StdMeshers_ProjectionUtils.hxx File Reference
#include "SMDS_MeshElement.hxx"
#include "SMESH_Delaunay.hxx"
#include "StdMeshers_FaceSide.hxx"
#include <ShapeAnalysis_Surface.hxx>
#include <TopTools_DataMapOfShapeShape.hxx>
#include <TopTools_IndexedDataMapOfShapeListOfShape.hxx>
#include <TopoDS_Edge.hxx>
#include <TopoDS_Face.hxx>
#include <TopoDS_Vertex.hxx>
#include <gp_GTrsf.hxx>
#include <gp_GTrsf2d.hxx>
#include <list>
#include <map>
Include dependency graph for StdMeshers_ProjectionUtils.hxx:
struct  StdMeshers_ShapeShapeBiDirectionMap
 Struct used instead of a sole TopTools_DataMapOfShapeShape to avoid problems with bidirectional bindings. More...
class  StdMeshers_ProjectionUtils::TrsfFinder2D
 Finds transformation between two sets of 2D points using a least square approximation. More...
class  StdMeshers_ProjectionUtils::TrsfFinder3D
 Finds transformation between two sets of 3D points using a least square approximation. More...
class  StdMeshers_ProjectionUtils::Delaunay
 Create a Delaunay triangulation of nodes on a face boundary and provide exploration of nodes shared by elements lying on the face. More...
class  StdMeshers_ProjectionUtils::Morph
 Morph mesh on the target FACE to lie within FACE boundary w/o distortion. More...
namespace  StdMeshers_ProjectionUtils
 Methods common to Projection algorithms.
Typedefs
typedef StdMeshers_ShapeShapeBiDirectionMap StdMeshers_ProjectionUtils::TShapeShapeMap
typedef TopTools_IndexedDataMapOfShapeListOfShape StdMeshers_ProjectionUtils::TAncestorMap
typedef std::map< const SMDS_MeshNode *, const SMDS_MeshNode *, TIDCompare > StdMeshers_ProjectionUtils::TNodeNodeMap
typedef boost::shared_ptr< Delaunay > StdMeshers_ProjectionUtils::DelaunayPtr
bool StdMeshers_ProjectionUtils::FindSubShapeAssociation (const TopoDS_Shape &theShape1, SMESH_Mesh *theMesh1, const TopoDS_Shape &theShape2, SMESH_Mesh *theMesh2, TShapeShapeMap &theAssociationMap)
 Looks for association of all sub-shapes of two shapes. More...
int StdMeshers_ProjectionUtils::FindFaceAssociation (const TopoDS_Face &face1, TopoDS_Vertex VV1[2], const TopoDS_Face &face2, TopoDS_Vertex VV2[2], std::list< TopoDS_Edge > &edges1, std::list< TopoDS_Edge > &edges2, const bool isClosenessAssoc=false)
 Find association of edges of faces. More...
void StdMeshers_ProjectionUtils::InitVertexAssociation (const SMESH_Hypothesis *theHyp, TShapeShapeMap &theAssociationMap)
 Insert vertex association defined by a hypothesis into a map. More...
bool StdMeshers_ProjectionUtils::InsertAssociation (const TopoDS_Shape &theShape1, const TopoDS_Shape &theShape2, TShapeShapeMap &theAssociationMap)
 Inserts association theShape1 <-> theShape2 to TShapeShapeMap. More...
TopoDS_Edge StdMeshers_ProjectionUtils::GetEdgeByVertices (SMESH_Mesh *aMesh, const TopoDS_Vertex &V1, const TopoDS_Vertex &V2)
 Finds an edge by its vertices in a main shape of the mesh. More...
TopoDS_Face StdMeshers_ProjectionUtils::GetNextFace (const TAncestorMap &edgeToFaces, const TopoDS_Edge &edge, const TopoDS_Face &face)
 Return another face sharing an edge. More...
TopoDS_Vertex StdMeshers_ProjectionUtils::GetNextVertex (const TopoDS_Edge &edge, const TopoDS_Vertex &vertex)
 Return other vertex of an edge. More...
std::pair< int, TopoDS_Edge > StdMeshers_ProjectionUtils::GetPropagationEdge (SMESH_Mesh *aMesh, const TopoDS_Edge &anEdge, const TopoDS_Edge &fromEdge, TopTools_IndexedMapOfShape *chain=0)
 Return an oriented propagation edge. More...
bool StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces (const TopoDS_Face &face1, SMESH_Mesh *mesh1, const TopoDS_Face &face2, SMESH_Mesh *mesh2, const TShapeShapeMap &assocMap, TNodeNodeMap &nodeIn2OutMap)
 Find corresponding nodes on two faces. More...
TopoDS_Shape StdMeshers_ProjectionUtils::OuterShape (const TopoDS_Face &face, TopAbs_ShapeEnum type)
 Return any sub-shape of a face belonging to the outer wire. More...
bool StdMeshers_ProjectionUtils::MakeComputed (SMESH_subMesh *sm, const int iterationNb=0)
 Check that submeshis is computed and try to compute it if is not. More...
std::string StdMeshers_ProjectionUtils::SourceNotComputedError (SMESH_subMesh *sm=0, SMESH_Algo *projAlgo=0)
 Returns an error message to show in case if MakeComputed( sm ) fails. More...
void StdMeshers_ProjectionUtils::SetEventListener (SMESH_subMesh *subMesh, TopoDS_Shape srcShape, SMESH_Mesh *srcMesh)
 Set event listeners to submesh with projection algo. More...
TopoDS_Edge StdMeshers_ProjectionUtils::GetBoundaryEdge (const TopoDS_Shape &edgeContainer, const SMESH_Mesh &mesh, std::list< TopoDS_Edge > *allBndEdges=0)
 Return a boundary EDGE (or all boundary EDGEs) of edgeContainer. More...
