FeaturesAPI_BooleanCommon Class Reference
Interface for Boolean Common feature. More...
#include <FeaturesAPI_BooleanCommon.h>
Inheritance diagram for FeaturesAPI_BooleanCommon:
 FeaturesAPI_BooleanCommon (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_BooleanCommon (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Double &theFuzzy=ModelHighAPI_Double(-1))
 FeaturesAPI_BooleanCommon (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const std::list< ModelHighAPI_Selection > &theToolObjects, const ModelHighAPI_Double &theFuzzy=ModelHighAPI_Double(-1))
virtual ~FeaturesAPI_BooleanCommon ()
virtual std::string getID ()
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects () const
 Main objects. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > toolObjects () const
 Tool objects. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > useFuzzy () const
 Use Fuzzy parameter. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > fuzzyParam () const
void setMainObjects (const std::list< ModelHighAPI_Selection > &theMainObjects)
 Set main objects. More...
void setToolObjects (const std::list< ModelHighAPI_Selection > &theToolObjects)
 Set tool objects. More...
void setUseFuzzy (bool theUseFuzzy)
 Set use fuzzy parameter. More...
void setFuzzyValue (const ModelHighAPI_Double &theFuzzy)
 Set fuzzy parameter. More...
void setAdvancedMode (const bool theMode)
 Set mode. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mymainObjects
std::shared_ptr< ModelAPI_AttributeSelectionList > mytoolObjects
std::shared_ptr< ModelAPI_AttributeBoolean > myuseFuzzy
std::shared_ptr< ModelAPI_AttributeDouble > myfuzzyParam
◆ FeaturesAPI_BooleanCommon() [1/3]
FeaturesAPI_BooleanCommon::FeaturesAPI_BooleanCommon ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_BooleanCommon() [2/3]
FeaturesAPI_BooleanCommon::FeaturesAPI_BooleanCommon ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theMainObjects,
const ModelHighAPI_Double &  theFuzzy = ModelHighAPI_Double(-1)
◆ FeaturesAPI_BooleanCommon() [3/3]
const std::list< ModelHighAPI_Selection > &  theToolObjects,
◆ ~FeaturesAPI_BooleanCommon()
FeaturesAPI_BooleanCommon::~FeaturesAPI_BooleanCommon ( )
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_BooleanCommon::creationMethod ( ) const
Creation method.
◆ mainObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_BooleanCommon::mainObjects ( ) const
Main objects.
◆ toolObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_BooleanCommon::toolObjects ( ) const
Tool objects.
◆ useFuzzy()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > FeaturesAPI_BooleanCommon::useFuzzy ( ) const
◆ fuzzyParam()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_BooleanCommon::fuzzyParam ( ) const
Fuzzy parameter.
◆ setMainObjects()
void FeaturesAPI_BooleanCommon::setMainObjects ( const std::list< ModelHighAPI_Selection > &  theMainObjects)
Set main objects.
◆ setToolObjects()
void FeaturesAPI_BooleanCommon::setToolObjects ( const std::list< ModelHighAPI_Selection > &  theToolObjects)
Set tool objects.
◆ setUseFuzzy()
void FeaturesAPI_BooleanCommon::setUseFuzzy ( bool  theUseFuzzy)
◆ setFuzzyValue()
void FeaturesAPI_BooleanCommon::setFuzzyValue ( const ModelHighAPI_Double &  theFuzzy)
◆ setAdvancedMode()
void FeaturesAPI_BooleanCommon::setAdvancedMode ( const bool  theMode)
Set mode.
◆ dump()
void FeaturesAPI_BooleanCommon::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
