FeaturesAPI_Chamfer Class Reference
Interface for Chamfer feature. More...
#include <FeaturesAPI_Chamfer.h>
Inheritance diagram for FeaturesAPI_Chamfer:
 FeaturesAPI_Chamfer (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_Chamfer (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const bool performDistances, const ModelHighAPI_Double &aVal1, const ModelHighAPI_Double &aVal2)
virtual ~FeaturesAPI_Chamfer ()
virtual std::string getID ()
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects () const
 Base objects. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > d1 () const
 Value of the first distance chamfer. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > d2 () const
 Value of the second distance chamfer. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > d () const
 Value of the distance chamfer. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle () const
 Angle chamfer. More...
void setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects)
 Modify base objects of the chamfer. More...
void setDistances (const ModelHighAPI_Double &theD1, const ModelHighAPI_Double &theD2)
 Modify chamfer to have two distances. More...
void setDistAngle (const ModelHighAPI_Double &theDistance, const ModelHighAPI_Double &theAngle)
 Modify chamfer to have distance and angle. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mybaseObjects
std::shared_ptr< ModelAPI_AttributeDouble > myd1
std::shared_ptr< ModelAPI_AttributeDouble > myd2
std::shared_ptr< ModelAPI_AttributeDouble > myangle
◆ FeaturesAPI_Chamfer() [1/2]
FeaturesAPI_Chamfer::FeaturesAPI_Chamfer ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_Chamfer() [2/2]
FeaturesAPI_Chamfer::FeaturesAPI_Chamfer ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theBaseObjects,
const ModelHighAPI_Double &  aVal1,
const ModelHighAPI_Double &  aVal2
explicit
◆ ~FeaturesAPI_Chamfer()
FeaturesAPI_Chamfer::~FeaturesAPI_Chamfer ( )
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_Chamfer::creationMethod ( ) const
Creation method.
◆ baseObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_Chamfer::baseObjects ( ) const
Base objects.
◆ d1()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Chamfer::d1 ( ) const
◆ d2()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Chamfer::d2 ( ) const
◆ d()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Chamfer::d ( ) const
◆ angle()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Chamfer::angle ( ) const
Angle chamfer.
◆ setBase()
void FeaturesAPI_Chamfer::setBase ( const std::list< ModelHighAPI_Selection > &  theBaseObjects)
◆ setDistances()
void FeaturesAPI_Chamfer::setDistances ( const ModelHighAPI_Double &  theD1,
const ModelHighAPI_Double &  theD2
◆ setDistAngle()
void FeaturesAPI_Chamfer::setDistAngle ( const ModelHighAPI_Double &  theDistance,
const ModelHighAPI_Double &  theAngle
◆ dump()
void FeaturesAPI_Chamfer::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
