ExchangeAPI_Export Class Reference
Interface for Export feature. More...
#include <ExchangeAPI_Export.h>
Inheritance diagram for ExchangeAPI_Export:
 ExchangeAPI_Export (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 ExchangeAPI_Export (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::string &theFilePath, const std::string &theAuthor=std::string(), const std::string &theGeometryName=std::string(), const std::string &theShapeFilePath=std::string())
 Constructor with values for XAO export. More...
 ExchangeAPI_Export (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::string &theFilePath, const ModelHighAPI_Selection &theSelectedShape, const ModelHighAPI_Double &theDeflectionRelative, const ModelHighAPI_Double &theDeflectionAbsolute, const bool theIsRelative, const bool theIsASCII)
 Constructor with values for STL of selected result export. More...
 ExchangeAPI_Export (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::string &theFilePath, const ModelHighAPI_Selection &theResult, const std::string &theAuthor, const std::string &theGeometryName=std::string(), const std::string &theShapeFilePath=std::string())
 Constructor with values for XAO of selected result export. More...
 ExchangeAPI_Export (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theResult, const std::string &theAuthor, const std::string &theGeometryName=std::string())
 Constructor with values for XAO of selected result export to memory buffer. More...
 ExchangeAPI_Export (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::string &theFilePath, const std::list< ModelHighAPI_Selection > &theSelectionList, const std::string &theFileFormat=std::string())
 Constructor with values for export in other formats than XAO. More...
virtual ~ExchangeAPI_Export ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeString > exportType () const
 ExportType. More...
virtual std::shared_ptr< ModelAPI_AttributeString > filePath () const
 file path More...
virtual std::shared_ptr< ModelAPI_AttributeString > xaoFilePath () const
 xao_file_path More...
virtual std::shared_ptr< ModelAPI_AttributeString > fileFormat () const
 file format More...
virtual std::shared_ptr< ModelAPI_AttributeString > selectionList () const
 selection list More...
virtual std::shared_ptr< ModelAPI_AttributeString > xaoAuthor () const
 xao author More...
virtual std::shared_ptr< ModelAPI_AttributeString > xaoGeometryName () const
 xao geometry name More...
virtual std::shared_ptr< ModelAPI_AttributeString > stlFilePath () const
 stl_file_path More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > stlobjectselected () const
 Object selected to export in stl file. More...
virtual std::shared_ptr< ModelAPI_AttributeString > stldeflectionType () const
 Type of the defelection. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > stlrelative () const
 Relative. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > stlabsolute () const
 Absolute. More...
virtual std::shared_ptr< ModelAPI_AttributeString > stlfileType () const
 Type of the stl file. More...
virtual std::shared_ptr< ModelAPI_AttributeString > stldeflectionTypeabsolute () const
virtual std::shared_ptr< ModelAPI_AttributeString > stldeflectionTyperelative () const
virtual std::shared_ptr< ModelAPI_AttributeString > memoryBuff () const
 Bytes. More...
virtual std::shared_ptr< ModelAPI_AttributeString > xaoShapeFilePath () const
 xao shape file path More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeString > myexportType
std::shared_ptr< ModelAPI_AttributeString > myfilePath
std::shared_ptr< ModelAPI_AttributeString > myxaoFilePath
std::shared_ptr< ModelAPI_AttributeString > myfileFormat
std::shared_ptr< ModelAPI_AttributeString > myselectionList
std::shared_ptr< ModelAPI_AttributeString > myxaoAuthor
std::shared_ptr< ModelAPI_AttributeString > myxaoGeometryName
std::shared_ptr< ModelAPI_AttributeString > mystlFilePath
std::shared_ptr< ModelAPI_AttributeSelection > mystlobjectselected
std::shared_ptr< ModelAPI_AttributeString > mystldeflectionType
std::shared_ptr< ModelAPI_AttributeDouble > mystlrelative
std::shared_ptr< ModelAPI_AttributeDouble > mystlabsolute
std::shared_ptr< ModelAPI_AttributeString > mystlfileType
std::shared_ptr< ModelAPI_AttributeString > mystldeflectionTypeabsolute
std::shared_ptr< ModelAPI_AttributeString > mystldeflectionTyperelative
std::shared_ptr< ModelAPI_AttributeString > mymemoryBuff
std::shared_ptr< ModelAPI_AttributeString > myxaoShapeFilePath
◆ ExchangeAPI_Export() [1/6]
ExchangeAPI_Export::ExchangeAPI_Export ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ ExchangeAPI_Export() [2/6]
ExchangeAPI_Export::ExchangeAPI_Export ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::string &  theFilePath,
const std::string &  theAuthor = std::string(),
const std::string &  theGeometryName = std::string(),
const std::string &  theShapeFilePath = std::string()
explicit
◆ ExchangeAPI_Export() [3/6]
const ModelHighAPI_Selection &  theSelectedShape,
const ModelHighAPI_Double &  theDeflectionRelative,
const ModelHighAPI_Double &  theDeflectionAbsolute,
explicit
◆ ExchangeAPI_Export() [4/6]
const ModelHighAPI_Selection &  theResult,
const std::string &  theAuthor,
explicit
◆ ExchangeAPI_Export() [5/6]
explicit
◆ ExchangeAPI_Export() [6/6]
const std::list< ModelHighAPI_Selection > &  theSelectionList,
const std::string &  theFileFormat = std::string()
explicit
◆ ~ExchangeAPI_Export()
ExchangeAPI_Export::~ExchangeAPI_Export ( )
◆ exportType()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::exportType ( ) const
ExportType.
◆ filePath()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::filePath ( ) const
file path
◆ xaoFilePath()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::xaoFilePath ( ) const
xao_file_path
◆ fileFormat()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::fileFormat ( ) const
file format
◆ selectionList()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::selectionList ( ) const
selection list
◆ xaoAuthor()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::xaoAuthor ( ) const
xao author
◆ xaoGeometryName()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::xaoGeometryName ( ) const
xao geometry name
◆ stlFilePath()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::stlFilePath ( ) const
stl_file_path
◆ stlobjectselected()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ExchangeAPI_Export::stlobjectselected ( ) const
◆ stldeflectionType()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::stldeflectionType ( ) const
◆ stlrelative()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ExchangeAPI_Export::stlrelative ( ) const
Relative.
◆ stlabsolute()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ExchangeAPI_Export::stlabsolute ( ) const
Absolute.
◆ stlfileType()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::stlfileType ( ) const
◆ stldeflectionTypeabsolute()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::stldeflectionTypeabsolute ( ) const
◆ stldeflectionTyperelative()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::stldeflectionTyperelative ( ) const
◆ memoryBuff()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::memoryBuff ( ) const
Bytes.
◆ xaoShapeFilePath()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Export::xaoShapeFilePath ( ) const
xao shape file path
◆ dump()
void ExchangeAPI_Export::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
