PlaneGCSSolver_Tools Namespace Reference
Converter tools. More...
class  AttributeArray
 Provide an interface to access values in attribute which is an array of values. More...
SolverConstraintPtr createConstraint (ConstraintPtr theConstraint)
 Creates a solver's constraint using given SketchPlugin constraint or returns empty pointer if not all attributes are correct. More...
std::shared_ptr< SketchSolver_ConstraintMovement > createMovementConstraint (FeaturePtr theMovedFeature)
 Creates temporary constraint to fix the feature after movement. More...
std::shared_ptr< SketchSolver_ConstraintMovement > createMovementConstraint (AttributePtr theMovedAttribute)
 Creates temporary constraint to fix the attribute after movement. More...
std::shared_ptr< SketchSolver_ConstraintMovement > createMovementConstraint (const std::pair< AttributePtr, int > &theMovedPointInArray)
 Creates temporary constraint to fix the point in array after movement. More...
ConstraintWrapperPtr createConstraint (ConstraintPtr theConstraint, const SketchSolver_ConstraintType &theType, const EntityWrapperPtr &theValue, const EntityWrapperPtr &theEntity1, const EntityWrapperPtr &theEntity2=EntityWrapperPtr(), const EntityWrapperPtr &theEntity3=EntityWrapperPtr(), const EntityWrapperPtr &theEntity4=EntityWrapperPtr())
 Creates new constraint using given parameters. More...
bool isAttributeApplicable (const std::string &theAttrName, const std::string &theOwnerName)
 Return true if the attribute is used in PlaneGCS solver. More...
std::shared_ptr< GeomAPI_Pnt2d > point (EntityWrapperPtr theEntity)
 Convert entity to point. More...
std::shared_ptr< GeomAPI_Lin2d > line (EntityWrapperPtr theEntity)
 Convert entity to line. More...
std::shared_ptr< GeomAPI_Circ2d > circle (EntityWrapperPtr theEntity)
 Convert entity to circle. More...
std::shared_ptr< GeomAPI_Ellipse2d > ellipse (EntityWrapperPtr theEntity)
 Convert entity to ellipse. More...
std::shared_ptr< GeomAPI_BSpline2d > bspline (EntityWrapperPtr theEntity)
 Convert entity to Bs-pline. More...
std::shared_ptr< GeomAPI_Lin2d > line (FeaturePtr theFeature)
void recalculateArcParameters (EntityWrapperPtr theArc)
 Update start and end parameters of circular and elliptic arcs respectively to start and end points on the arc. More...
GCS::SET_pD parameters (const EntityWrapperPtr &theEntity)
 brief Return list of parameters for the given entity More...
bool updateValue (const double &theSource, double &theDest, const double theTolerance=1.e4 *tolerance)
 Update value in theDest if theSource is differ more than theTolerance. More...
double distance (const GCS::Point &thePnt1, const GCS::Point &thePnt2)
Converter tools.
◆ createConstraint() [1/2]
SolverConstraintPtr PlaneGCSSolver_Tools::createConstraint ( ConstraintPtr  theConstraint)
◆ createMovementConstraint() [1/3]
std::shared_ptr< SketchSolver_ConstraintMovement > PlaneGCSSolver_Tools::createMovementConstraint ( FeaturePtr  theMovedFeature)
◆ createMovementConstraint() [2/3]
std::shared_ptr< SketchSolver_ConstraintMovement > PlaneGCSSolver_Tools::createMovementConstraint ( AttributePtr  theMovedAttribute)
◆ createMovementConstraint() [3/3]
std::shared_ptr< SketchSolver_ConstraintMovement > PlaneGCSSolver_Tools::createMovementConstraint ( const std::pair< AttributePtr, int > &  theMovedPointInArray)
◆ createConstraint() [2/2]
ConstraintWrapperPtr PlaneGCSSolver_Tools::createConstraint ( ConstraintPtr  theConstraint,
const SketchSolver_ConstraintType &  theType,
const EntityWrapperPtr &  theValue,
const EntityWrapperPtr &  theEntity1,
const EntityWrapperPtr &  theEntity2 = EntityWrapperPtr(),
const EntityWrapperPtr &  theEntity3 = EntityWrapperPtr(),
const EntityWrapperPtr &  theEntity4 = EntityWrapperPtr()
theConstraint[in] original constraint
theType[in] type of constraint
theValue[in] numeric characteristic of constraint (e.g. distance or radius) if applicable
theEntity1[in] first attribute of constraint
theEntity2[in] second attribute of constraint
theEntity3[in] third attribute of constraint
theEntity4[in] fourth attribute of constraint
Created wrapper of constraints applicable for specific solver.
◆ isAttributeApplicable()
bool PlaneGCSSolver_Tools::isAttributeApplicable ( const std::string &  theAttrName,
const std::string &  theOwnerName
[in]theAttrNamename of the attribute
[in]theOwnerNamename of the parent feature
◆ point()
std::shared_ptr< GeomAPI_Pnt2d > PlaneGCSSolver_Tools::point ( EntityWrapperPtr  theEntity)
empty pointer if the entity is not a point
◆ line() [1/2]
std::shared_ptr< GeomAPI_Lin2d > PlaneGCSSolver_Tools::line ( EntityWrapperPtr  theEntity)
empty pointer if the entity is not a line
◆ circle()
std::shared_ptr< GeomAPI_Circ2d > PlaneGCSSolver_Tools::circle ( EntityWrapperPtr  theEntity)
empty pointer if the entity is not a circle
◆ ellipse()
std::shared_ptr< GeomAPI_Ellipse2d > PlaneGCSSolver_Tools::ellipse ( EntityWrapperPtr  theEntity)
empty pointer if the entity is not an ellipse
◆ bspline()
std::shared_ptr< GeomAPI_BSpline2d > PlaneGCSSolver_Tools::bspline ( EntityWrapperPtr  theEntity)
◆ line() [2/2]
std::shared_ptr< GeomAPI_Lin2d > PlaneGCSSolver_Tools::line ( FeaturePtr  theFeature)
◆ recalculateArcParameters()
void PlaneGCSSolver_Tools::recalculateArcParameters ( EntityWrapperPtr  theArc)
For the circular arc, the radius is calculated too.
◆ parameters()
GCS::SET_pD PlaneGCSSolver_Tools::parameters ( const EntityWrapperPtr &  theEntity)
◆ updateValue()
bool PlaneGCSSolver_Tools::updateValue ( const double &  theSource,
double &  theDest,
const double  theTolerance = 1.e4 * tolerance
Update value.
true if the value was updated.
