20#ifndef SRC_EXCHANGEAPI_EXCHANGEAPI_EXPORT_H_
21#define SRC_EXCHANGEAPI_EXCHANGEAPI_EXPORT_H_
24#include "ExchangeAPI.h"
29#include <ModelHighAPI_Interface.h>
30#include <ModelHighAPI_Macro.h>
32#include <ExchangePlugin_ExportFeature.h>
55 const std::string & theFilePath,
56 const std::string & theAuthor = std::string(),
57 const std::string & theGeometryName = std::string(),
58 const std::string & theShapeFilePath = std::string());
63 const std::string & theFilePath,
67 const bool theIsRelative,
68 const bool theIsASCII);
73 const std::string & theFilePath,
75 const std::string & theAuthor,
76 const std::string & theGeometryName = std::string(),
77 const std::string & theShapeFilePath = std::string());
83 const std::string & theAuthor,
84 const std::string & theGeometryName = std::string());
89 const std::string & theFilePath,
90 const std::list<ModelHighAPI_Selection> & theSelectionList,
91 const std::string & theFileFormat = std::string());
148 const std::
150 const std::
string());
157 const std::
158 const std::
string(),
159 const std::
string(),
160 const std::
string());
167 const std::
171 const
bool theIsRelative,
172 const
bool theIsASCII);
179 const std::
181 const std::
string(),
182 const std::
string(),
183 const std::
string());
191 const std::
string(),
192 const std::
string());
203 const std::
Interface for Export feature.
Definition: ExchangeAPI_Export.h:46
Dump wrapped feature.
Definition: ExchangeAPI_Export.cpp:197
virtual std::shared_ptr< ModelAPI_AttributeString > xaoFilePath() const
xao_file_path
Definition: ExchangeAPI_Export.h:133
virtual std::shared_ptr< ModelAPI_AttributeDouble > stlabsolute() const
Absolute.
virtual std::shared_ptr< ModelAPI_AttributeString > fileFormat() const
file format
virtual std::shared_ptr< ModelAPI_AttributeString > xaoGeometryName() const
xao geometry name
virtual std::shared_ptr< ModelAPI_AttributeString > exportType() const
ExportType.
virtual std::shared_ptr< ModelAPI_AttributeString > stldeflectionTypeabsolute() const
Type of the defelection.
virtual std::shared_ptr< ModelAPI_AttributeString > stlfileType() const
Type of the stl file.
virtual std::shared_ptr< ModelAPI_AttributeString > stlFilePath() const
stl_file_path
virtual std::shared_ptr< ModelAPI_AttributeString > selectionList() const
selection list
ExchangeAPI_Export(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: ExchangeAPI_Export.cpp:38
virtual std::shared_ptr< ModelAPI_AttributeDouble > stlrelative() const
Relative.
virtual std::shared_ptr< ModelAPI_AttributeString > xaoShapeFilePath() const
xao shape file path
virtual std::shared_ptr< ModelAPI_AttributeString > stldeflectionType() const
virtual std::shared_ptr< ModelAPI_AttributeString > filePath() const
file path
virtual ~ExchangeAPI_Export()
Definition: ExchangeAPI_Export.cpp:173
virtual std::shared_ptr< ModelAPI_AttributeSelection > stlobjectselected() const
Object selected to export in stl file.
virtual std::shared_ptr< ModelAPI_AttributeString > memoryBuff() const
Bytes.
virtual std::shared_ptr< ModelAPI_AttributeString > xaoAuthor() const
xao author
virtual std::shared_ptr< ModelAPI_AttributeString > stldeflectionTyperelative() const
Feature kind.
Definition: ExchangePlugin_ExportFeature.h:40
static const std::string & XAO_GEOMETRY_NAME_ID()
attribute name of geometry name for XAO format
Definition: ExchangePlugin_ExportFeature.h:148
static const std::string & STL_ABSOLUTE()
Attribute name for absolute.
Definition: ExchangePlugin_ExportFeature.h:100
static const std::string & MEMORY_BUFFER_ID()
attribute string memory buffer
Definition: ExchangePlugin_ExportFeature.h:167
static const std::string & FILE_FORMAT_ID()
attribute name of file format
Definition: ExchangePlugin_ExportFeature.h:124
static const std::string & STL_DEFLECTION_TYPE()
Attribute name for deflection type.
Definition: ExchangePlugin_ExportFeature.h:76
static const std::string & STL_RELATIVE()
Attribute name for relative.
Definition: ExchangePlugin_ExportFeature.h:94
static const std::string & XAO_FILE_PATH_ID()
attribute name of xao file path
Definition: ExchangePlugin_ExportFeature.h:58
static const std::string & FILE_PATH_ID()
attribute name of file path
Definition: ExchangePlugin_ExportFeature.h:52
static const std::string & STL_DEFLECTION_TYPE_RELATIVE()
Attribute name for deflection type relative.
Definition: ExchangePlugin_ExportFeature.h:82
static const std::string & XAO_SHAPE_FILE_PATH_ID()
attribute name of xao shape file path
Definition: ExchangePlugin_ExportFeature.h:154
static const std::string & EXPORT_TYPE_ID()
attribute name for file format
Definition: ExchangePlugin_ExportFeature.h:46
static const std::string & SELECTION_LIST_ID()
attribute name of selection list
Definition: ExchangePlugin_ExportFeature.h:130
static const std::string & STL_DEFLECTION_TYPE_ABSOLUTE()
Attribute name for deflection type absolute.
Definition: ExchangePlugin_ExportFeature.h:88
static const std::string & STL_FILE_PATH_ID()
attribute name of stl file path
Definition: ExchangePlugin_ExportFeature.h:64
static const std::string & STL_OBJECT_SELECTED()
Attribute name for selected object to export in stl file path.
Definition: ExchangePlugin_ExportFeature.h:70
static const std::string & STL_FILE_TYPE()
Attribute name for stl file type.
Definition: ExchangePlugin_ExportFeature.h:106
static const std::string & XAO_AUTHOR_ID()
attribute name of author for XAO format
Definition: ExchangePlugin_ExportFeature.h:142
Dump engine for the model.
void exportPart(const std::shared_ptr< ModelAPI_Document > &thePart, const std::string &theFilePath, const std::list< ModelHighAPI_Selection > &theSelected=std::list< ModelHighAPI_Selection >())
Export selected features or the whole part to the binary file.
Definition: ExchangeAPI_Export.cpp:373
PyObject * exportToXAOMem(const std::shared_ptr< ModelAPI_Document > &thePart, const ModelHighAPI_Selection &theSelectedShape, const std::string &theAuthor=std::string(), const std::string &theGeometryName=std::string())
Exports to XAO format buffer the selected result with groups parts related to it only.
Definition: ExchangeAPI_Export.cpp:358
ExportPtr exportToSTL(const std::shared_ptr< ModelAPI_Document > &thePart, const std::string &theFilePath, const ModelHighAPI_Selection &theSelectedShape, const ModelHighAPI_Double &theDeflectionRelative, const ModelHighAPI_Double &theDeflectionAbsolute, const bool theIsRelative, const bool theIsASCII)
Exports to STL file the result of the current document.
Definition: ExchangeAPI_Export.cpp:323
ExportPtr exportToFile(const std::shared_ptr< ModelAPI_Document > &thePart, const std::string &theFilePath, const std::list< ModelHighAPI_Selection > &theSelectionList, const std::string &theFileFormat=std::string())
Export to file.
Definition: ExchangeAPI_Export.cpp:300
ExportPtr exportToXAO(const std::shared_ptr< ModelAPI_Document > &thePart, const std::string &theFilePath, const std::string &theAuthor=std::string(), const std::string &theGeometryName=std::string(), const std::string &theShapeFilePath=std::string())
Exports to XAO file all results of the current document.
Definition: ExchangeAPI_Export.cpp:311
