// Copyright (C) 2016-2026 CEA, EDF
// This library is free software; you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public
// License as published by the Free Software Foundation; either
// version 2.1 of the License, or (at your option) any later version.
// This library is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
// Lesser General Public License for more details.
// You should have received a copy of the GNU Lesser General Public
// License along with this library; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
// See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
#include "MEDPyLockWrapper.hxx"
#include "MEDPresentationPlot3D.hxx"
#include "MEDPresentationException.hxx"
#include <SALOME_KernelServices.hxx>
#undef LOG // should be fixed in KERNEL - double definition
#include <Basics_Utils.hxx>
#include <sstream>
const std::string MEDPresentationPlot3D::TYPE_NAME = "MEDPresentationPlot3D";
const std::string MEDPresentationPlot3D::PROP_PLANE_NORMAL_X = "planeNormalX";
const std::string MEDPresentationPlot3D::PROP_PLANE_NORMAL_Y = "planeNormalY";
const std::string MEDPresentationPlot3D::PROP_PLANE_NORMAL_Z = "planeNormalZ";
const std::string MEDPresentationPlot3D::PROP_PLANE_POS = "planePos";
const std::string MEDPresentationPlot3D::PROP_IS_PLANAR = "isPlanar";
MEDPresentationPlot3D::MEDPresentationPlot3D(const MEDCALC::Plot3DParameters& params,
const MEDCALC::ViewModeType viewMode) :
MEDPresentation(params.fieldHandlerId, TYPE_NAME, viewMode, params.colorMap, params.scalarBarRange),
_params(params)
setDoubleProperty(MEDPresentationPlot3D::PROP_PLANE_NORMAL_X, params.planeNormal[0]);
setDoubleProperty(MEDPresentationPlot3D::PROP_PLANE_NORMAL_Y, params.planeNormal[1]);
setDoubleProperty(MEDPresentationPlot3D::PROP_PLANE_NORMAL_Z, params.planeNormal[2]);
setDoubleProperty(MEDPresentationPlot3D::PROP_PLANE_POS, params.planePos);
_isPlanar = 0;
setIntProperty(MEDPresentationPlot3D::PROP_IS_PLANAR, _isPlanar);
void
MEDPresentationPlot3D::initFieldMeshInfos()
MEDPresentation::initFieldMeshInfos();
_colorByType = "POINTS";
void
MEDPresentationPlot3D::getSliceObj()
std::ostringstream oss;
oss << "__objSlice";
_objSlice = oss.str(); oss.str("");
oss << _objSlice << " = pvs.Slice(" << _srcObjVar << ");";
pushAndExecPyLine(oss.str()); oss.str("");
oss << _objSlice << ".SliceType.Normal = [" <<
_params.planeNormal[0] << ", " <<
_params.planeNormal[1] << ", " <<
_params.planeNormal[2] << "];";
oss << "slicePos = medcalc.GetPositions(" << _srcObjVar << ", [" <<
_params.planeNormal[2] << "]," <<
_params.planePos << ");";
oss << _objSlice << ".SliceType.Origin = slicePos";
oss << _objVar << " = " << _objSlice;
execPyLine(oss.str()); oss.str("");
void
MEDPresentationPlot3D::getMagnitude()
oss << "__objCalc";
_objCalc = oss.str(); oss.str("");
oss << _objCalc <<"= pvs.Calculator(Input=" << _objSlice << ");";
if (_pvFieldType == "CELLS") {
oss << _objCalc << ".AttributeType = 'Cell Data'";
oss << _objCalc << ".ResultArrayName = 'resCalcMag'";
std::string fieldName = _fieldName;
if(_nbComponents == 2)
fieldName += "_Vector";
oss << _objCalc << ".Function = 'mag(" << fieldName << ")'";
void
MEDPresentationPlot3D::internalGeneratePipeline()
MEDPresentation::internalGeneratePipeline();
MEDPyLockWrapper lock;
createSource();
setTimestamp();
fillAvailableFieldComponents();
setOrCreateRenderView();
oss << "is_planar = medcalc.IsPlanarObj("<< _srcObjVar<<");";
getPythonObjectFromMain("is_planar");
PyObject * obj = getPythonObjectFromMain("is_planar");
// Planar mesh?
if (obj && PyBool_Check(obj) && (obj == Py_False))
getSliceObj();
else
oss << _objSlice << " = " << _srcObjVar;
_isPlanar = 1;
// Vector field?
if(_nbComponents > 1)
getMagnitude();
oss << "scalarArray = "<< _objCalc << ".ResultArrayName;";
else
oss << "__objCalc";
oss << _objCalc << " = " << _objSlice;
// cell data?
oss << _objCalc << " = pvs.CellDatatoPointData(" << _objCalc << ");";
oss << _objCalc << ".PassCellData = 1;";
oss << _objVar << " = pvs.WarpByScalar(Input=" << _objCalc << ");";
oss << _objVar << ".Scalars = ['" << "POINTS" << "', " << "scalarArray]";
else
oss << _objVar << ".Scalars = ['" << "POINTS" << "', '" << _fieldName << "']";
oss << _objVar << ".Normal = [" <<
else
oss << "P2 = " << "medcalc.GetPlaneNormalVector(" << _objSlice << ")";
PyObject * obj2 = getPythonObjectFromMain("P2");
if (obj2 && PyList_Check(obj2)) {
PyObject* objP0 = PyList_GetItem(obj2, 0);
PyObject* objP1 = PyList_GetItem(obj2, 1);
PyObject* objP2 = PyList_GetItem(obj2, 2);
if (PyFloat_Check(objP0) && PyFloat_Check(objP1) && PyFloat_Check(objP2)) {
_params.planeNormal[0] = PyFloat_AsDouble(objP0);
_params.planeNormal[1] = PyFloat_AsDouble(objP1);
_params.planeNormal[2] = PyFloat_AsDouble(objP2);
setDoubleProperty(MEDPresentationPlot3D::PROP_PLANE_NORMAL_X, _params.planeNormal[0]);
setDoubleProperty(MEDPresentationPlot3D::PROP_PLANE_NORMAL_Y, _params.planeNormal[1]);
setDoubleProperty(MEDPresentationPlot3D::PROP_PLANE_NORMAL_Z, _params.planeNormal[2]);
oss << _objVar << ".Normal = " << "medcalc.GetPlaneNormalVector(" << _objSlice << ")";
showObject();
colorBy(); // see initFieldInfo() - necessarily POINTS because of the conversion above
showScalarBar();
selectColorMap();
rescaleTransferFunction();
resetCameraAndRender();
void
MEDPresentationPlot3D::updatePipeline(const MEDCALC::Plot3DParameters& params)
if (params.fieldHandlerId != _params.fieldHandlerId)
throw KERNEL::createSalomeException("Unexpected updatePipeline error! Mismatching fieldHandlerId!");
if (params.colorMap != _params.colorMap)
updateColorMap<MEDPresentationPlot3D, MEDCALC::Plot3DParameters>(params.colorMap);
if (params.scalarBarRange != _params.scalarBarRange ||
params.hideDataOutsideCustomRange != _params.hideDataOutsideCustomRange ||
params.scalarBarRangeArray[0] != _params.scalarBarRangeArray[0] ||
params.scalarBarRangeArray[1] != _params.scalarBarRangeArray[1])
updateScalarBarRange<MEDPresentationPlot3D, MEDCALC::Plot3DParameters>(params.scalarBarRange,
params.hideDataOutsideCustomRange,
params.scalarBarRangeArray[0],
params.scalarBarRangeArray[1]);
if (params.planeNormal[0] != _params.planeNormal[0] ||
params.planeNormal[1] != _params.planeNormal[1] ||
params.planeNormal[2] != _params.planeNormal[2])
updatePlaneNormal(params.planeNormal);
if (_isPlanar == 0 && params.planePos != _params.planePos)
updatePlanePos(params.planePos);
if (params.visibility != _params.visibility)
updateVisibility<MEDPresentationPlot3D, MEDCALC::Plot3DParameters>(params.visibility);
if (params.scalarBarVisibility != _params.scalarBarVisibility)
updateScalarBarVisibility<MEDPresentationPlot3D, MEDCALC::Plot3DParameters>(params.scalarBarVisibility);
void
MEDPresentationPlot3D::updatePlaneNormal(MEDCALC::DoubleArray planeNormal)
_params.planeNormal[0] = planeNormal[0];
_params.planeNormal[1] = planeNormal[1];
_params.planeNormal[2] = planeNormal[2];
// GUI helper:
setDoubleProperty(MEDPresentationPlot3D::PROP_PLANE_NORMAL_X, planeNormal[0]);
setDoubleProperty(MEDPresentationPlot3D::PROP_PLANE_NORMAL_Y, planeNormal[1]);
setDoubleProperty(MEDPresentationPlot3D::PROP_PLANE_NORMAL_Z, planeNormal[2]);
// Update Plane Normal
if(_isPlanar == 0)
updatePlanePos(_params.planePos);
pushAndExecPyLine("pvs.Render();");
void
MEDPresentationPlot3D::updatePlanePos(const double planePos)
_params.planePos = planePos;
// GUI helper:
setDoubleProperty(MEDPresentationPlot3D::PROP_PLANE_POS, planePos);
// Update Plane Position
