Contains all necessary data in SolveSpace format to solve a single group of constraints. More...
#include <SolveSpaceSolver_Storage.h>
| SolveSpaceSolver_Storage (const GroupID &theGroup) | |
| virtual bool | update (ConstraintWrapperPtr theConstraint) |
| Update constraint's data. More... | |
| virtual bool | update (EntityWrapperPtr theEntity) |
| Update entity's data. More... | |
| virtual bool | update (ParameterWrapperPtr theParameter) |
| Update parameter's data. More... | |
| virtual void | refresh (bool theFixedOnly=false) const |
| Update SketchPlugin features after resolving constraints. More... | |
| virtual void | verifyFixed () |
| Check if some parameters or entities are returned to the current group after removing temporary constraints. More... | |
| virtual void | addCoincidentPoints (EntityWrapperPtr theMaster, EntityWrapperPtr theSlave) |
| Mark two points as coincident. More... | |
| virtual EntityWrapperPtr | calculateMiddlePoint (EntityWrapperPtr theBase, double theCoeff) |
| Calculate point on theBase entity. More... | |
| void | storeWorkplane (EntityWrapperPtr theSketch) |
| Obtain and store identifier of sketch. More... | |
| Slvs_hParam | addParameter (const Slvs_Param &theParam) |
| Add new parameter to the current group. More... | |
| Slvs_hParam | updateParameter (const Slvs_Param &theParam) |
| Updates parameter in the current group. More... | |
| bool | removeParameter (const Slvs_hParam &theParamID) |
| Removes the parameter by its ID. More... | |
| const Slvs_Param & | getParameter (const Slvs_hParam &theParamID) const |
| Returns the parameter by its ID. More... | |
| Slvs_hEntity | addEntity (const Slvs_Entity &theEntity) |
| Add new entity to the current group. More... | |
| Slvs_hEntity | updateEntity (const Slvs_Entity &theEntity) |
| Updates entity in the current group. More... | |
| bool | removeEntity (const Slvs_hEntity &theEntityID) |
| Removes the entity by its ID. More... | |
| const Slvs_Entity & | getEntity (const Slvs_hEntity &theEntityID) const |
| Returns the entity by its ID. More... | |
| const Slvs_hEntity & | entityMaxID () const |
| Returns maximal ID of entities in this storage. More... | |
| Slvs_hConstraint | addConstraint (const Slvs_Constraint &theConstraint) |
| Add new constraint to the current group. More... | |
| Slvs_hConstraint | updateConstraint (const Slvs_Constraint &theConstraint) |
| Updates constraint in the current group. More... | |
| bool | removeConstraint (const Slvs_hConstraint &theConstraintID) |
| Removes the constraint by its ID. More... | |
| const Slvs_Constraint & | getConstraint (const Slvs_hConstraint &theConstraintID) const |
| Returns the constraint by its ID. More... | |
| size_t | nbConstraints () const |
| Returns quantity of constraints in this storage. More... | |
| virtual bool | hasDuplicatedConstraint () const |
| Shows the storage has the same constraint twice. More... | |
| virtual void | initializeSolver (SolverPtr theSolver) |
| Initialize constraint solver by the entities collected by current storage. More... | |
| virtual void | addConstraint (ConstraintPtr theConstraint, ConstraintWrapperPtr theSolverConstraint) |
| Change mapping between constraint from SketchPlugin and a constraint applicable for corresponding solver. More... | |
| virtual void | addMovementConstraint (const ConstraintWrapperPtr &theSolverConstraint)=0 |
| Add a movement constraint which will be destroyed after the next solving of the set of constraints. More... | |
| void | addEntity (FeaturePtr theFeature, EntityWrapperPtr theSolverEntity) |
| Change mapping feature from SketchPlugin and the entity applicable for corresponding solver. More... | |
| void | addEntity (AttributePtr theAttribute, EntityWrapperPtr theSolverEntity) |
| Change mapping attribute of a feature and the entity applicable for corresponding solver. More... | |
| virtual bool | update (FeaturePtr theFeature, bool theForce=false)=0 |
| Convert feature to the form applicable for specific solver and map it. More... | |
| virtual bool | update (AttributePtr theAttribute, bool theForce=false)=0 |
| Convert attribute to the form applicable for specific solver and map it. More... | |
| const ConstraintWrapperPtr & | constraint (const ConstraintPtr &theConstraint) const |
| Returns constraint related to corresponding constraint. More... | |
| const EntityWrapperPtr & | entity (const FeaturePtr &theFeature) const |
| Returns entity related to corresponding feature. More... | |
| const EntityWrapperPtr & | entity (const AttributePtr &theAttribute) const |
| Returns entity related to corresponding attribute. More... | |
| virtual void | makeExternal (const EntityWrapperPtr &theEntity)=0 |
| Make entity external. More... | |
| virtual void | makeNonExternal (const EntityWrapperPtr &theEntity)=0 |
| Make entity non-external. More... | |
| virtual bool | removeConstraint (ConstraintPtr theConstraint)=0 |
| Removes constraint from the storage. More... | |
| virtual bool | changeActiveStatus (ConstraintPtr theConstraint, bool theNewState)=0 |
| virtual bool | UpdateDeactivateList ()=0 |
| void | removeFeature (FeaturePtr theFeature) |
| Removes feature from the storage. More... | |
| void | removeAttribute (AttributePtr theAttribute) |
| Removes attribute from the storage. More... | |
| virtual void | removeInvalidEntities ()=0 |
| Remove all features became invalid. More... | |
| bool | areFeaturesValid () const |
| Check the features have not been removed. More... | |
| virtual bool | isEmpty () const |
| Check the storage has constraints. More... | |
| virtual bool | isNeedToResolve () |
| Shows the sketch should be resolved. More... | |
| void | setNeedToResolve (bool theFlag) |
| Changes the flag of group to be resolved. More... | |
| std::set< ObjectPtr > | getConflictingConstraints (SolverPtr theSolver) const |
| Return list of conflicting constraints. More... | |
| virtual void | getUnderconstrainedGeometry (std::set< ObjectPtr > &theFeatures) const =0 |
| Return list of features which are not fully constrained. More... | |
| virtual PlaneGCSSolver_Solver::SolveStatus | checkDegeneratedGeometry () const =0 |
| Verify, the sketch contains degenerated geometry after resolving the set of constraints. More... | |
| virtual void | refresh () const =0 |
| void | blockEvents (bool isBlocked) |
| Block or unblock events when refreshing features. More... | |
| void | subscribeUpdates (SketchSolver_Constraint *theSubscriber, const std::string &theGroup) const |
| Subscribe for updates of features. More... | |
| void | unsubscribeUpdates (SketchSolver_Constraint *theSubscriber) const |
| Unsubscribe for updates of features. More... | |
| void | notify (const FeaturePtr &theFeature) const |
| Notify all subscribers about update of the feature. More... | |
| virtual void | adjustParametrizationOfArcs ()=0 |
| Make parametrization of arcs consistent. More... | |
| virtual bool | remove (ConstraintWrapperPtr theConstraint) |
| Remove constraint. More... | |
| virtual bool | remove (EntityWrapperPtr theEntity) |
| Remove entity. More... | |
| virtual bool | remove (ParameterWrapperPtr theParameter) |
| Remove parameter. More... | |
| virtual void | changeGroup (EntityWrapperPtr theEntity, const GroupID &theGroup) |
| Update the group for the given entity, its sub-entities and parameters. More... | |
| virtual void | changeGroup (ParameterWrapperPtr theParam, const GroupID &theGroup) |
| Update the group for the given parameter. More... | |
Static Protected Member Functions | |
| static void | resultToFeatureOrAttribute (const ObjectPtr &theResult, FeaturePtr &theFeature, AttributePtr &theAttribute) |
| Convert result to feature or attribute if theResult is linked to center of circle/arc. More... | |
Protected Attributes | |
| SolverPtr | mySketchSolver |
| Sketch solver, prepared in corresponding group. More... | |
| bool | myNeedToResolve |
| parameters are changed and group needs to be resolved More... | |
| bool | myEventsBlocked |
| indicates that features do not send events More... | |
| std::map< ConstraintPtr, ConstraintWrapperPtr > | myConstraintMap |
| map SketchPlugin constraint to a list of solver's constraints More... | |
| std::map< FeaturePtr, EntityWrapperPtr > | myFeatureMap |
| map SketchPlugin feature to solver's entity More... | |
| std::map< AttributePtr, EntityWrapperPtr > | myAttributeMap |
| map attribute to solver's entity More... | |
| UpdaterPtr | myUpdaters |
| std::map< ConstraintPtr, ConstraintWrapperPtr > | myDeactivatedConstraintMap |
true if any value is updated
true if the value of parameter is updated
| theFixedOnly | [in] if true the fixed points will be updated only |
Value theCoeff is in [0.0 .. 1.0] and shows the distance from the start point.
protectedvirtual |
Remove constraint.
true if the constraint and all its parameters are removed successfully
protectedvirtual |
Remove entity.
true if the entity and all its parameters are removed successfully
protectedvirtual |
Remove parameter.
true if the parameter has been removed
protectedvirtual |
protectedvirtual |
| void SolveSpaceSolver_Storage::storeWorkplane | ( | EntityWrapperPtr | theSketch | ) |
| Slvs_hParam SolveSpaceSolver_Storage::addParameter | ( | const Slvs_Param & | theParam | ) |
| [in] | theParam | SolveSpace parameter |
| Slvs_hParam SolveSpaceSolver_Storage::updateParameter | ( | const Slvs_Param & | theParam | ) |
If the ID of parameter is zero, the new item will be added
| bool SolveSpaceSolver_Storage::removeParameter | ( | const Slvs_hParam & | theParamID | ) |
| [in] | theParamID | index of parameter to be removed |
true if the parameter was successfully removed | const Slvs_Param & SolveSpaceSolver_Storage::getParameter | ( | const Slvs_hParam & | theParamID | ) | const |
| Slvs_hEntity SolveSpaceSolver_Storage::addEntity | ( | const Slvs_Entity & | theEntity | ) |
| [in] | theEntity | SolveSpace entity |
| Slvs_hEntity SolveSpaceSolver_Storage::updateEntity | ( | const Slvs_Entity & | theEntity | ) |
If the ID of entity is zero, the new item will be added
| bool SolveSpaceSolver_Storage::removeEntity | ( | const Slvs_hEntity & | theEntityID | ) |
All parameters used in this entity, and not used in other constraints, will be removed too.
| [in] | theEntityID | index of entity to be removed |
true if the entity was successfully removed | const Slvs_Entity & SolveSpaceSolver_Storage::getEntity | ( | const Slvs_hEntity & | theEntityID | ) | const |
inline |
| Slvs_hConstraint SolveSpaceSolver_Storage::addConstraint | ( | const Slvs_Constraint & | theConstraint | ) |
| [in] | theConstraint | SolveSpace's constraint |
| Slvs_hConstraint SolveSpaceSolver_Storage::updateConstraint | ( | const Slvs_Constraint & | theConstraint | ) |
If the ID of constraint is zero, the new item will be added
| [in] | theConstraint | SolveSpace constraint |
| bool SolveSpaceSolver_Storage::removeConstraint | ( | const Slvs_hConstraint & | theConstraintID | ) |
All entities and parameters depending on this constraint, which are not used in other constraints, will be removed too.
| [in] | theConstraintID | index of constraint to be removed |
true if the constraint was successfully removed | const Slvs_Constraint & SolveSpaceSolver_Storage::getConstraint | ( | const Slvs_hConstraint & | theConstraintID | ) | const |
inline |
inlinevirtual |
| theConstraint | [in] original SketchPlugin constraint |
| theSolverConstraint | [in] solver's constraint |
Reimplemented in PlaneGCSSolver_Storage.
pure virtualinherited |
Implemented in PlaneGCSSolver_Storage.
| theFeature | [in] original SketchPlugin feature |
| theSolverEntity | [in] solver's entity, created outside |
| theAttribute | [in] original attribute |
| theFeature | [in] feature to convert |
| theForce | [in] forced feature creation |
true if the feature has been created or updated Implemented in PlaneGCSSolver_Storage.
| theAttribute | [in] attribute to convert |
true if the attribute has been created or updated Implemented in PlaneGCSSolver_Storage.
TODO: Check resultToFeatureOrAttribute() precisely. Create additional unit-test
true if the constraint and all its parameters are removed successfully Implemented in PlaneGCSSolver_Storage.
inlinevirtualinherited |
inlineinherited |
| theSubscriber | [in] object which wants to revceive notifications |
| theGroup | [in] group of updates features to be send |
| theSubscriber | [in] object which does not want to revceive notifications anymore |
Forward arcs should have the last parameter greater than the first parameter. Reversed arcs should have the last parameter lesser than the first parameter.
staticprotectedinherited |
