20#ifndef SRC_CONSTRUCTIONAPI_CONSTRUCTIONAPI_POINT_H_
21#define SRC_CONSTRUCTIONAPI_CONSTRUCTIONAPI_POINT_H_
23#include "ConstructionAPI.h"
25#include <ConstructionPlugin_Point.h>
41 CONSTRUCTIONAPI_EXPORT
45 CONSTRUCTIONAPI_EXPORT
52 CONSTRUCTIONAPI_EXPORT
56 const bool theUseRatio =
false,
57 const bool theReverse =
false);
60 CONSTRUCTIONAPI_EXPORT
66 CONSTRUCTIONAPI_EXPORT
74 CONSTRUCTIONAPI_EXPORT
77 const bool theIsCircularEdge =
false,
78 const bool theIsXYZSelection =
false);
81 CONSTRUCTIONAPI_EXPORT
85 point, ConstructionPlugin_Point::POINT3D(),
137 CONSTRUCTIONAPI_EXPORT
143 CONSTRUCTIONAPI_EXPORT
146 const
bool theUseRatio = false,
147 const
bool theReverse = false);
150 CONSTRUCTIONAPI_EXPORT
155 CONSTRUCTIONAPI_EXPORT
160 CONSTRUCTIONAPI_EXPORT
165 CONSTRUCTIONAPI_EXPORT
170 CONSTRUCTIONAPI_EXPORT
176 CONSTRUCTIONAPI_EXPORT
180 CONSTRUCTIONAPI_EXPORT
184 CONSTRUCTIONAPI_EXPORT
193CONSTRUCTIONAPI_EXPORT
201CONSTRUCTIONAPI_EXPORT
205 const
206 const
210CONSTRUCTIONAPI_EXPORT
218CONSTRUCTIONAPI_EXPORT
223 const
227CONSTRUCTIONAPI_EXPORT
235CONSTRUCTIONAPI_EXPORT
238 const
bool theIsCircularEdge = false);
242CONSTRUCTIONAPI_EXPORT
Interface for Point feature.
Definition: ConstructionAPI_Point.h:38
void setByProjectionOnEdge(const ModelHighAPI_Selection &theVertex, const ModelHighAPI_Selection &theEdge)
Set point and edge for projection.
Definition: ConstructionAPI_Point.cpp:197
void setByLinesIntersection(const ModelHighAPI_Selection &theEdge1, const ModelHighAPI_Selection &theEdge2)
Set lines for intersections.
Definition: ConstructionAPI_Point.cpp:225
virtual std::shared_ptr< GeomDataAPI_Point > point() const
Point attribute.
Definition: ConstructionAPI_Point.h:134
virtual std::shared_ptr< ModelAPI_AttributeSelection > intersectionLine2() const
Line for intersection.
virtual std::shared_ptr< ModelAPI_AttributeSelection > pointToProject() const
Point to project.
virtual std::shared_ptr< ModelAPI_AttributeSelection > intersectionLine() const
virtual std::shared_ptr< ModelAPI_AttributeDouble > ratio() const
Ratio.
void setByCenterOfGravity(const ModelHighAPI_Selection &theObject)
Set object for center of gravity.
Definition: ConstructionAPI_Point.cpp:266
virtual std::shared_ptr< ModelAPI_AttributeDouble > distance() const
Distance.
virtual std::shared_ptr< ModelAPI_AttributeSelection > intersectionPlane3() const
Plane for intersection.
virtual std::shared_ptr< ModelAPI_AttributeSelection > edgeForPointProjection() const
Edge for point projection.
virtual std::shared_ptr< ModelAPI_AttributeSelection > intersectionPlane() const
void setByProjectionOnFace(const ModelHighAPI_Selection &theVertex, const ModelHighAPI_Selection &theFace)
Set point and face for projection.
Definition: ConstructionAPI_Point.cpp:211
virtual std::shared_ptr< ModelAPI_AttributeSelection > objectForCenterOfGravity() const
Object for center of gravity.
ConstructionAPI_Point(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: ConstructionAPI_Point.cpp:32
virtual std::shared_ptr< ModelAPI_AttributeString > projectionType() const
Type of the point projection.
virtual std::shared_ptr< ModelAPI_AttributeString > geometricalPropertyType() const
Type of the geometrical property.
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reverseOffset() const
Reverse offset.
virtual std::shared_ptr< ModelAPI_AttributeString > intersectionType() const
Type of the intersection.
virtual std::shared_ptr< ModelAPI_AttributeSelection > intersectionLine1() const
void setByXYZ(const ModelHighAPI_Double &theX, const ModelHighAPI_Double &theY, const ModelHighAPI_Double &theZ)
Set point values.
Definition: ConstructionAPI_Point.cpp:165
virtual std::shared_ptr< ModelAPI_AttributeString > offsetType() const
Type of the offset on edge.
virtual ~ConstructionAPI_Point()
Definition: ConstructionAPI_Point.cpp:159
virtual std::shared_ptr< ModelAPI_AttributeString > useOffset() const
Use offset.
virtual std::shared_ptr< ModelAPI_AttributeSelection > objectForCenterOfCircle() const
Object for center of circle.
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reverse() const
Reverse.
virtual std::shared_ptr< ModelAPI_AttributeSelection > faceForPointProjection() const
Face for point projection.
virtual std::shared_ptr< ModelAPI_AttributeSelection > intersectionPlane1() const
void setByOffsetOnEdge(const ModelHighAPI_Selection &theEdge, const ModelHighAPI_Double &theOffset, const bool theUseRatio=false, const bool theReverse=false)
Set edge and distance on it for point.
Definition: ConstructionAPI_Point.cpp:176
virtual std::shared_ptr< ModelAPI_AttributeSelection > edge() const
Edge.
void setByCenterOfCircle(const ModelHighAPI_Selection &theObject)
Set object for center of circular edge.
Definition: ConstructionAPI_Point.cpp:278
Dump wrapped feature.
Definition: ConstructionAPI_Point.cpp:290
virtual std::shared_ptr< ModelAPI_AttributeDouble > offset() const
Offset.
virtual std::shared_ptr< ModelAPI_AttributeSelection > intersectionPlane2() const
void setByLineAndPlaneIntersection(const ModelHighAPI_Selection &theEdge, const ModelHighAPI_Selection &theFace)
Set line and plane for intersections.
Definition: ConstructionAPI_Point.cpp:238
void setByPlanesIntersection(const ModelHighAPI_Selection &theFace1, const ModelHighAPI_Selection &theFace2, const ModelHighAPI_Selection &theFace3)
Set faces for intersections.
Definition: ConstructionAPI_Point.cpp:251
static const std::string & REVERSE()
Attribute name for reverse flag.
Definition: ConstructionPlugin_Point.h:155
static const std::string & INTERSECTION_LINE_1()
Attribute name for selected first intersection line.
Definition: ConstructionPlugin_Point.h:232
static const std::string & OBJECT_FOR_CENTER_OF_GRAVITY()
Attribute name for selected object for center of gravity.
Definition: ConstructionPlugin_Point.h:323
Point kind.
Definition: ConstructionPlugin_Point.h:58
static const std::string & INTERSECTION_PLANE_2()
Attribute name for selected intersection plane.
Definition: ConstructionPlugin_Point.h:288
static const std::string & OBJECT_FOR_CENTER_OF_CIRCLE()
Attribute name for selected object for center of cricle.
Definition: ConstructionPlugin_Point.h:330
static const std::string & EDGE()
Attribute name for selected edge.
Definition: ConstructionPlugin_Point.h:113
static const std::string & POINT_TO_PROJECT()
Attribute name for point to projection.
Definition: ConstructionPlugin_Point.h:162
static const std::string & FACE_FOR_POINT_PROJECTION()
Attribute name for face for point projection.
Definition: ConstructionPlugin_Point.h:197
static const std::string & REVERSE_OFFSET()
Attribute name for reverse offset for the intersection plane.
Definition: ConstructionPlugin_Point.h:274
static const std::string & INTERSECTION_PLANE_3()
Definition: ConstructionPlugin_Point.h:295
static const std::string & INTERSECTION_TYPE()
Attribute name for intersection type.
Definition: ConstructionPlugin_Point.h:204
static const std::string & DISTANCE()
Attribute name for distance.
Definition: ConstructionPlugin_Point.h:141
static const std::string & RATIO()
Attribute name for percent flag.
Definition: ConstructionPlugin_Point.h:148
static const std::string & INTERSECTION_LINE()
Attribute name for selected intersection line.
Definition: ConstructionPlugin_Point.h:246
static const std::string & OFFSET()
Attribute name for offset for the intersection plane.
Definition: ConstructionPlugin_Point.h:267
static const std::string & PROJECTION_TYPE()
Attribute name for projection type.
Definition: ConstructionPlugin_Point.h:169
static const std::string & GEOMETRICAL_PROPERTY_TYPE()
Attribute name for property type.
Definition: ConstructionPlugin_Point.h:302
static const std::string & INTERSECTION_PLANE_1()
Definition: ConstructionPlugin_Point.h:281
Definition: ConstructionPlugin_Point.h:65
static const std::string & OFFSET_TYPE()
Attribute name for offset type on selected edge.
Definition: ConstructionPlugin_Point.h:120
static const std::string & USE_OFFSET()
Attribute name for use offset for the intersection plane.
Definition: ConstructionPlugin_Point.h:260
static const std::string & INTERSECTION_PLANE()
Definition: ConstructionPlugin_Point.h:253
static const std::string & EDGE_FOR_POINT_PROJECTION()
Attribute name for edge for point projection.
Definition: ConstructionPlugin_Point.h:190
static const std::string & INTERSECTION_LINE_2()
Attribute name for selected second intersection line.
Definition: ConstructionPlugin_Point.h:239
Attribute that contains 3D point coordinates.
Definition: GeomDataAPI_Point.h:36
Dump engine for the model.
PointPtr addPointXYZ(const std::shared_ptr< ModelAPI_Document > &thePart, const ModelHighAPI_Selection &theObject)
Create Point feature by coordinates using the selected vertex.
Definition: ConstructionAPI_Point.cpp:419
PointPtr addPoint(const std::shared_ptr< ModelAPI_Document > &thePart, const ModelHighAPI_Double &theX, const ModelHighAPI_Double &theY, const ModelHighAPI_Double &theZ)
Create Point feature.
Definition: ConstructionAPI_Point.cpp:353
