Interface for Plane feature. More...
#include <ConstructionAPI_Plane.h>
| ConstructionAPI_Plane (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| ConstructionAPI_Plane (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theFace, const ModelHighAPI_Double &theDistance, const bool theIsReverse, const ModelHighAPI_Integer &theNbCopy=ModelHighAPI_Integer(1)) | |
| ConstructionAPI_Plane (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Double &theA, const ModelHighAPI_Double &theB, const ModelHighAPI_Double &theC, const ModelHighAPI_Double &theD) | |
| ConstructionAPI_Plane (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &thePoint1, const ModelHighAPI_Selection &thePoint2, const ModelHighAPI_Selection &thePoint3) | |
| ConstructionAPI_Plane (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theLine, const ModelHighAPI_Selection &thePoint, const bool theIsPerpendicular) | |
| ConstructionAPI_Plane (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theObject1, const ModelHighAPI_Selection &theObject2) | |
| ConstructionAPI_Plane (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &thePlane, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theAngle, const ModelHighAPI_Integer &theNbCopy=ModelHighAPI_Integer(1)) | |
| virtual | ~ConstructionAPI_Plane () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeString > | creationMethod () const |
| Creation method. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | A () const |
| Parameter A for general equation. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | B () const |
| Parameter B for general equation. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | C () const |
| Parameter C for general equation. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | D () const |
| Parameter D for general equation. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | point1 () const |
| Point 1 for plane. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | point2 () const |
| Point 2 for plane. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | point3 () const |
| Point 3 for plane. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | line () const |
| Line for plane. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | point () const |
| Point for plane. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | perpendicular () const |
| Perpendicular flag. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeString > | creationMethodByOtherPlane () const |
| Creation method by other plane. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | plane () const |
| Plane face. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | distance () const |
| Distance. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | reverse () const |
| Reverse flag. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | coincidentPoint () const |
| Coincident point. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | axis () const |
| Axis for rotation. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | angle () const |
| Rotation angle. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | plane1 () const |
| Plane 1. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | plane2 () const |
| Plane 2. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeInteger > | nbcopy () const |
| Number of copies. More... | |
| void | setByFaceAndDistance (const ModelHighAPI_Selection &theFace, const ModelHighAPI_Double &theDistance, const bool theIsReverse, const ModelHighAPI_Integer &theNbCopy=ModelHighAPI_Integer(1)) |
| Set face and distance. More... | |
| void | setByGeneralEquation (const ModelHighAPI_Double &theA, const ModelHighAPI_Double &theB, const ModelHighAPI_Double &theC, const ModelHighAPI_Double &theD) |
| Set GeneralEquation parameters of the feature. More... | |
| void | setByThreePoints (const ModelHighAPI_Selection &thePoint1, const ModelHighAPI_Selection &thePoint2, const ModelHighAPI_Selection &thePoint3) |
| Set by three points. More... | |
| void | setByLineAndPoint (const ModelHighAPI_Selection &theLine, const ModelHighAPI_Selection &thePoint, const bool theIsPerpendicular) |
| Set by line and point. More... | |
| void | setByTwoParallelPlanes (const ModelHighAPI_Selection &thePlane1, const ModelHighAPI_Selection &thePlane2) |
| Set by two parallel planes. More... | |
| void | setByCoincidentToPoint (const ModelHighAPI_Selection &thePlane, const ModelHighAPI_Selection &thePoint) |
| Set by coincident to point. More... | |
| void | setByRotation (const ModelHighAPI_Selection &thePlane, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theAngle, const ModelHighAPI_Integer &theNbCopy=ModelHighAPI_Integer(1)) |
| Set by rotation. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeString > | mycreationMethod |
| std::shared_ptr< ModelAPI_AttributeDouble > | myA |
| std::shared_ptr< ModelAPI_AttributeDouble > | myB |
| std::shared_ptr< ModelAPI_AttributeDouble > | myC |
| std::shared_ptr< ModelAPI_AttributeDouble > | myD |
| std::shared_ptr< ModelAPI_AttributeSelection > | mypoint1 |
| std::shared_ptr< ModelAPI_AttributeSelection > | mypoint2 |
| std::shared_ptr< ModelAPI_AttributeSelection > | mypoint3 |
| std::shared_ptr< ModelAPI_AttributeSelection > | myline |
| std::shared_ptr< ModelAPI_AttributeSelection > | mypoint |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myperpendicular |
| std::shared_ptr< ModelAPI_AttributeString > | mycreationMethodByOtherPlane |
| std::shared_ptr< ModelAPI_AttributeSelection > | myplane |
| std::shared_ptr< ModelAPI_AttributeDouble > | mydistance |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myreverse |
| std::shared_ptr< ModelAPI_AttributeSelection > | mycoincidentPoint |
| std::shared_ptr< ModelAPI_AttributeSelection > | myaxis |
| std::shared_ptr< ModelAPI_AttributeDouble > | myangle |
| std::shared_ptr< ModelAPI_AttributeSelection > | myplane1 |
| std::shared_ptr< ModelAPI_AttributeSelection > | myplane2 |
| std::shared_ptr< ModelAPI_AttributeInteger > | mynbcopy |
explicit |
| ConstructionAPI_Plane::ConstructionAPI_Plane | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| const ModelHighAPI_Selection & | theFace, | ||
| const ModelHighAPI_Double & | theDistance, | ||
| const bool | theIsReverse, | ||
| const ModelHighAPI_Integer & | theNbCopy = ModelHighAPI_Integer(1) |
| const ModelHighAPI_Double & | theA, | ||
| const ModelHighAPI_Double & | theB, | ||
| const ModelHighAPI_Double & | theC, | ||
| const ModelHighAPI_Double & | theD | ||
| const ModelHighAPI_Selection & | thePoint1, | ||
| const ModelHighAPI_Selection & | thePoint2, | ||
| const ModelHighAPI_Selection & | thePoint3 | ||
| const ModelHighAPI_Selection & | theLine, | ||
| const ModelHighAPI_Selection & | thePoint, | ||
| const bool | theIsPerpendicular | ||
| const ModelHighAPI_Selection & | theObject1, | ||
| const ModelHighAPI_Selection & | theObject2 | ||
| const ModelHighAPI_Selection & | thePlane, | ||
| const ModelHighAPI_Selection & | theAxis, | ||
| const ModelHighAPI_Double & | theAngle, | ||
inlinevirtual |
Creation method.
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
Point 1 for plane.
inlinevirtual |
Point 2 for plane.
inlinevirtual |
Point 3 for plane.
inlinevirtual |
Line for plane.
inlinevirtual |
Point for plane.
inlinevirtual |
Perpendicular flag.
inlinevirtual |
inlinevirtual |
Plane face.
inlinevirtual |
Distance.
inlinevirtual |
Reverse flag.
inlinevirtual |
Coincident point.
inlinevirtual |
Axis for rotation.
inlinevirtual |
Rotation angle.
inlinevirtual |
Plane 1.
inlinevirtual |
Plane 2.
inlinevirtual |
Number of copies.
| void ConstructionAPI_Plane::setByFaceAndDistance | ( | const ModelHighAPI_Selection & | theFace, |
| void ConstructionAPI_Plane::setByGeneralEquation | ( | const ModelHighAPI_Double & | theA, |
| void ConstructionAPI_Plane::setByThreePoints | ( | const ModelHighAPI_Selection & | thePoint1, |
| void ConstructionAPI_Plane::setByLineAndPoint | ( | const ModelHighAPI_Selection & | theLine, |
| void ConstructionAPI_Plane::setByTwoParallelPlanes | ( | const ModelHighAPI_Selection & | thePlane1, |
| const ModelHighAPI_Selection & | thePlane2 | ||
| void ConstructionAPI_Plane::setByCoincidentToPoint | ( | const ModelHighAPI_Selection & | thePlane, |
| const ModelHighAPI_Selection & | thePoint | ||
| void ConstructionAPI_Plane::setByRotation | ( | const ModelHighAPI_Selection & | thePlane, |
Set by rotation.
protectedinherited |
