// Copyright (C) 2016-2026 CEA, EDF
// This library is free software; you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public
// License as published by the Free Software Foundation; either
// version 2.1 of the License, or (at your option) any later version.
// This library is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
// Lesser General Public License for more details.
// You should have received a copy of the GNU Lesser General Public
// License along with this library; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
// See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
#include "MEDWidgetHelperPlot3D.hxx"
#include "MEDPresentationPlot3D.hxx" // from component side.
#include "PresentationController.hxx"
#include <Basics_Utils.hxx>
#include <sstream>
MEDWidgetHelperPlot3D::MEDWidgetHelperPlot3D(const PresentationController* presController,
MEDCALC::MEDPresentationManager_ptr presManager, int presId, const std::string & presName,
WidgetPresentationParameters * paramW):
MEDWidgetHelper(presController, presManager, presId, presName, paramW)
MEDWidgetHelperPlot3D::~MEDWidgetHelperPlot3D()
void MEDWidgetHelperPlot3D::loadParametersFromEngine()
MEDWidgetHelper::loadParametersFromEngine();
_planeNormal[0] = _presManager->getPresentationDoubleProperty(_presId, MEDPresentationPlot3D::PROP_PLANE_NORMAL_X.c_str());
_planeNormal[1] = _presManager->getPresentationDoubleProperty(_presId, MEDPresentationPlot3D::PROP_PLANE_NORMAL_Y.c_str());
_planeNormal[2] = _presManager->getPresentationDoubleProperty(_presId, MEDPresentationPlot3D::PROP_PLANE_NORMAL_Z.c_str());
_planePos = _presManager->getPresentationDoubleProperty(_presId, MEDPresentationPlot3D::PROP_PLANE_POS.c_str());
_isPlanar = _presManager->getPresentationIntProperty(_presId, MEDPresentationPlot3D::PROP_IS_PLANAR.c_str());
void MEDWidgetHelperPlot3D::updateWidget(bool connect)
MEDWidgetHelper::updateWidget(connect);
_paramWidget->setNormal(_planeNormal[0], _planeNormal[1], _planeNormal[2]);
_paramWidget->setPlanePosition(_planePos);
// Connect spin boxes changes
if (connect)
QObject::connect( _paramWidget, SIGNAL(spinNormalValuesChanged(double, double, double)), this, SLOT(onPlaneNormalChanged(double, double, double)) );
QObject::connect( _paramWidget, SIGNAL(spinPlanePosValueChanged(double)), this, SLOT(onPlanePositionChanged(double)) );
if(_isPlanar)
_paramWidget->hidePlot3D();
void MEDWidgetHelperPlot3D::releaseWidget()
MEDWidgetHelper::releaseWidget();
QObject::disconnect( _paramWidget, SIGNAL(spinNormalValuesChanged(double, double, double)), this, SLOT(onPlaneNormalChanged(double, double, double)) );
QObject::disconnect( _paramWidget, SIGNAL(spinPlanePosValueChanged(double)), this, SLOT(onPlanePositionChanged(double)) );
void MEDWidgetHelperPlot3D::onPlaneNormalChanged(double normX, double normY, double normZ)
STDLOG("MEDWidgetHelperSlices::onNbSlicesChanged");
PresentationEvent* event = new PresentationEvent();
event->eventtype = PresentationEvent::EVENT_CHANGE_NORMAL;
event->presentationId = _presId;
event->aDoubleN[0] = normX;
event->aDoubleN[1] = normY;
event->aDoubleN[2] = normZ;
emit presentationUpdateSignal(event); // --> PresentationController::processPresentationEvent
void MEDWidgetHelperPlot3D::onPlanePositionChanged(double planePos)
event->eventtype = PresentationEvent::EVENT_CHANGE_PLANE_POS;
event->aDouble3 = planePos;
