FeaturesAPI_Offset.h
20#ifndef FeaturesAPI_Offset_H_
21#define FeaturesAPI_Offset_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_Offset.h>
26
27#include <ModelHighAPI_Double.h>
28#include <ModelHighAPI_Interface.h>
29#include <ModelHighAPI_Macro.h>
30
32
37{
38public:
40 FEATURESAPI_EXPORT
41 explicit FeaturesAPI_Offset(const std::shared_ptr<ModelAPI_Feature>& theFeature);
42
44 FEATURESAPI_EXPORT
45 explicit FeaturesAPI_Offset(const std::shared_ptr<ModelAPI_Feature>& theFeature,
46 const ModelHighAPI_Selection& theBaseObject,
47 const ModelHighAPI_Double& theOffset,
48 const bool isPipeJoint);
49
51 FEATURESAPI_EXPORT
52 explicit FeaturesAPI_Offset(const std::shared_ptr<ModelAPI_Feature>& theFeature,
53 const ModelHighAPI_Selection& theBaseObject,
54 const ModelHighAPI_Double& theOffset,
55 const std::list<ModelHighAPI_Selection>& theFaces);
56
58 FEATURESAPI_EXPORT
59 virtual ~FeaturesAPI_Offset();
60
61 INTERFACE_5(FeaturesPlugin_Offset::ID(),
62
65
68
71
74
77
78
79 FEATURESAPI_EXPORT
80 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
81};
82
84typedef std::shared_ptr<FeaturesAPI_Offset> OffsetPtr;
85
88FEATURESAPI_EXPORT
89OffsetPtr addOffset(const std::shared_ptr<ModelAPI_Document>& thePart,
90 const ModelHighAPI_Selection& theBaseObject,
91 const ModelHighAPI_Double& theOffset,
92 const bool isPipeJoint = true);
93
96FEATURESAPI_EXPORT
97OffsetPtr addOffsetPartial(const std::shared_ptr<ModelAPI_Document>& thePart,
98 const ModelHighAPI_Selection& theBaseObject,
99 const ModelHighAPI_Double& theOffset,
100 const std::list<ModelHighAPI_Selection>& theFaces);
101
102#endif // FeaturesAPI_Offset_H_
Interface for Offset feature.
Definition: FeaturesAPI_Offset.h:37
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
Definition: FeaturesAPI_Offset.h:76
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > faces() const
List of faces for partial offset.
virtual std::shared_ptr< ModelAPI_AttributeDouble > offsetValue() const
Value of the offset.
FeaturesAPI_Offset(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_Offset.cpp:29
Dump wrapped feature.
Definition: FeaturesAPI_Offset.cpp:71
Definition: FeaturesAPI_Offset.cpp:67
virtual std::shared_ptr< ModelAPI_AttributeBoolean > isPipeJoint() const
Is pipe or intersection joint.
virtual std::shared_ptr< ModelAPI_AttributeSelection > baseObject() const
Base object.
Feature kind.
Definition: FeaturesPlugin_Offset.h:37
static const std::string & CREATION_METHOD_ID()
Definition: FeaturesPlugin_Offset.h:44
static const std::string & BASE_SHAPE_ID()
Attribute name of base shape.
Definition: FeaturesPlugin_Offset.h:65
static const std::string & OFFSET_VALUE_ID()
Attribute name of offset value.
Definition: FeaturesPlugin_Offset.h:72
static const std::string & PIPE_JOINT_ID()
Attribute name of pipe/intersection joint bool flag.
Definition: FeaturesPlugin_Offset.h:79
static const std::string & FACES_ID()
Attribute name of sub-faces to offset (for partial offset).
Definition: FeaturesPlugin_Offset.h:86
Dump engine for the model.
OffsetPtr addOffset(const std::shared_ptr< ModelAPI_Document > &thePart, const ModelHighAPI_Selection &theBaseObject, const ModelHighAPI_Double &theOffset, const bool isPipeJoint=true)
Create Offset feature.
Definition: FeaturesAPI_Offset.cpp:101
OffsetPtr addOffsetPartial(const std::shared_ptr< ModelAPI_Document > &thePart, const ModelHighAPI_Selection &theBaseObject, const ModelHighAPI_Double &theOffset, const std::list< ModelHighAPI_Selection > &theFaces)
Definition: FeaturesAPI_Offset.cpp:112
