PrimitivesAPI_Box Class Reference
Interface for primitive Box feature. More...
#include <PrimitivesAPI_Box.h>
Inheritance diagram for PrimitivesAPI_Box:
 PrimitivesAPI_Box (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 PrimitivesAPI_Box (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Double &theDx, const ModelHighAPI_Double &theDy, const ModelHighAPI_Double &theDz)
 PrimitivesAPI_Box (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theFirstPoint, const ModelHighAPI_Selection &theSecondPoint)
 PrimitivesAPI_Box (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Double &theOx, const ModelHighAPI_Double &theOy, const ModelHighAPI_Double &theOz, const ModelHighAPI_Double &theHalfX, const ModelHighAPI_Double &theHalfY, const ModelHighAPI_Double &theHalfZ)
virtual ~PrimitivesAPI_Box ()
virtual std::string getID ()
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > dx () const
 Dimension in X. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > dy () const
 Dimension in Y. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > dz () const
 Dimension in Z. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > firstPoint () const
 First point. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > secondPoint () const
 Second point. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > ox () const
 X coordinate for origin. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > oy () const
 Y coordinate for origin. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > oz () const
 Z coordinate for origin. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > halfdx () const
 Half length in X. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > halfdy () const
 Half length in Y. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > halfdz () const
 Half length in Z. More...
void setDimensions (const ModelHighAPI_Double &theDx, const ModelHighAPI_Double &theDy, const ModelHighAPI_Double &theDz)
 Set dimensions. More...
void setPoints (const ModelHighAPI_Selection &theFirstPoint, const ModelHighAPI_Selection &theSecondPoint)
 Set points. More...
void setOrigin (const ModelHighAPI_Double &theOx, const ModelHighAPI_Double &theOy, const ModelHighAPI_Double &theOz)
 Set origin point. More...
void setHalfLengths (const ModelHighAPI_Double &theHalfLengthX, const ModelHighAPI_Double &theHalfLengthY, const ModelHighAPI_Double &theHalfLengthZ)
 Set half lengths. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeDouble > mydx
std::shared_ptr< ModelAPI_AttributeDouble > mydy
std::shared_ptr< ModelAPI_AttributeDouble > mydz
std::shared_ptr< ModelAPI_AttributeSelection > myfirstPoint
std::shared_ptr< ModelAPI_AttributeSelection > mysecondPoint
std::shared_ptr< ModelAPI_AttributeDouble > myox
std::shared_ptr< ModelAPI_AttributeDouble > myoy
std::shared_ptr< ModelAPI_AttributeDouble > myoz
std::shared_ptr< ModelAPI_AttributeDouble > myhalfdx
std::shared_ptr< ModelAPI_AttributeDouble > myhalfdy
std::shared_ptr< ModelAPI_AttributeDouble > myhalfdz
◆ PrimitivesAPI_Box() [1/4]
PrimitivesAPI_Box::PrimitivesAPI_Box ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ PrimitivesAPI_Box() [2/4]
PrimitivesAPI_Box::PrimitivesAPI_Box ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Double &  theDx,
const ModelHighAPI_Double &  theDy,
const ModelHighAPI_Double &  theDz
explicit
◆ PrimitivesAPI_Box() [3/4]
const ModelHighAPI_Selection &  theFirstPoint,
const ModelHighAPI_Selection &  theSecondPoint
explicit
◆ PrimitivesAPI_Box() [4/4]
const ModelHighAPI_Double &  theOx,
const ModelHighAPI_Double &  theOy,
const ModelHighAPI_Double &  theOz,
const ModelHighAPI_Double &  theHalfX,
const ModelHighAPI_Double &  theHalfY,
const ModelHighAPI_Double &  theHalfZ
explicit
◆ ~PrimitivesAPI_Box()
PrimitivesAPI_Box::~PrimitivesAPI_Box ( )
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > PrimitivesAPI_Box::creationMethod ( ) const
Creation method.
◆ dx()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Box::dx ( ) const
Dimension in X.
◆ dy()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Box::dy ( ) const
Dimension in Y.
◆ dz()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Box::dz ( ) const
Dimension in Z.
◆ firstPoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > PrimitivesAPI_Box::firstPoint ( ) const
First point.
◆ secondPoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > PrimitivesAPI_Box::secondPoint ( ) const
Second point.
◆ ox()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Box::ox ( ) const
◆ oy()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Box::oy ( ) const
◆ oz()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Box::oz ( ) const
◆ halfdx()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Box::halfdx ( ) const
Half length in X.
◆ halfdy()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Box::halfdy ( ) const
Half length in Y.
◆ halfdz()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Box::halfdz ( ) const
Half length in Z.
◆ setDimensions()
void PrimitivesAPI_Box::setDimensions ( const ModelHighAPI_Double &  theDx,
Set dimensions.
◆ setPoints()
void PrimitivesAPI_Box::setPoints ( const ModelHighAPI_Selection &  theFirstPoint,
Set points.
◆ setOrigin()
void PrimitivesAPI_Box::setOrigin ( const ModelHighAPI_Double &  theOx,
Set origin point.
◆ setHalfLengths()
void PrimitivesAPI_Box::setHalfLengths ( const ModelHighAPI_Double &  theHalfLengthX,
const ModelHighAPI_Double &  theHalfLengthY,
const ModelHighAPI_Double &  theHalfLengthZ
Set half lengths.
◆ dump()
void PrimitivesAPI_Box::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
