FeaturesAPI_Chamfer.h
20#ifndef FeaturesAPI_Chamfer_H_
21#define FeaturesAPI_Chamfer_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_Chamfer.h>
26
32
37{
38public:
40 FEATURESAPI_EXPORT
41 explicit FeaturesAPI_Chamfer(const std::shared_ptr<ModelAPI_Feature>& theFeature);
42
44 FEATURESAPI_EXPORT
45 explicit FeaturesAPI_Chamfer(const std::shared_ptr<ModelAPI_Feature>& theFeature,
46 const std::list<ModelHighAPI_Selection>& theBaseObjects,
47 const bool performDistances,
48 const ModelHighAPI_Double& aVal1,
49 const ModelHighAPI_Double& aVal2);
50
52 FEATURESAPI_EXPORT
53 virtual ~FeaturesAPI_Chamfer();
54
55 INTERFACE_6(FeaturesPlugin_Chamfer::ID(),
56 creationMethod, FeaturesPlugin_Chamfer::CREATION_METHOD(),
74
75
76 FEATURESAPI_EXPORT
77 void setBase(const std::list<ModelHighAPI_Selection>& theBaseObjects);
78
80 FEATURESAPI_EXPORT
81 void setDistances(const ModelHighAPI_Double& theD1, const ModelHighAPI_Double& theD2);
82
84 FEATURESAPI_EXPORT
85 void setDistAngle(const ModelHighAPI_Double& theDistance, const ModelHighAPI_Double& theAngle);
86
88 FEATURESAPI_EXPORT
89 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
90
91private:
92 void execIfBaseNotEmpty();
93};
94
96typedef std::shared_ptr<FeaturesAPI_Chamfer> ChamferPtr;
97
100FEATURESAPI_EXPORT
101ChamferPtr addChamfer(const std::shared_ptr<ModelAPI_Document>& thePart,
102 const std::list<ModelHighAPI_Selection>& theBaseObjects,
103 const bool performDistances,
104 const ModelHighAPI_Double& theVal1,
105 const ModelHighAPI_Double& theVal2,
106 const bool keepSubResults = false);
107
108#endif // FeaturesAPI_Chamfer_H_
Interface for Chamfer feature.
Definition: FeaturesAPI_Chamfer.h:37
Definition: FeaturesAPI_Chamfer.cpp:55
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
Definition: FeaturesAPI_Chamfer.h:73
void setBase(const std::list< ModelHighAPI_Selection > &theBaseObjects)
Modify base objects of the chamfer.
Definition: FeaturesAPI_Chamfer.cpp:60
Dump wrapped feature.
Definition: FeaturesAPI_Chamfer.cpp:88
void setDistAngle(const ModelHighAPI_Double &theDistance, const ModelHighAPI_Double &theAngle)
Modify chamfer to have distance and angle.
Definition: FeaturesAPI_Chamfer.cpp:78
virtual std::shared_ptr< ModelAPI_AttributeDouble > d1() const
Value of the first distance chamfer.
virtual std::shared_ptr< ModelAPI_AttributeDouble > d2() const
Value of the second distance chamfer.
void setDistances(const ModelHighAPI_Double &theD1, const ModelHighAPI_Double &theD2)
Modify chamfer to have two distances.
Definition: FeaturesAPI_Chamfer.cpp:68
FeaturesAPI_Chamfer(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_Chamfer.cpp:26
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects() const
Base objects.
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle() const
Angle chamfer.
virtual std::shared_ptr< ModelAPI_AttributeDouble > d() const
Value of the distance chamfer.
static const std::string & D1_ID()
Attribute name of D1.
Definition: FeaturesPlugin_Chamfer.h:72
static const std::string & ANGLE_ID()
Attribute name of Angle.
Definition: FeaturesPlugin_Chamfer.h:93
static const std::string & D2_ID()
Attribute name of D2.
Definition: FeaturesPlugin_Chamfer.h:79
static const std::string & D_ID()
Attribute name of D.
Definition: FeaturesPlugin_Chamfer.h:86
Feature kind.
Definition: FeaturesPlugin_Chamfer.h:33
static const std::string & OBJECT_LIST_ID()
Attribute name of main objects.
Definition: FeaturesPlugin_Chamfer.h:65
Dump engine for the model.
ChamferPtr addChamfer(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theBaseObjects, const bool performDistances, const ModelHighAPI_Double &theVal1, const ModelHighAPI_Double &theVal2, const bool keepSubResults=false)
Create Chamfer feature.
Definition: FeaturesAPI_Chamfer.cpp:125
