medpresentation Python API
def MakePlot3D(proxy,
viewMode=MEDCALC.VIEW_MODE_DEFAULT,
scalarBarRange=MEDCALC.SCALAR_BAR_RANGE_DEFAULT,
colorMap=MEDCALC.COLOR_MAP_DEFAULT
# Create the presentation instance in CORBA engine
# The engine in turn creates the ParaView pipeline elements
visibility = DEFAULT_VISIBILITY
scalarBarVisibility = DEFAULT_SCALAR_BAR_VISIBILITY
scalarBarRangeArray = DEFAULT_SCALAR_BAR_RANGE
hideDataOutsideCustomRange = DEFAULT_HIDE_DATA_OUTSIDE_CUSTOM_RANGE
planeNormal = DEFAULT_PLANE_NORMAL
planePos = DEFAULT_PLANE_POS
params = MEDCALC.Plot3DParameters(proxy.id, scalarBarRange, colorMap, visibility,
scalarBarVisibility, scalarBarRangeArray, hideDataOutsideCustomRange, planeNormal, planePos)
try:
presentation_id = __manager.makePlot3D(params, viewMode)
notifyGui_addPresentation(proxy.id, presentation_id)
return presentation_id
except SALOME.SALOME_Exception as e:
notifyGui_error("An error occurred while creating the Plot3D:\n" + e.details.text)
raise Exception(e.details.text)
GetPlot3DParameters = lambda pres_id: __GetGENERICParameters("Plot3D", pres_id)
Method __GetGENERICParameters is an internal helper method that calls getPlot3DParameters function of MEDPresentationManager CORBA service.
UpdatePlot3D = lambda pres_id, params: __UpdateGENERIC("Plot3D", pres_id, params)
Method __GetGENERICParameters is an internal helper method that calls updatePlot3D function of MEDPresentationManager CORBA service.
