Plot3D presentation’s parameters panel implementation
Functions to access the cutting plane normal
void
WidgetPresentationParameters::setNormal(const double normX, const double normY, const double normZ)
_blockSig = true;
_ui.labelCutPlaneNormal->show();
_ui.spinNormalX->show();
_ui.spinNormalY->show();
_ui.spinNormalZ->show();
_ui.spinNormalX->setValue(normX);
_ui.spinNormalY->setValue(normY);
_ui.spinNormalZ->setValue(normZ);
_blockSig = false;
void WidgetPresentationParameters::getNormal(double* arr) const
arr[0] = _ui.spinNormalX->value();
arr[1] = _ui.spinNormalY->value();
arr[2] = _ui.spinNormalZ->value();
Functions to access the cutting plane position
void
_blockSig = true;
_blockSig = false;
Signal-slot connections
QObject::connect(_ui.spinNormalX, SIGNAL(editingFinished()),
this, SLOT(onSpinNormalEditingFinished()) );
QObject::connect(_ui.spinNormalY, SIGNAL(editingFinished()),
QObject::connect(_ui.spinNormalZ, SIGNAL(editingFinished()),
QObject::connect(_ui.spinPlanePos, SIGNAL(editingFinished()),
this, SLOT(onSpinPlanePosEditingFinished()) );
