlane1, const ModelHighAPI_Selection &thePlane2)
 Set by two planes. More...
void setByTwoPlanes (const ModelHighAPI_Selection &thePlane1, const ModelHighAPI_Double &theOffset1, const bool theReverseOffset1, const ModelHighAPI_Selection &thePlane2, const ModelHighAPI_Double &theOffset2, const bool theReverseOffset2)
void setByTwoPlanes (const ModelHighAPI_Selection &thePlane1, const ModelHighAPI_Selection &thePlane2, const ModelHighAPI_Double &theOffset2, const bool theReverseOffset2)
void setByTwoPlanes (const ModelHighAPI_Selection &thePlane1, const ModelHighAPI_Double &theOffset1, const bool theReverseOffset1, const ModelHighAPI_Selection &thePlane2)
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelection > myfirstPoint
std::shared_ptr< ModelAPI_AttributeSelection > mysecondPoint
std::shared_ptr< ModelAPI_AttributeSelection > mycylindricalFace
std::shared_ptr< ModelAPI_AttributeDouble > myxDirection
std::shared_ptr< ModelAPI_AttributeDouble > myyDirection
std::shared_ptr< ModelAPI_AttributeDouble > myzDirection
std::shared_ptr< ModelAPI_AttributeDouble > myxDimension
std::shared_ptr< ModelAPI_AttributeDouble > myyDimension
std::shared_ptr< ModelAPI_AttributeDouble > myzDimension
std::shared_ptr< ModelAPI_AttributeSelection > myline
std::shared_ptr< ModelAPI_AttributeSelection > myplane
std::shared_ptr< ModelAPI_AttributeSelection > mypoint
std::shared_ptr< ModelAPI_AttributeSelection > myplane1
std::shared_ptr< ModelAPI_AttributeString > myuseOffset1
std::shared_ptr< ModelAPI_AttributeDouble > myoffset1
std::shared_ptr< ModelAPI_AttributeBoolean > myreverseOffset1
std::shared_ptr< ModelAPI_AttributeSelection > myplane2
std::shared_ptr< ModelAPI_AttributeString > myuseOffset2
std::shared_ptr< ModelAPI_AttributeDouble > myoffset2
std::shared_ptr< ModelAPI_AttributeBoolean > myreverseOffset2
◆ ConstructionAPI_Axis() [1/8]
ConstructionAPI_Axis::ConstructionAPI_Axis ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ ConstructionAPI_Axis() [2/8]
ConstructionAPI_Axis::ConstructionAPI_Axis ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Selection &  theObject1,
const ModelHighAPI_Selection &  theObject2
◆ ConstructionAPI_Axis() [3/8]
◆ ConstructionAPI_Axis() [4/8]
const ModelHighAPI_Selection &  thePoint,
const ModelHighAPI_Double &  theX,
const ModelHighAPI_Double &  theY,
const ModelHighAPI_Double &  theZ
◆ ConstructionAPI_Axis() [5/8]
const ModelHighAPI_Double &  theDX,
const ModelHighAPI_Double &  theDY,
const ModelHighAPI_Double &  theDZ
◆ ConstructionAPI_Axis() [6/8]
const ModelHighAPI_Selection &  thePlane1,
const ModelHighAPI_Double &  theOffset1,
const ModelHighAPI_Selection &  thePlane2,
const ModelHighAPI_Double &  theOffset2,
◆ ConstructionAPI_Axis() [7/8]
◆ ConstructionAPI_Axis() [8/8]
◆ ~ConstructionAPI_Axis()
ConstructionAPI_Axis::~ConstructionAPI_Axis ( )
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > ConstructionAPI_Axis::creationMethod ( ) const
Creation method.
◆ firstPoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ConstructionAPI_Axis::firstPoint ( ) const
First point.
◆ secondPoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ConstructionAPI_Axis::secondPoint ( ) const
Second point.
◆ cylindricalFace()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ConstructionAPI_Axis::cylindricalFace ( ) const
Cylindrical face.
◆ xDirection()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ConstructionAPI_Axis::xDirection ( ) const
X direction.
◆ yDirection()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ConstructionAPI_Axis::yDirection ( ) const
Y direction.
◆ zDirection()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ConstructionAPI_Axis::zDirection ( ) const
Z direction.
◆ xDimension()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ConstructionAPI_Axis::xDimension ( ) const
X dimension.
◆ yDimension()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ConstructionAPI_Axis::yDimension ( ) const
Y dimension.
◆ zDimension()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ConstructionAPI_Axis::zDimension ( ) const
Z dimension.
◆ line()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ConstructionAPI_Axis::line ( ) const
Line.
◆ plane()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ConstructionAPI_Axis::plane ( ) const
Plane.
◆ point()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ConstructionAPI_Axis::point ( ) const
Point.
◆ plane1()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ConstructionAPI_Axis::plane1 ( ) const
Plane 1.
◆ useOffset1()
virtual std::shared_ptr< ModelAPI_AttributeString > ConstructionAPI_Axis::useOffset1 ( ) const
Use offset 1.
◆ offset1()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ConstructionAPI_Axis::offset1 ( ) const
Offset 1.
◆ reverseOffset1()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > ConstructionAPI_Axis::reverseOffset1 ( ) const
Reverse offset 1.
◆ plane2()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ConstructionAPI_Axis::plane2 ( ) const
Plane 2.
◆ useOffset2()
virtual std::shared_ptr< ModelAPI_AttributeString > ConstructionAPI_Axis::useOffset2 ( ) const
Use offset 2.
◆ offset2()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ConstructionAPI_Axis::offset2 ( ) const
Offset 2.
◆ reverseOffset2()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > ConstructionAPI_Axis::reverseOffset2 ( ) const
Reverse offset 2.
◆ setByPoints()
void ConstructionAPI_Axis::setByPoints ( const ModelHighAPI_Selection &  thePoint1,
const ModelHighAPI_Selection &  thePoint2
Set points.
◆ setByCylindricalFace()
void ConstructionAPI_Axis::setByCylindricalFace ( const ModelHighAPI_Selection &  theCylindricalFace)
◆ setByPointAndDirection()
void ConstructionAPI_Axis::setByPointAndDirection ( const ModelHighAPI_Selection &  thePoint,
Set direction.
◆ setByDimensions()
void ConstructionAPI_Axis::setByDimensions ( const ModelHighAPI_Double &  theDX,
Set dimensions.
◆ setByLine()
void ConstructionAPI_Axis::setByLine ( const ModelHighAPI_Selection &  theCylindricalFace)
Set by line.
◆ setByPlaneAndPoint()
void ConstructionAPI_Axis::setByPlaneAndPoint ( const ModelHighAPI_Selection &  thePlane,
◆ setByTwoPlanes() [1/4]
void ConstructionAPI_Axis::setByTwoPlanes ( const ModelHighAPI_Selection &  thePlane1,
Set by two planes.
◆ setByTwoPlanes() [2/4]
Set by two planes.
◆ setByTwoPlanes() [3/4]
Set by two planes.
◆ setByTwoPlanes() [4/4]
Set by two planes.
◆ dump()
void ConstructionAPI_Axis::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
